CS6 wants to generate peak files every time I open the same project. I had a similar problem once with CS5, and when I unchecked the box telling the applicatio to save media files near their originals it went awat. But this box is still unchecked, and yet PP keeps wasting time and processing with this task. How can I get the program to recognize the Peak Files it has already created?
You need to tell Adobe, so the information gets to the programmers
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
I'm a complete PP newbie, so I'm not sure if I'm having the same thing: everytime I open my project it says something along the lines of "conforming clip X of X" at the bottom. I currently have over 8,000 clips so it takes quite a while to complete. I just assumed this is normal behaviour for PP, so I didn't bring it up until seeing this thread. Is it not supposed to do that?
Chris Conlee
Mac Pro (4,1)
OS X 10.7.4
24Gb RAM
GTX 285 (latest)
Matrox Mini Max (3.1)
PP 6.0.1
This is the problem that I reported. It is supposed to do this the first time a file is opened (or the first time an asset is imported into the project). However, the program is supposed to story the files it generates, and then access them when the file is opened any time in the future. This appears to be a bug in the Mac version of CS6. Let's hope the fix it soon.
Well upon getting to the office this morning I read what it actually said, and it says LOADING file x of x, which I assume is normal? So in my case I don't think it's actually regenerating anything, simply validating database links?
Chris Conlee
Mac Pro (4,1)
OS X 10.7.4
24Gb RAM
nVidia GTX 285 (CUDA 4.2.10)
Dual Monitors
Matrox Mini Max
PP 6.0.1
Actually it's also a issue with the windows version of cs6 as well. Because it kept happening to me over and over again. It also happens to one of my co-workers who is on windows 7 as well. My co-worker and I have both reported the bug to adobe so hopefully they will be able to resolve the issue shortly. Because quite frankly I had to quit editing certain projects with Premiere CS6 because I have well over 400 clips in some of my projects and it gets a bit old having to sit there and wait for it to conform the same files over and over every time I open the same project over and over again.
Other than this issue though I haven't really had any problems with Premiere cs6 although this one is a rather annoying problem to have...
I would have sworn it has something to do with the fact that the Library files are hidden in Lion, but if it's happening in the Windows version too then so much for that theory.
I just don't get how something like this slips through the cracks. Don't they test this stuff before they release it?
Thanks, that seems to be a step in the right direction. This seems to help, but introduces new problems. Firstly, premiere still wants to conform every file in the project each time it's opened. Less of a time suck than before, but still a time suck. Second, audio tracks do not import completely, they just drop off to nothing, which makes the program essentially useless.
Do I get anything for beta-testing this?
I filed a bug on this against CS6. I remmeber it well because it was the #1 pain point for my own workflow projects. But it's media-specific so it hasn't been fixed for everyone. The media I was using to get the bug was 720p motion jpegs inside an mov wrapper. (system file info shows Codecs: Photo - JPEG, Linear PCM) The only workarounf is to transcode to something different.
In order to escalate the bug, what I need from each person is to know what kind of media you can repro it wth 100%. The main info I need is:
File format
Codec
Resolution & Interlace vs Progressive (720p, 1080i, etc)
Good to hear that. I havent ran into the problem in quite awhile, but oddly enough all I did to fix it was I ended up doing a reinstall of CS6 (then updated the software) and the problem went away. The media I was experincing the issue with was BMD's MJPEG codec. So apparently it is indeed media specific. We actually experinced the issue with very similar media.
The media it occurred with for me was
1920x1080i (uff) using the BMD MPJEG codec inside a .AVI cotainer.
I can't reproduce the problem anymore though, sorry. Basically when it was occuring simply opening a project caused it to occur. Even though it had already loaded the files several times before.
I'm having problems with the following format:
File format: MPEG Movie
Codec: MPEG-1/2 Video (mpgv)
Resolution & Interlace vs Progressive: 1440 x 1080 (1080i), 25fps
video files were captured with Premiere CS6 from a HDV tape
(an mp4 file in the same project that was imported as an existing file doesn't have this problem)
@ ComputerNovice: Thanks for the info. It is helpful and I added it to the exisitng bug report. I'm glad it went for you, but what I was encoutnering definately did not go away after re-install, which i would have done daily back in the CS6 dev timeframe.
@ Bugzke: Thank you as well. it is really helpful to have al the specifics listed out liek that so i can jsut paste it right into the bug.
I've had this problem since CS5, so consider my skeptical Adobe is ever going to fix it. It happens to me with 720x480 29.97i DV MOV files as well as 1920x1080 29.97i AVCHD MTS fies.
Part of the time what happens is everything conforms, I alt-tab out of the program and back, it begins to re-start comforming all over again but then crashes. If I restart the program it does the whole process again but usually won't crash.
Lately I can alt-tab in and out numerous times and without fail, something will always start re-conforming.
CS6 on a Mac Pro with Mountain Lion.
File formats: QuickTime MOV, Windows AVI, MTS
Codecs: DV, DV, AVCHD
Resolution & Interlace vs Progressive: 720x480, 29.97i, 720x480, 29.97i, 1920x1080, 29.97i
video files were recorded onto a DTE FireStore FS-100, captured by Sony Vegas Pro Video Capture, off an SD card from a Panasonic HMC-40
Same issue here.
File format: MPEG
Codec: Canon MXF
Resolution: 720p 60fps
Loaded to HD using Canon XF ultility and then imported into Premiere CS6.
Tries to conform on each load. Worse yet, enabling automacitc peak file generation in preferences causes media to "drop out" the next time the project is loaded, displaying the "media pending" screen. Trying to quit then causes Premiere Pro to lock up.
I am a relatively new PP user. I just brought the editing staff in our company over to PP from FCP 7. We are now editing all new shows in PP. The redrawing is indeed an issue, especially since we tend to have 2000+ clips in our shows between video and audio components. We shoot in XDCAM HD, 1440x1080, 35 mbs. Usually 2-3 camera shoots, 100-200 clips per disc per camera, 2 discs per camera per show. It is a lot of material, but we found by putting 32 gigs of ram in each computer that we only wait about 1 minute for all the files to regenerate, or conform, or whatever they are doing. Ram is pretty cheap now, and it never hurts to have more. Might be a fix for some until Adobe can figure out how to just read the files that have been generated. We are using 2011 8 core MacPro's with NVidia Quadro 4000 cards.
Hi All
I am a new CS6 user (used older version until recently). The generating-peak-files-every time-you-open-a-new-project bug is a serious one for me.
Is this bug finally solved? In which version?
Specifics are: very simple files (SD, PAL 50fps). It strikes me that this bug has not been solved upon the first user complaint, because in CS3 or PPro 2.0 this has always worked fine.
Btw: we are working with W7. Is that perhaps a part of the problem?
Dear jstrawn,
Could you please indicate for which settings and file types the bug does not appear? After two months of "getting-used-to", we are beginning to make some more complex shows now (with over 100 clips) and CS6 turns out to be completely unusable for us with DV-PAL.
Right now we are doing the simple stuff on our 16GB i7 PC with W7 and CS6 and the complex things on an old machine with WXP and PP2.0. An awkward situation, isn't it?
Would switching over to 720p50 be a solution? And which settings do you advise to prevent the "generating peak files..."-bug?
Thanks in advance for your reply
