I have the worst crashing issue from what I read. Any flash activity causes Firefox to completly FREEZE 100% of the time on any site with flash. I tried the protected mode test, same issue. I tried a new Firefox profile same issue. I submitted a full bug report.
Win7 32 bit, newest firefox newest flash.
Your issue sounds different from the one described in the other thread. I've branched it into it's own discussion in order to track and discuss it with you more effectively.
Do you happen to know the ID of the bug you filed? I poked around in the new bugs, but I'm not seeing a title that jumps out at me.
I'm thinking it's this one, let me know if it's not:
https://bugbase.adobe.com/index.cfm?event=bug&id=3219894
There are a couple things that could be going on. I don't have enough data to guess based on your bug.
I'd like to get links to any crashes that are getting logged in Firefox since you've upgraded.
If you type "about:crashes" in the browser (no quotes), and then hit Enter, you should get a list of submitted crash reports.
Just click each one (or Ctrl+Click to open them in new tabs) and paste the links in the reply to this thread. I'd like to see if they're signatures we're already familiar with, or if something unique is happening for you.
First, try disabling Hardware Acceleration, and restart your browser. There are instructions in the video toubleshooting guide under the Solve Video Problems section, here:
http://helpx.adobe.com/flash-player/kb/video-playback-issues.html
If that doesn't work, let's try restarting Firefox in Safe Mode to see if there's something else in-play:
Click Firefox > The arrow to the right of Help > Restart with Add-Ons Disabled (don't worry, it's temporary as long as everything remains unchecked)
Click Restart
Click Continue in Safe Mode
Go about your business, and see if the crashing stops.
If you're still seeing crashing, try the Troubleshooting Protected Mode guide here:
http://forums.adobe.com/thread/1018071?tstart=0
Okay, that should cover first steps pretty well. We'll do our best to get you sorted out.
That will be super helpful, thank you. Also, if you can point me to a site / workflow that you frequently see the crash in, that would be good. I found a laptop with a similar chipset (HD 6310), but I'm not seeing the crashes there.
Also, if you go here, you should see the ID of the bug you filed: https://bugbase.adobe.com/index.cfm?event=home
That big report is mine. IN addition you will be probably annoyed at this point, but after completely uninstall 11.3 a sper your instructions, and manualy rebooting and deleting all said files, I have now reupdated to the newest version and now it is working fine. Maybe you will want to try uninstalling then reboot and delete all relate files and reupdate, worked for me.
Sites it haped on were many. Off hand www.youtube.com then click on any video at all. Also www.cinemassacre.com again click on any video
I think why it worked for a little bit is because I rebooted and was not playing a video game. Earlier, and now, it is happening after I fire up my video game, which I play windows mode running alongside my browser etc. I disabled acceleration and right now I am using my browser and playing my game at the same time and for the last 5 minutes no freezing.
Thanks. We released a patch overnight (11.3.300.262) that addresses a couple stability issues.
http://get.adobe.com/flashplayer/?promoid=BUIGP
If the issue persists, can you please try disabling hardware acceleration in Firefox?
https://support.mozilla.org/en-US/kb/forum-response-disable-hardware-a cceleration
I have disabled every plugin except flash and updated to the new one. INterestingly youtube is now using HTML 5 for videos today, check it out. Right click the video to see this. So I goto www.cinemassacre.com and the browser freezes solid. I cannot disable acceleration now because it freezes so I cannot right click. If there is another way to disable acceleration let me know. When I close the plugin container process it comes right back and keeps it froxzen. I must end the firefox process. This freezes so bad it does not generate an error report.
Do you want me to post a video of this happening so u can see it?
The address you want to type is "about:crashes", no quotes.
The RealPlayer issue is only about Flash not loading at all. As far as we can tell at this point, it's not causing crashes.
Youtube is showing up in Flash for me. It might be particular videos, or there may be a "prefer HTML video" preference somewhere. I poked around a little in the Youtube UI, but I didn't find it. Logging out of YouTube (or using private browsing mode) would be a pretty good way to check that.
I'm not seeing the cinemassacre hang when I check with Firefox 13.0.1 on Win7 x64. I'm definitely interested in the output of dxdiag. I'm hoping I can find a similar machine in our labs that reproduces the problem.
To do that, click Start > Run (or in Win7, just Start and type in the bar).
Type dxdiag and hit [Enter]
You should see the DirectX Diagnostic Tool load.
Click Save All Information and save it to your desktop. You can just paste the contents in here, or attach it to your reply (click the Use Advanced Editor link on the upper right of the reply window, then scroll down to Attach Files).
Here ya go!
System Information
Time of this report: 6/21/2012, 16:04:18
Machine name: NORM
Operating System: Windows 7 Professional 32-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120330-1504)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Core(TM)2 Duo CPU E6550 @ 2.33GHz (2 CPUs), ~2.3GHz
Memory: 4096MB RAM
Available OS Memory: 3582MB RAM
Page File: 2517MB used, 1562MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: 120 DPI (125 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: AMD Radeon HD 6670
Manufacturer: Advanced Micro Devices, Inc.
