File Import Failure
Jun 20, 2012 1:30 PM
Tags: #premiere #elements #10
This issue has begun to happen regularly.  I work on making a family video and all is going fine.  I save and come back to the project next day and close out  again after a while after saving my work.
Next day, I try to open the file and I get, "File Import Failure"   Error message  -  This type of file not supported, or the required codec is not supported.
The monitor panel is several shades of red with the notation, "media off-line" in ten different languages stacked on top of each other.
I use a Canon Vixia HF M32 camcorder whick uses AVCHD.  Prior to the past several months, I have not had this problem.  What am I doing wrong?  What should I do to correct this?
Thank you,
George Rodgers
    Jun 20, 2012 1:43 PM   in reply to rodgerssouth
    Can you offer any more details? Like your operating system, your processor, how much free, defragmented space is on your C or main hard drive and if you are editing on one or a second or external hard drive?
    Jun 20, 2012 1:49 PM   in reply to rodgerssouth
    Well, if the files, that are giving you issues, have been previously Imported, something has changed.
    First, see this ARTICLE on Media Offline, to see if anything applies there.
    As for the AVCHD files, you should have the H.264 CODEC installed, if you were able to Import those. However, it is possible that your H.264 CODEC has become corrupted, or somehow removed from the system - CODEC's are installed at the system level for video editing.
    1. What version of Apple's QuickTime Player do you have installed?
    2. Did you update it, or perhaphs iTunes recently?
    3. Have you installed any CODEC "packs?"
    4. Have you installed any new video editing programs, or any new hardware?
    5. Have you experienced any problems with your C:\ drive, like lost documents, etc.?
    Wish I had more, but good luck,
    Hunt
