Hello Forum!
I have a short Captivate file I have recently edited. I'm now ready to publish it, but I keep getting a "Publish Failed" error message. It comes up immediately upon trying to publish.
I have done a number of things suggested in this forum that do not seem to be helping:
I was hoping to get these files out to users next week. Does anyone have any further suggestions? I'd be happy to send you the file for review.
Many thanks!
You have already tried a lot of actions, but did not see those:
I didn't see which version you are using, so just an example of that famous 'Preferences folder' for 5.5: it is labeled Captivate 5.5 - do not look for 'Preferences' and can be found here:
Windows Vista and Windows 7: C:\Users\[user name]\AppData\Local\Adobe\Adobe Captivate 5.5 folder
Windows XP: C:\Documents and Settings\[user name]\Local Settings\Application Data\Adobe\Adobe Captivate 5.5 folder
Mac: /Users/[user name]/Library/Preferences/Adobe Captivate 5.5 folder
Thank you, Lilybiri, RodWard, and Avinash!
I am using Captivate 5.5. Sorry for not saying. I am trying to publish to a .swf file, though .html file is checked as well. And I am NOT having any trouble on the preview.
I tried both Lily and Rod's suggestions, but end up with the same result. I hid each slide one by one (there are only 11), but I got a Publish Failed on each of them. Any other ideas? With 11 slides, I think it might just be good to start over, huh?
Jen W
I presume you've been able to publish previous to this?
Before starting over, you might try opening a new, blank project, then copying your slides to that project.
You could try copying them one at a time and see if you can isolate the problem, or en mass and see what happens.
Right click the slides (or click/shift-click to select all/range) in the filmstrip, copy, go to the new project, and paste into the filmstrip. Publish, see what happens.
Thanks, Andy!
Yeah, that's the crazy part -- I've published this file before. It just has a few tweaks and updates, but now it won't publish.
And I publised different files after getting stuck on this one.
I did copy the slides en masse to a blank file, and it still wouldn't publish. I didn't try them one by one, though. Maybe that would help isolate the problem? I appreciate the suggestion!
Jen W
Hi Jennifer,
How about the location you are publishin to? Any issue with HD space? How about changing the publish drive/folder?
Can you publish another project without issue? To that same location?
What's the error message specifically say - any hints there?
How about embedded files? Any external resources CP may not be able to find on publish?
Thank you, everyone, for being willing to help out! I've discovered the problem, and after much blushing and saying of bad words, here it is.
The Project Title (as shown on the Publish screen) had a punctuation mark in it. I had tried the titles "What is iLearn?" and "Using iLearn: What is iLearn." When a coworker suggested taking out the question mark, I thought that was going to be the fix. But replacing it with a colon wasn't the way to go. When I finally took out the colon as well, it worked fine.
The only message I received was "Publish Failed." It happened immediately after I pressed the Publish button, so the computer wasn't even trying to do anything with the file. And it previewed just fine. So, hopefully this will help someone else who runs across the problem.
Again, thank you to all of you!
Jen
Hi Lilybiri,
I'm having this same issue and i"m using Captivate 5. I'm in Administrator mode and everytime I publish to a swf if fails. I was able to publish the file before, but now can't so I'm guessing something in the changes I made is causing thsi problem. But I was going to try your solution here and I do not have that folder, should I be concerned? Here's my screenshot of that path...