Chip type: ATI display adapter (0x6758)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_6758&SUBSYS_E1941092&REV_00
Display Memory: 2548 MB
Dedicated Memory: 1012 MB
Shared Memory: 1535 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: BBY LCD TV
Monitor Id: PRI0042
Native Mode: 1920 x 1080(p) (59.991Hz)
Output Type: HDMI
Driver Name: aticfx32.dll,aticfx32.dll,aticfx32.dll,atiumdag.dll,atidxx32.dll,atiu mdva.cap
Driver File Version: 8.17.0010.1124 (English)
Driver Version: 8.961.0.0
DDI Version: 11
Driver Model: WDDM 1.1
Driver Attributes: Final Retail
Driver Date/Size: 4/5/2012 19:21:52, 909312 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-2418-11CF-4677-9EC1BEC2C535}
Vendor ID: 0x1002
Device ID: 0x6758
SubSys ID: 0xE1941092
Revision ID: 0x0000
Driver Strong Name: oem47.inf:ATI.Mfg.NTx86.6.1:ati2mtag_NI:8.961.0.0:pci\ven_1002&dev_67 58
Rank Of Driver: 00E62001
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description: Speakers (2- High Definition Audio Device)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0883&SUBSYS_10438249&REV_1000
Manufacturer ID: 1
Product ID: 65535
Type: WDM
Driver Name: HdAudio.sys
Driver Version: 6.01.7601.17514 (English)
WHQL Logo'd: Yes
Date and Size: 11/20/2010 03:00:21, 304128 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Digital Audio (S/PDIF) (2- High Definition Audio Device)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Description: Headphones (2- High Definition Audio Device)
Manufacturer ID: 1
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (2- High Definition Audio Device)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Line In (2- High Definition Audio Device)
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x1
Description: Line (Roxio GAMECAP)
Driver Name: USBAUDIO.sys
Date and Size: 11/20/2010 02:59:44, 80768 bytes
Cap Flags: 0x1
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Super Smartjoy 2
Attached: 1
Controller ID: 0x4
Vendor/Product ID: 0x6666, 0x0667
FF Driver: n/a
Device Name: PPJoy Virtual Joystick 1
Attached: 1
Controller ID: 0x3
Vendor/Product ID: 0xDEAD, 0xBEF0
FF Driver: n/a
Device Name: VJoy Virtual Joystick
Attached: 1
Controller ID: 0x1
Vendor/Product ID: 0xFEED, 0xFACE
FF Driver: n/a
Attached: 1
Controller ID: 0x2
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x10DE, 0x026D
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 3/24/2011 19:58:37, 258560 bytes
| Driver: usbd.sys, 3/24/2011 19:57:53, 5888 bytes
+-+ Logitech Cordless USB Mouse
| | Vendor/Product ID: 0x046D, 0xC50E
| | Matching Device ID: usb\vid_046d&pid_c50e
| | Lower Filters: LUsbFilt
| | Service: HidUsb
| | Driver: LUsbFilt.sys, 3/18/2010 02:02:32, 28624 bytes
| | Driver: hidusb.sys, 11/20/2010 02:59:38, 24064 bytes
| | Driver: hidclass.sys, 11/20/2010 02:59:38, 55808 bytes
| | Driver: hidparse.sys, 7/13/2009 16:51:00, 25728 bytes
| | Driver: LkmdfCoInst.dll, 3/18/2010 02:02:00, 1581136 bytes
| +-+ Logitech HID-compliant Cordless Mouse
| | | Matching Device ID: hid\vid_046d&pid_c50e
| | | Upper Filters: LMouFilt
| | | Lower Filters: LHidFilt
| | | Service: mouhid
| | | Driver: LHidFilt.Sys, 3/18/2010 02:01:52, 38864 bytes
| | | Driver: LMouFilt.Sys, 3/18/2010 02:02:08, 37328 bytes
| | | Driver: mouhid.sys, 7/13/2009 16:45:08, 26112 bytes
| | | Driver: mouclass.sys, 7/13/2009 18:20:44, 41552 bytes
| | | Driver: LMouFiltCoInst.dll, 4/28/2010 15:29:24, 53328 bytes
+-+ USB Input Device
| | Matching Device ID: generic_hid_device
| | Service: HidUsb
| | OEMData: 00 00 00 10 08 00 00 00
| +-+ HID-compliant game controller
| | | Matching Device ID: hid_device_system_game
Gameport Devices
PS/2 Devices
+ Standard PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/13/2009 16:11:24, 80896 bytes
| Driver: kbdclass.sys, 7/13/2009 18:20:36, 42576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/20/2010 05:30:12, 53120 bytes
| Driver: sermouse.sys, 7/13/2009 16:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 33.2 GB
Total Space: 114.4 GB
File System: NTFS
Model: NVIDIA STRIPE 111.79G
Drive: D:
Free Space: 116.3 GB
Total Space: 2861.5 GB
File System: NTFS
Model: WDC WD30 EZRX-00MMMB0 SCSI Disk Device
Drive: H:
Free Space: 3.8 GB
Total Space: 5722.9 GB
File System: NTFS
Model: H/W RAID 5 USB Device
Drive: T:
Free Space: 66.2 GB
File System: NTFS
Drive: E:
Model: HL-DT-ST DVDRAM GSA-H62N SCSI CdRom Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/20/2010 01:38:10, 108544 bytes
Drive: B:
Model: YREL 6RWTIRS SCSI CdRom Device
System Devices
Name: PCI standard RAM Controller
Device ID: PCI\VEN_10DE&DEV_03B6&SUBSYS_00000000&REV_A1\3&2411E6FE&1&10
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AE&SUBSYS_00000000&REV_A1\3&2411E6FE&1&09
Driver: n/a
Name: nForce Memory Controller
Device ID: PCI\VEN_10DE&DEV_0272&SUBSYS_81BC1043&REV_A3\3&2411E6FE&1&52
Driver: n/a
Name: NVIDIA nForce Serial ATA Controller
Device ID: PCI\VEN_10DE&DEV_0266&SUBSYS_81BC1043&REV_A1\3&2411E6FE&1&70
