Render At Same Settings As Import
Jun 20, 2012 9:09 AM
Running AE 5.5 on a Mac tower with OSX 10.6.4
This is most likely very obvious;  I was given an .mov of unspecified codec to color correct, (864x486, not that the size matters, no transformations there) and I'd like to output it with the same codec I was given.  I have determined the color space is sRGB IEC61966-2.1 and my Project color space is the same.
How can I find out the "native" codec, short of bothering my client??
Thank you!
    Jun 20, 2012 9:21 AM   in reply to JesseHarris
    Have you tried opening the file in quicktime and hitting Command + I.  This should open the an info box and tell you the exact format of the clip.
    Highlight the footage in question in the project window.  At the very top, you'll see the information about that file: H&V size, frame rate, media container (e.g. Quicktime movie) and codec (e.g. ProRes 422).
    Jun 20, 2012 9:25 AM   in reply to JesseHarris
    This is a NEGATIVE confirmation.  Look at what's written above.  Proceed accordingly.
    Jun 20, 2012 9:52 AM   in reply to JesseHarris
    Looks odd. Does Quicktime itself reveal any CoDec info (Cmd-J/ Cmd-I)? There are "None" and a generic "Video" CoDec in QT which might not yield any readout.... If it's those, then that would possibly explain it...
    Mylenium
    Jun 20, 2012 9:54 AM   in reply to JesseHarris
    It is possible to render out of After Effects with the codec set to "none" so this may be the case...
    But, as I said before, you could confirm this by opening the clip in quicktime player and hitting Command + I or going Window - Show Movie Inspector.
    Jun 20, 2012 10:39 AM   in reply to JesseHarris
    No problem we're here to help.  As Mylenium said, it could also just be a generic video codec that doesn't yield a readout in both Quicktime and After Effects, so it seems you should be fine exporting out to "none." However, I'm curious if the file size is a lot larger when you export it to "none."  You may want to check in with your client anyway to see what format he/she would like the clips exported in because you could end up getting much larger file sizes by setting it to "none" in the video codec settings.  This could potentially effect playback.  There are other lossless or near lossless codecs such as ProRes or H.264, which your client might prefer over "none," or a DNxHD file if they want to continue editing in Avid.
    Jun 20, 2012 10:48 AM   in reply to BenMarkus
    BenMarkus wrote:
    ...There are other lossless or near lossless codecs such as ProRes or H.264, which your client might prefer over "none," or a DNxHD file if they want to continue editing in Avid.
    Hmmm... personally, I'd exclude H.264 from the list.  It's a good final delivery codec, and it's regrettably an acquisition codec, but you're implying that it's an acceptable intermediate codec.  That's really iffy in my opinion.
    For my projects I would not use it.  Not ever.  Not even as a joke.
    Aug 10, 2012 9:12 AM   in reply to Dave LaRonde
    That's true.  I would not use H.264 for an intermediate Codec.  It's definitely lossy, but as Dave said H.264 quicktimes are usually good enough for final output especially if you're going to be screening something from the desktop and want to make sure it will play back smoothly.
