handsome_pete
building a workstation, advice welcomed
Jun 14, 2012 2:21 PM
Ok, so I'm contemplating the custom workstation route.  I'm a long time Mac based video editor/motion graphics artist in need of a new workstation and I think I'm ready to move back to Windows.  I'm usually pretty good with any technical and hands on type of stuff, but I've been away from Windows for so long and have no experience with building PCs other than watching a few friends do it back in college.  So I'm hoping that I'm not entirely in over my head here.  Any advice would be welcome.
Here is what I have so far.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber =20531366
My thinking on the CPU side of things was I would ideally like to run a dual CPU configuration, but it's just not in the budget right now.  So I was hoping to run a single 2687w on a dual chip board and then upgrade down the road.  Again, I'm not that familiar with how all of this works, so I'm just going by the limited info I've read so far in various forums.
I'm questioning my motherboard choice the most since there are no reviews posted yet.  I suppose other options would be the ASUS or SuperMicro.
So please let me know what you think.  Along with running the Adobe suite, I'll be doing a lot of 3D modeling and animation so that's why I'm leaning towards the Xeons and the potential to use 2 chips in the future.
    Jun 19, 2012 12:32 PM   in reply to handsome_pete
    Nice looking parts list!  Here are my thoughts:
    For just a few $'s more, I would upgrade to the AX PSU line from Corsair.  More efficient...less heat generated...which you can translate into quieter environment
    If you really want/need a dual socket board, you are pretty limited in choices, ...but I would go with the EVGA also.  But do you REALLY want to go dual socket?  These Xeon CPU's can not be overcloced much at all (5% I believe), so until you get a second CPU, you will be working with a 3.1 GHz processor for almost $2 grand, when you could have opted for a 3960X for almost $1,000 less and then overclocked it to about 5GHz.  Plus the motherboard would have been cheaper also.  Tough decision to make, for sure.
    If you do switch to a single socket board, check out the Asrock Extreme 11.  Supposed to be released next month.  By far the most feature packed motherboard released....ever.  Ever.
    If it were me, I'd probably go with a 680GTX over the Quadro.   Less costly, more powerful.  But both are good cards.
    Good luck, and update the post with what you buy!
    Message edit by cpachris_1969:  clarified release date for Extreme 11 as NEXT month.
    Jun 19, 2012 12:39 PM   in reply to handsome_pete
    In addition to what cpachris_1969 stated, that wish list does not have anywhere near enough disks. As listed, you have only a single disk plus the OS disk - barely sufficient for even standard-definition DV AVI work, let alone high-definition work. You will need at least three more identical disks in addition to the one that's already in your wish list if you're going to work with HD video content. This is because all NLEs, Premiere Pro included, decompress (unpack) video to full uncompressed on the fly for display, and full uncompressed (even unpacked for a brief moment) require a ton of disk I/O throughput to even edit video smoothly. No single hard disk can even deliver average transfer speed that matches even the minimum throughput that's required of uncompressed HD video. And if you edit on a disk system that's below the minimum requirements of the video content, the playback will suffer from dropped frames big time.
    Jun 19, 2012 12:44 PM   in reply to handsome_pete
    This is a lob-sided system. Overkill on the mobo and CPU, underpowered on memory and disks, wrong PSU, too small a case, wrong video card and suboptimal CPU cooler. You should be able to do way better for that amount of $$$.
    Either go all the way ($ 15K) or stay within this budget range and choose a better balanced system. See Adobe Forums: What PC to build? An update... or Adobe Forums: Planning / building a new system. Part 1
    Jun 19, 2012 1:26 PM   in reply to handsome_pete
    I would guess that a six core 3960X overclocked to anywere between 4.5GHz and 5.0 GHz would outperform a stock 8 core Xeon.  However, if you really plan on getting the second CPU at some point, what your planning is pretty sweet.
    I'd get the GTX series video card if it was primarily Adobe software, but would stick with your initial Quadro if you are using a lot of programs where the drivers have been optimized for the Quadro series.
    Jun 19, 2012 1:22 PM   in reply to handsome_pete
    The truth about the Quadro 4000 is that Adobe Premiere Pro does not take anywhere close to full advantage of the card's enhanced OpenGL capabilities. As such, to Premiere it is only about equal to a far cheaper GeForce GTX 460 SE. However, Avid does take at least some advantage of the Quadro's capabilities, and thus tend to perform faster than an otherwise comparable GeForce in such an app.