Driver: C:\Windows\system32\DRIVERS\nvstor32.sys, 11.01.0000.0043 (English), 4/9/2010 01:32:56, 215656 bytes
Driver: C:\Windows\system32\nvraidco.dll, 11.01.0000.0043 (English), 4/9/2010 01:32:56, 372840 bytes
Driver: C:\Windows\system32\nvraiins.dll, 11.01.0000.0043 (English), 4/9/2010 01:32:56, 372840 bytes
Driver: C:\Windows\system32\NvRCoDa.dll, 11.01.0000.0043 (Danish), 4/9/2010 01:32:56, 17512 bytes
Driver: C:\Windows\system32\NvRCoDe.dll, 11.01.0000.0043 (German), 4/9/2010 01:32:58, 18024 bytes
Driver: C:\Windows\system32\NvRCoEng.dll, 11.01.0000.0043 (English), 4/9/2010 01:32:58, 17000 bytes
Driver: C:\Windows\system32\NvRCoENU.dll, 11.01.0000.0043 (English), 4/9/2010 01:33:00, 17000 bytes
Driver: C:\Windows\system32\NvRCoEs.dll, 11.01.0000.0043 (Spanish), 4/9/2010 01:33:00, 18024 bytes
Driver: C:\Windows\system32\NvRCoEsm.dll, 11.01.0000.0043 (Spanish), 4/9/2010 01:33:02, 18024 bytes
Driver: C:\Windows\system32\NvRCoFi.dll, 11.01.0000.0043 (Finnish), 4/9/2010 01:33:02, 17512 bytes
Driver: C:\Windows\system32\NvRCoFr.dll, 11.01.0000.0043 (French), 4/9/2010 01:33:04, 18024 bytes
Driver: C:\Windows\system32\NvRCoIt.dll, 11.01.0000.0043 (Italian), 4/9/2010 01:33:04, 18024 bytes
Driver: C:\Windows\system32\NvRCoJa.dll, 11.01.0000.0043 (Japanese), 4/9/2010 01:33:04, 15464 bytes
Driver: C:\Windows\system32\NvRCoKo.dll, 11.01.0000.0043 (Korean), 4/9/2010 01:33:06, 15464 bytes
Driver: C:\Windows\system32\NvRCoNl.dll, 11.01.0000.0043 (Dutch), 4/9/2010 01:33:06, 17512 bytes
Driver: C:\Windows\system32\NvRCoNo.dll, 11.01.0000.0043 (Norwegian (Bokmål)), 4/9/2010 01:33:08, 17512 bytes
Driver: C:\Windows\system32\NvRCoPtb.dll, 11.01.0000.0043 (Portuguese), 4/9/2010 01:33:08, 18024 bytes
Driver: C:\Windows\system32\NvRCoRu.dll, 11.01.0000.0043 (Russian), 4/9/2010 01:33:10, 17512 bytes
Driver: C:\Windows\system32\NvRCoSv.dll, 11.01.0000.0043 (Swedish), 4/9/2010 01:33:10, 17512 bytes
Driver: C:\Windows\system32\NvRCoZhc.dll, 11.01.0000.0043 (Chinese (Simplified)), 4/9/2010 01:33:12, 14952 bytes
Driver: C:\Windows\system32\NvRCoZht.dll, 11.01.0000.0043 (Chinese (Traditional)), 4/9/2010 01:33:12, 14952 bytes
Device ID: PCI\VEN_10DE&DEV_03B5&SUBSYS_00000000&REV_A1\3&2411E6FE&1&06
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AD&SUBSYS_00000000&REV_A1\3&2411E6FE&1&08
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0270&SUBSYS_81BC1043&REV_A2\3&2411E6FE&1&48
Driver: n/a
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_10DE&DEV_0265&SUBSYS_81BC1043&REV_A1\3&2411E6FE&1&68
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 18:20:45, 12368 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 18:19:03, 42560 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 18:26:15, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/20/2010 05:29:12, 132992 bytes
Device ID: PCI\VEN_10DE&DEV_03B4&SUBSYS_00000000&REV_A1\3&2411E6FE&1&07
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AC&SUBSYS_00000000&REV_A1\3&2411E6FE&1&01
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_10DE&DEV_026F&SUBSYS_CB8410DE&REV_A2\3&2411E6FE&1&80
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/20/2010 05:30:06, 153984 bytes
Name: NVIDIA nForce PCI System Management
Device ID: PCI\VEN_10DE&DEV_0264&SUBSYS_81BC1043&REV_A3\3&2411E6FE&1&51
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B3&SUBSYS_00000000&REV_A1\3&2411E6FE&1&0E
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AB&SUBSYS_00000000&REV_A1\3&2411E6FE&1&04
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026E&SUBSYS_81BC1043&REV_A3\3&2411E6FE&1&59
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/24/2011 19:57:58, 43008 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/24/2011 19:58:07, 284672 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/24/2011 19:58:37, 258560 bytes
Name: PCI standard ISA bridge
Device ID: PCI\VEN_10DE&DEV_0260&SUBSYS_81BC1043&REV_A3\3&2411E6FE&1&50
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 18:20:43, 13888 bytes
Device ID: PCI\VEN_10DE&DEV_03BC&SUBSYS_00000000&REV_A1\3&2411E6FE&1&11
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B2&SUBSYS_00000000&REV_A1\3&2411E6FE&1&0D
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03AA&SUBSYS_00000000&REV_A1\3&2411E6FE&1&02
Driver: n/a
Name: Standard OpenHCD USB Host Controller
Device ID: PCI\VEN_10DE&DEV_026D&SUBSYS_81BC1043&REV_A3\3&2411E6FE&1&58
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.01.7601.17586 (English), 3/24/2011 19:57:58, 20480 bytes
Name: JMicron JMB36X Controller
Device ID: PCI\VEN_197B&DEV_2360&SUBSYS_82081043&REV_02\4&2212B143&0&0038
Driver: C:\Windows\system32\DRIVERS\jraid.sys, 1.17.0008.0001 (English), 12/7/2006 03:41:16, 44416 bytes
Driver: C:\Windows\system32\DRIVERS\JGOGO.sys, 5.00.3790.0001 (English), 2/8/2006 03:52:58, 6912 bytes
Device ID: PCI\VEN_10DE&DEV_03BB&SUBSYS_0C5510DE&REV_A1\3&2411E6FE&1&38
Device ID: PCI\VEN_10DE&DEV_03B1&SUBSYS_00000000&REV_A1\3&2411E6FE&1&0C
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A9&SUBSYS_00000000&REV_A1\3&2411E6FE&1&03
