Tutorials for drag and drop multiple objects on a sigle target
Jun 20, 2012 12:36 PM
I hoping someone could direct me to tutorials that show how to make drag and drop multiple objects to a single target and get different results based on which object I drag.
  • kglad
    Jul 21, 2002
    Jun 20, 2012 1:25 PM   in reply to lightwavemac
    use any drag-and-drop as3 tutorial that you can understand.  in the mouseup listener function your can use the event's currentTarget to determine which object was dropped and then execute the corresponding code.
  • kglad
    Jul 21, 2002
    Jun 21, 2012 9:11 AM   in reply to lightwavemac
    var hitArray:Array = new Array(hitTarget1,hitTarget1,hitTarget1);
    var dropArray:Array = new Array(drop1,drop2,drop3);
    var positionsArray:Array = new Array();
    for (var i:int = 0; i < dropArray.length; i++) {
    dropArray[i].buttonMode = true;
    dropArray[i].addEventListener(MouseEvent.MOUSE_DOWN, mdown);
    dropArray[i].addEventListener(MouseEvent.MOUSE_UP, mUp);
    positionsArray.push({xPos:dropArray[i].x, yPos:dropArray[i].y});
    function mdown(e:MouseEvent):void {
    e.currentTarget.startDrag();
    setChildIndex(MovieClip(e.currentTarget), numChildren - 1);
    function mUp(e:MouseEvent):void {
    var dropIndex:int = dropArray.indexOf(e.currentTarget);
    var target:MovieClip = e.currentTarget as MovieClip;
    target.stopDrag();
    if (target.hitTestObject(hitArray[dropIndex])) {
    target.x = hitArray[dropIndex].x;
    target.y = hitArray[dropIndex].y;
    if(dropIndex==0){
    somemovieclip.gotoAndStop(someframe);
    } else if(dropIndex==1){
    somemovieclip.gotoAndStop(someotherframe);
    } else {
    somemovieclip.gotoAndStop(anotherframe);
    }else{
    target.x = positionsArray[dropIndex].xPos;
    target.y = positionsArray[dropIndex].yPos;
  • kglad
    Jul 21, 2002
    Jun 21, 2012 1:10 PM   in reply to lightwavemac
    it's possible that's correct but noone could determine that from the information you've given.  you should be able to see how your app is performing and determine if that is what you want.
  • kglad
    Jul 21, 2002
    Jun 21, 2012 4:39 PM   in reply to lightwavemac
    use the trace function to debug your actionscript:
    target.stopDrag();
    trace(dropIndex);
    // if this traces something other than -1, put trace functions in frame 2 of drop1, frame 3 of drop2 etc.
    if(dropIndex==0){
    drop1.gotoAndStop(2);
    drop2.gotoAndStop(3);
    } else {
    drop3.gotoAndStop(4);
    }else{
