InDesign CS6/CS5 compatibility question
Jun 20, 2012 10:22 AM
I need to know if users in InDesign CS5 will be able to successfully work in an InDesign file I create and save back from CS6. I was told by someone at Adobe that these 2 versions were NOT compatible at all, even though I was told by another Adobe employee that you can save back 1 version with no issues.  What is correct?  And... if we ALL upgrade to CS6, will we be able to open up files we created in CS5 or earlier with no issues?  The guy that said they were totally incompatible sent me this link:
http://www.adobe.com/products/indesign/buying-guide-version-comparison .html
So I need a definitive answer - can we, or can we not, exchange between CS5 and CS6???  Thank you.
    Jun 20, 2012 10:30 AM   in reply to Dazidoodles1
    You can export the file to IDML and it will open in CS5. Whether is resembles your layout or not is up in the air.
    This is, quite simply, a very poor workflow. If the recipients need CS5 files then work in CS5.
    If you all upgrade to CS6 there should be no issues opening the earlier files.
    Bob
    Jun 20, 2012 10:55 AM   in reply to Dazidoodles1
    An exact answer depends on the exact wording of your question.
    "Are CS5 and CS6 files compatible with each other?" NO.
    But a longer, and more accurate, answer is "They are, up to a certain point and with proper precautions."
    1. You cannot open a 6 file in '5 or earlier. To be able to, save your file as IDML -- that *can* be opened by earlier versions, at least one or two. (Saving back to a CS3 compatible format, for example, takes more effort and a working CS4.)
    2. When saving as IDML, the file ought to open exactly as it was with the original version. If there were any new features used in the file, they will be (silently!) ignored by older versions.
    3. Due to code changes, there might be a change in text flow. Nothing you can do about it, text is always reformatted according to the internal rules of the version you open it with.
    4. Older version files ought to open right away in a newer version. "Ought to", because the latger the difference in version, the larger chances *something* might fail. Apart from that, the text might also reflow, as per point 3.
    So you see, the correct answer to "are they compatible. depends more on how much time you have to answer it.
    Jun 20, 2012 10:59 AM   in reply to [Jongware]
    (I also have the distinct impression we, the daily users of InDesign, know substantially more about it than your average Adobe Help Center employee. :) Any further questions? Always here to help.)