Driver: n/a
Name: ARBLU88Q IDE Controller
Device ID: PCI\VEN_105A&DEV_3318&SUBSYS_145B5885&REV_01\4&5D18F2DF&1
Driver: n/a
Name: High Definition Audio Controller
Device ID: PCI\VEN_10DE&DEV_026C&SUBSYS_82491043&REV_A2\3&2411E6FE&1&81
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/20/2010 02:59:29, 108544 bytes
Name: A6ZRXIYM IDE Controller
Device ID: PCI\VEN_11AB&DEV_6140&SUBSYS_F0DC44BF&REV_01\4&5D18F2DF&0
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03BA&SUBSYS_00000000&REV_A1\3&2411E6FE&1&12
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03B0&SUBSYS_00000000&REV_A1\3&2411E6FE&1&0B
Driver: n/a
Device ID: PCI\VEN_10DE&DEV_03A8&SUBSYS_00000000&REV_A2\3&2411E6FE&1&05
Driver: n/a
Device ID: PCI\VEN_1002&DEV_AA90&SUBSYS_AA901092&REV_00\4&6BB9499&1&0118
Name: NVIDIA nForce 10/100/1000 Mbps Ethernet
Device ID: PCI\VEN_10DE&DEV_0269&SUBSYS_82211043&REV_A3\3&2411E6FE&1&A0
Driver: C:\Windows\system32\DRIVERS\nvmf6232.sys, 7.03.0001.7330 (English), 3/4/2010 18:26:56, 296936 bytes
Driver: C:\Windows\system32\fdco2.dll, 2.02.0000.7330 (English), 3/4/2010 18:04:50, 953856 bytes
Driver: C:\Windows\system32\nvconrm.dll, 1.09.0008.0093 (English), 3/4/2010 01:49:38, 207464 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvunrm.exe, 1.10.0057.0035 (English), 3/4/2010 01:49:34, 600680 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvnrm.nvu, 3/4/2010 01:35:00, 9079 bytes
Name: VIA VT6421 RAID Controller
Device ID: PCI\VEN_1106&DEV_3249&SUBSYS_32491106&REV_50\4&14591D7E&0&3880
Driver: C:\Windows\system32\DRIVERS\vsmraid.sys, 6.00.6000.6210 (English), 7/13/2009 18:19:11, 141904 bytes
Device ID: PCI\VEN_10DE&DEV_03B7&SUBSYS_0C5510DE&REV_A1\3&2411E6FE&1&18
Device ID: PCI\VEN_10DE&DEV_03AF&SUBSYS_00000000&REV_A1\3&2411E6FE&1&0A
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_10DE&DEV_03A3&SUBSYS_00000000&REV_A2\3&2411E6FE&1&00
Driver: n/a
Name: AMD Radeon HD 6670
Device ID: PCI\VEN_1002&DEV_6758&SUBSYS_E1941092&REV_00\4&6BB9499&1&0018
Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.1243 (English), 4/5/2012 22:21:10, 9334784 bytes
Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0024 (English), 4/5/2012 18:09:02, 53248 bytes
Driver: C:\Windows\system32\DRIVERS\atikmpag.sys, 8.14.0001.6261 (English), 4/5/2012 18:10:22, 275968 bytes
Driver: C:\Windows\system32\atiumdag.dll, 7.14.0010.0903 (English), 4/5/2012 18:34:04, 6203392 bytes
Driver: C:\Windows\system32\atiumdva.dll, 8.14.0010.0355 (English), 4/5/2012 18:22:54, 4795904 bytes
Driver: C:\Windows\system32\atitmmxx.dll, 6.14.0011.0023 (English), 4/5/2012 19:14:36, 159744 bytes
Driver: C:\Windows\system32\atiicdxx.dat, 1/10/2012 14:10:08, 601728 bytes
Driver: C:\Windows\system32\amdpcom32.dll, 8.14.0010.0023 (English), 4/5/2012 18:06:04, 53760 bytes
Driver: C:\Windows\system32\atimpc32.dll, 8.14.0010.0023 (English), 4/5/2012 18:06:04, 53760 bytes
Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1100 (English), 4/5/2012 18:11:18, 360448 bytes
Driver: C:\Windows\system32\atiumdva.cap, 4/5/2012 18:21:42, 2664704 bytes
Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1002 (English), 4/5/2012 19:14:28, 20992 bytes
Driver: C:\Windows\system32\atiapfxx.exe, 6.14.0010.1001 (English), 4/5/2012 19:22:00, 159744 bytes
Driver: C:\Windows\system32\atiapfxx.blb, 4/5/2012 19:23:06, 245896 bytes
Driver: C:\Windows\system32\atiumdmv.dll, 7.14.0010.0184 (English), 4/5/2012 18:34:50, 1831424 bytes
Driver: C:\Windows\system32\ativvsva.dat, 2/14/2012 19:28:34, 157144 bytes
Driver: C:\Windows\system32\ativvsvl.dat, 2/14/2012 19:28:32, 204952 bytes
Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1120 (English), 4/5/2012 19:15:50, 217600 bytes
Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1120 (English), 4/5/2012 19:16:24, 451072 bytes
Driver: C:\Windows\system32\ati2edxx.dll, 6.14.0010.2514 (English), 4/5/2012 19:14:20, 43520 bytes
Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.4478.38306 (English), 4/5/2012 19:16:52, 442368 bytes
Driver: C:\Windows\system32\atioglxx.dll, 6.14.0010.11631 (English), 4/5/2012 18:50:56, 19753984 bytes
Driver: C:\Windows\system32\aticaldd.dll, 6.14.0010.1720 (English), 4/5/2012 18:25:30, 13764096 bytes
Driver: C:\Windows\system32\aticalrt.dll, 6.14.0010.1720 (English), 4/5/2012 18:30:14, 46080 bytes
Driver: C:\Windows\system32\aticalcl.dll, 6.14.0010.1720 (English), 4/5/2012 18:30:06, 44032 bytes
Driver: C:\Windows\system32\atipblag.dat, 9/12/2011 15:06:16, 3917 bytes
Driver: C:\Windows\system32\atiu9pag.dll, 8.14.0001.6261 (English), 4/5/2012 18:09:34, 32256 bytes
Driver: C:\Windows\system32\atigktxx.dll, 8.14.0001.6261 (English), 4/5/2012 18:10:52, 33280 bytes
Driver: C:\Windows\system32\atiglpxx.dll, 8.14.0001.6261 (English), 4/5/2012 18:11:04, 14848 bytes
Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 21:35:30, 118784 bytes
Driver: C:\Windows\system32\atidxx32.dll, 8.17.0010.0432 (English), 4/5/2012 19:13:42, 6800896 bytes
Driver: C:\Windows\system32\atiuxpag.dll, 8.14.0001.6261 (English), 4/5/2012 18:09:48, 41984 bytes
Driver: C:\Windows\atiogl.xml, 3/5/2012 15:15:04, 38159 bytes
Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 6/22/2009 15:34:20, 45056 bytes
Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 8/27/2010 18:32:08, 294912 bytes
Driver: C:\Windows\system32\aticfx32.dll, 8.17.0010.1124 (English), 4/5/2012 19:21:52, 909312 bytes
Driver: C:\Windows\system32\coinst.dll, 1.00.0003.0005 (English), 4/5/2012 19:00:08, 52736 bytes
Device ID: PCI\VEN_10DE&DEV_0267&SUBSYS_81BC1043&REV_A1\3&2411E6FE&1&78
Driver: C:\Windows\system32\DRIVERS\nvstor.sys, 10.06.0000.0018 (English), 3/10/2011 22:39:00, 143744 bytes
DirectShow Filters
Nero Digital:
Nero Digital Renderer,0x00100000,1,0,NeroDigital.dll,5.05.0027.0000
Nero Digital MP4 Muxer,0x00100000,1,1,NeroDigital.dll,5.05.0027.0000
Nero Digital AAC Encoder,0x00100000,1,1,NeroDigital.dll,5.05.0027.0000
Subpic Encoder,0x00100000,1,3,NeroDigital.dll,5.05.0027.0000
Watermark,0x00200000,1,1,NeroDigital.dll,5.05.0027.0000
AMR Encoder,0x00100000,1,1,NeroDigital.dll,5.05.0027.0000
Nero Digital AVC Encoder,0x00100000,1,1,NeroDigital.dll,5.05.0027.0000
Media Type Adjustment,0x00200000,1,1,NeroDigital.dll,5.05.0027.0000
Nero Digital DMO Wrapper,0x00200000,1,1,NeroDigital.dll,5.05.0027.0000
Nero Digital SP/ASP Encoder,0x00100000,1,1,NeroDigital.dll,5.05.0027.0000
VideoTee,0x00200000,1,2,NeroDigital.dll,5.05.0027.0000
PreviewRenderer,0x00400000,1,0,NeroDigital.dll,5.05.0027.0000
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
Annodex Mux Filter,0x00200000,1,0,dsfAnxMux.dll,0.80.15035.0000
CMML Decode Filter,0x00800002,1,1,dsfCMMLDecoder.dll,0.80.15035.0000
CMML Raw Source Filter,0x00600000,0,0,dsfCMMLRawSource.dll,0.80.15035.0000
FLAC Decode Filter,0x00600000,1,1,dsfFLACDecoder.dll,0.80.15035.0000
FLAC Encode Filter,0x00200000,1,1,dsfFLACEncoder.dll,0.80.15035.0000
Native FLAC Source Filter,0x00600000,0,0,dsfNativeFLACSource.dll,0.80.15035.0000
Ogg Demux Packet Source Filter,0x00600000,0,0,dsfOggDemux2.dll,0.80.15035.0000
Ogg Mux Filter,0x00200000,1,0,dsfOggMux.dll,0.80.15035.0000
OGM Decode Filter,0x00600000,1,1,dsfOGMDecoder.dll,0.80.15035.0000
Speex Decode Filter,0x00600000,1,1,dsfSpeexDecoder.dll,0.80.15035.0000
Speex Encode Filter,0x00200000,1,1,dsfSpeexEncoder.dll,0.80.15035.0000
Subtitle VMR9 Filter,0x00800002,1,1,dsfSubtitleVMR9.dll,0.80.15035.0000
Theora Decode Filter,0x00600000,1,1,dsfTheoraDecoder.dll,0.80.15035.0000
Theora Encode Filter,0x00200000,1,1,dsfTheoraEncoder.dll,0.80.15035.0000
Vorbis Encode Filter,0x00200000,1,1,dsfVorbisEncoder.dll,0.80.15035.0000
Nero Digital Audio Encoder 8,0x00200000,1,2,NeNDAud.ax,5.05.0027.0000
Nero Digital Muxer 8,0x00200000,2,1,NeNDMux.ax,5.05.0027.0000
Nero Digital File Writer 8,0x00200000,1,0,NeNDMux.ax,5.05.0027.0000
Nero Digital Null Renderer 8,0x00200000,1,0,NeNDMux.ax,5.05.0027.0000
Nero Digital Subpicture Enc 8,0x00200000,1,0,NeNDMux.ax,5.05.0027.0000
Nero Digital Video Enc 8,0x00200000,1,2,NeNDVid.ax,5.05.0027.0000
ROXIO SubPicture Encoder,0x00000000,0,0,,
Nero Sound Switcher,0x00200000,1,1,NeSoundSwitch.ax,5.05.0027.0000
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.01.4070.0000
roxio DCFilters Smart Resizer,0x00000000,0,0,,
Vorbis Decode Filter,0x00600000,1,1,dsfVorbisDecoder.dll,0.80.15035.0000
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,5.05.0027.0000
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,5.05.0027.0000
Nero Subpicture Decoder,0x00200000,1,1,NeSubpicture.ax,5.05.0027.0000
ROXIO QuickGrabber 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
MainConcept MP4 Multiplexer,0x00200000,1,1,mc_mux_mp4_ds.ax,8.08.0000.35710
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
Record Queue,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,15.04.3538.0513
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,15.04.3538.0513
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,5.05.0027.0000
Roxio Audio Stream Reader Filter,0x00000000,0,0,,
ffdshow DXVA Video Decoder,0xff800002,2,1,ffdshow.ax,1.01.4070.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.01.4070.0000
ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.01.4070.0000
ATI Ticker,0x00200000,0,1,Ticker.ax,
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,5.05.0027.0000
ROXIO Video Effect 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
Sonic AAC Decoder,0x00200000,1,1,roxio86_dec_aac_ds.ax,8.05.0000.15132
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,5.05.0027.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
LAV Splitter,0x00400001,1,1,LAVSplitter.ax,0.40.0000.0000
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
ROXIO VideoTransition 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
Audio Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2926
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
Nero Splitter,0x00600000,1,3,NeSplitter.ax,5.05.0027.0000
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
DV V/A Source Filter,0x00400000,0,1,dvsf.ax,6.00.0000.0000
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
Roxio Anaglyph to Stereo,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
RadLight Vorbis Decoder,0x00800001,1,1,RLVorbisDec.ax,1.00.0000.0002
ROXIO SceneRecorder 1.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
Nero Vobu Generator,0x00200000,1,0,NeroVobuGenerator.ax,5.05.0027.0000
RealVideo Decoder,0x00400000,1,1,RealMediaDX.ax,1.00.0001.0001
roxio DCFilters DVD Splitter,0x00000000,0,0,,
Sonic Stream Parser,0x00200000,1,2,roxio86_demux_mp2_ds.ax,8.05.0000.15132
Nero Audio Renderer,0x00200000,1,0,NeAudioRender.ax,5.05.0027.0000
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,5.05.0027.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
Roxio Repacketizer Filter,0x00000000,0,0,,
ROXIO InputSelectorNew 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
ROXIO VCFpeakmeter 3.0,0x00200000,1,1,roxaudio.ax,1.00.0000.0057
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
Nero Teletext Filter,0x00200000,1,1,NeTeletext.ax,5.05.0027.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,5.05.0027.0000
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
Sonic MPEG-4 Video Decoder,0x00200000,1,1,roxio86_dec_mp4v_ds.ax,8.05.0000.15132
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
ROXIO BDAV Smart Render 1.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Nero DVD Navigator,0x00600000,0,14,NeDVD.ax,5.05.0027.0000
ROXIO InputSelector 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
ROXIO CrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,1.00.0000.0057
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
ATI MPEG File Writer,0x00200000,1,0,atimpenc.dll,12.04.0000.20405
ATI MPEG Video Decoder,0x005fffff,1,2,atimpenc.dll,12.04.0000.20405
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0007.0001
Roxio Vob Loader,0x00200000,0,1,VOBLoader.ax,1.00.0000.0057
DV V/A ACM Source Filter,0x00400000,0,1,dvsf.ax,6.00.0000.0000
Roxio Video Rotater,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Roxio MPEG1 Encoder,0x00000000,0,0,,
roxio DCFilters Dragon Lair,0x00000000,0,0,,
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
Roxio-Intel Media SDK H.264 Encoder,0x00200000,1,1,RoxioH264Encode.ax,1.00.0000.0001
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
Nero Resize,0x00400000,1,1,NeResize.ax,5.05.0027.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
ROXIO VCFStationLogo 1.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
VCGImageSource,0x00200000,0,1,VideoCompositing.ax,1.00.0000.0057
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0007.0001
Nero Colorspace Converter,0x00200000,1,1,NeColorspace.ax,5.05.0027.0000
ROXIO Scene Detector 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
VMR9 Wrapper 3.0,0x00200000,1,0,VideoCompositing.ax,1.00.0000.0057
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,5.05.0027.0000
DV Video Source Filter,0x00400000,0,1,dvsf.ax,6.00.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
ROXIO Audio Source 3.0,0x00200000,0,1,roxaudio.ax,1.00.0000.0057
Roxio StereoSource Cropper,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
MMACE ProcAmp,0x00200000,0,2,MMACEFilters.dll,
DivX Video Decoder 0001,0x00800000,1,1,DivXDec.ax,8.00.0000.0002
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,5.05.0027.0000
ROXIO DVDCrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,5.05.0027.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
ROXIO VCFWaveform 1.0,0x00200000,1,0,roxaudio.ax,1.00.0000.0057
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,5.05.0027.0000
Nero FLV Splitter,0x00400000,1,1,NeFLVSplitter.ax,5.05.0027.0000
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,5.05.0027.0000
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.11.0288.0000
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.11.0288.0000
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,5.05.0027.0000
ROXIO AudioGrabber 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
Nero MP2 Audio Encoder,0x00200000,1,1,NeMP2AudioEnc.ax,5.05.0027.0000
roxio DCFilters Mpeg I/II Decoder,0x00000000,0,0,,
Disk Record Queue,0x00200000,1,1,wmedque.dll,9.00.0000.2926
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,5.05.0027.0000
Nero HD Audio Mixer,0x00200000,3,1,NeHDAudioMixer.ax,5.05.0027.0000
ROXIO VCFAlphaSplitter 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
ROXIO VCFLatency 3.0,0x00200000,1,1,roxaudio.ax,1.00.0000.0057
roxio DCFilters MPEG Transcoder,0x00000000,0,0,,
ATI MPEG Audio Encoder,0x00200000,1,1,atimpenc.dll,12.04.0000.20405
Xvid MPEG-4 Video Decoder,0x00800000,1,1,xvid.ax,
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,5.05.0027.0000
ROXIO SpyPos 3.0,0x00200000,1,1,MGINullIP.ax,1.00.0000.0057
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,5.05.0027.0000
AMD MJPEG Decoder,0x00800001,1,1,atimpenc.dll,12.04.0000.20405
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
CoreAAC Audio Decoder,0x00800000,1,1,CoreAAC.ax,1.02.0000.0575
ROXIO ColorSpace Converter 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
ROXIO Pin Tee,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Nero Elementary Stream Parser,0x00200000,1,1,NeESParser.ax,5.05.0027.0000
Roxio MPEG Stream Analyzer,0x00000000,0,0,,
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7601.17713
Roxio Plasma CrossGraph Source,0x00200000,0,1,PlasmaCGFilter.ax,1.00.0000.0057
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
ROXIO FLV Splitter,0x00200000,1,1,RoxFlvSplitter.ax,1.00.0000.0057
ROXIO VCFAudioMixer 3.0,0x00200000,1,1,roxaudio.ax,1.00.0000.0057
ROXIO Video Integrate,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
Nero Audio Transcoder,0x00200000,1,1,NeTranscoder.ax,5.05.0027.0000
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,5.05.0027.0000
ROXIO CPU Regulator,0x00200000,1,1,CPURegulator.ax,1.00.0000.0057
ATI MPEG Video Encoder,0x00200000,1,1,atimpenc.dll,12.04.0000.20405
Haali Video Renderer,0x00200000,1,0,dxr.dll,
RealMedia Source,0x00600000,0,0,RealMediaDX.ax,1.00.0001.0001
File Writer,0x00200000,1,0,WLXVAFilt.dll,15.04.3538.0513
Roxio MPEG1 Audio Encoder,0x00000000,0,0,,
ATI MPEG Multiplexer,0x00200000,2,1,atimpenc.dll,12.04.0000.20405
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,5.05.0027.0000
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
Nero TS Muxer,0x00200000,1,1,NeTSMuxer.ax,5.05.0027.0000
FLV Video Decoder,0x00600000,1,1,flvDX.dll,1.00.0000.0001
ROXIO Pan Zoom 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Nero Framerate Converter,0x00200000,1,1,NeFramerate.ax,5.05.0027.0000
Sonic MPEG Demultiplexer,0x00200000,1,2,roxio86_demux_mp2_ds.ax,8.05.0000.15132
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,5.05.0027.0000
Dib Output,0x00200000,0,1,DibOutput.ax,8.01.0000.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
Dib Receive,0x00200000,1,0,DibReceive.AX,8.01.0000.0000
Nero Mpeg Video Encoder,0x00200000,1,1,NeMpegVideoEnc.ax,5.05.0027.0000
MMACE SoftEmu,0x00200000,0,2,MMACEFilters.dll,
File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
ROXIO Field Splitter 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Roxio MPEG Analyzer,0x00000000,0,0,,
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
Roxio RealD to Stereo,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Roxio Audio Source Filter,0x00000000,0,0,,
ATI Video Scaler Filter,0x00200000,1,1,atimpenc.dll,12.04.0000.20405
ROXIO Video Resampler 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Nero Video Decoder HD,0x00200000,1,2,NeVideoHD.ax,5.05.0027.0000
Sonic AVC/H.264 Video Decoder,0x00800000,1,2,roxio86_dec_avc_ds.ax,8.05.0000.23127
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.11.0288.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,5.05.0027.0000
ROXIO VCFDVSceneDetect 1.0,0x00200000,1,2,RoxVideo.ax,1.00.0000.0057
DirectVobSub,0x00200000,2,1,vsfilter.dll,1.05.0003.3752
RealAudio Decoder,0x00400000,1,1,RealMediaDX.ax,1.00.0001.0001
ROXIO Deinterlace 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
ROXIO DV Scene Detector Tee 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,1.05.0003.3752
roxio DCFilters DVD Reader,0x00000000,0,0,,
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17713
ROXIO Audio VCFLooper 3.0,0x00200000,1,1,roxaudio.ax,1.00.0000.0057
ULead Infinite Pin Tee,0x00200000,1,1,uinftee.ax,1.00.0000.0001
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,5.05.0027.0000
MMACE DeInterlace,0x00200000,0,2,MMACEFilters.dll,
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7601.17713
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,5.05.0027.0000
ROXIO AudioConvert 3.0,0x00200000,1,1,roxaudio.ax,1.00.0000.0057
Audio Source Filter,0x00400000,0,1,AudioSF.ax,
Roxio VOB Formatter,0x00200000,1,1,VOBFormatter.ax,1.00.0000.0057
Nero MP3 Encoder,0x00200000,1,1,NeMp3Encoder.ax,5.05.0027.0000
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.11.0288.0000
RadLight Speex Decoder,0x00600000,1,1,RLSpeexDec.ax,1.00.0000.0000
AC3Filter,0x40000000,1,1,ac3DX.ax,1.00.0001.0000
Ulead AC3 Audio Decoder 2,0x00200000,1,1,ulac32.ax,1.09.0002.0002
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7601.17713
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,5.05.0027.0000
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
VCG Null Renderer 3.0,0x00200000,1,0,VideoCompositing.ax,1.00.0000.0057
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
PSI Parser,0x00200000,0,0,RoxVideo.ax,1.00.0000.0057
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
ROXIO DVDCrossGraphEx Source 3.0,0x00200000,0,1,RoxVideo.ax,1.00.0000.0057
ROXIO WAV Dest 3.0,0x00200000,0,0,roxaudio.ax,1.00.0000.0057
roxio DCFilters DVD Muxer,0x00000000,0,0,,
Sonic Cinemaster® Audio Decoder 4.3,0x005ffffe,1,1,CinemasterAudio.DLL,4.03.0000.0240
roxio DCFilters Subpicture Mixer,0x00000000,0,0,,
ROXIO LVM File Source (Async.),0x00200000,0,1,LVMAsync.ax,1.00.0000.0057
ROXIO MPEG Writer,0x00000000,0,0,,
ROXIO Audio VCFChunker 3.0,0x00200000,1,1,roxaudio.ax,1.00.0000.0057
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.01.4070.0000
Screen Capture filter,0x00200000,0,1,wmesrcwp.dll,9.00.0000.2926
LAV Splitter Source,0x00400001,0,1,LAVSplitter.ax,0.40.0000.0000
ROXIO Video VCFLooper 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Sonic Cinemaster® VideoDecoder 4.3 (Game1X),0x005ffffe,2,2,CinemasterVideo.DLL,4.03.0001.0280
Roxio Transport Stream Source,0x00000000,0,0,,
ROXIO VCFHDVSceneDetect 1.0,0x00200000,2,1,,
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
ROXIO QT Source,0x00200000,0,1,RoxVideo.ax,1.00.0000.0057
roxio DCFilters Audio Sync Filter 2,0x00000000,0,0,,
ROXIO Sewer 3.0,0x00200000,1,0,MVWcDSutil.dll,1.00.0000.0057
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
ROXIO MKV Splitter,0x00200000,1,1,RoxMkvSplitter.ax,8.00.0000.0047
Nero VMR Modules Filter,0x00200000,1,0,NeroVMRModules.dll,5.05.0027.0000
Roxio Plasma CrossGraph Renderer,0x00200000,1,0,PlasmaCGFilter.ax,1.00.0000.0057
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
ROXIO MKV Source,0x00200000,0,0,RoxMkvSplitter.ax,8.00.0000.0047
ROXIO Field Combiner 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7601.17713
Roxio MPEG1 Muxer,0x00000000,0,0,,
ROXIO LPCMSyncFilter,0x00000000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
ULead MPEG Splitter,0x00400002,1,2,ulspmpeg.ax,1.00.0000.0035
ULead MPEG Audio Decoder,0x00400000,1,1,uldsmpeg.ax,1.00.0000.0052
ULead MPEG Video Decoder,0x00400000,1,1,uldsmpeg.ax,1.00.0000.0052
ULead MPEG Encoder,0x00200000,2,1,ulesmpeg.ax,1.00.0002.0009
ULead MPEG Muxer,0x00200000,3,1,ulmxmpeg.ax,1.00.0001.0021
VCG Video Mixer 3.0,0x00200000,0,1,VideoCompositing.ax,1.00.0000.0057
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
DivX Demux 0001,0x00600001,1,0,DivXDemux.ax,8.00.0000.0002
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,5.05.0027.0000
ROXIO Image/Colour Source 3.0,0x00200000,0,1,RoxVideo.ax,1.00.0000.0057
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,5.05.0027.0000
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,5.05.0027.0000
Half Size to Stereo,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Sonic HD Demuxer,0x005ffffe,1,2,SonicHDDemuxer.dll,4.03.0000.0134
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.01.4070.0000
Video Source,0x00200000,0,1,wmprevu.dll,9.00.0000.2926
Roxio Audio Stream Writer Filter,0x00000000,0,0,,
Roxio MPEG2 Demuxer,0x00000000,0,0,,
Roxio File Writer Wrapper,0x00200000,1,0,RoxFileWriterWrapper.ax,1.00.0000.0057
ATI Video Rotation Filter,0x00200000,1,1,atimpenc.dll,12.04.0000.20405
Media Analyser,0x00200000,1,2,mediaanalyser.ax,1.00.0000.0057
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
RealMedia Splitter,0x00400000,1,1,RealMediaDX.ax,1.00.0001.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
Roxio Mp3 Encoder (SC),0x00000000,0,0,,
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,5.05.0027.0000
Sonic Color Space Converter,0x00600000,1,1,roxio86_trans_video_colorspace_sb_ds.ax,8.05 .0000.0000
DivX ReSync 0001,0x00200000,2,2,ReSync.ax,8.00.0000.0002
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
DivX Subtitle Decoder 0001,0x00600000,1,1,DivXSubDec.ax,8.00.0000.0001
LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.40.0000.0000
ROXIO VCFDvrSupport 3.0,0x00200000,1,1,DvrSupportFilt.ax,1.00.0000.0057
LAV Video Decoder,0x00800003,1,1,LAVVideo.ax,0.40.0000.0000
Haali Video Sink,0x00200000,1,0,splitter.ax,1.11.0288.0000
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,5.05.0027.0000
LVMWriter,0x00200000,1,0,LVMWriter.ax,1.00.0000.0057
Roxio FLV Video Decoder,0x00800000,1,1,RoxFLVDecoder.ax,1.00.0000.0057
ROXIO VideoInfo Transcoder 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
ROXIO VCFVideoCutList 3.0,0x00200000,1,1,RoxVideo.ax,1.00.0000.0057
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
Nero Video Decoder,0x00600000,2,1,NeVideo.ax,5.05.0027.0000
ROXIO CrossGraphEx Renderer 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
ROXIO ListImage Source 3.0,0x00200000,0,1,RoxVideo.ax,1.00.0000.0057
Audio Buffer Render,0x00200000,1,0,AudioDF.ax,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,5.05.0027.0000
Sonic MP4 Demultiplexer,0x00200000,1,2,roxio86_demux_mp4_ds.ax,8.05.0000.28926
ROXIO ThumbnailGrabber 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
ROXIO VideoCombine 3.0,0x00200000,1,0,RoxVideo.ax,1.00.0000.0057
Sony MPEG2 TS Splitter,0x00600002,1,2,tssplt.ax,1.00.0000.4202
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.01.4070.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Panasonic DV CODEC,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Huffyuv v2.1.1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Helix I420 YUV Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Lossless RGBA compression,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Windows Media Video 9,0x00200000,1,1,qcap.dll,6.06.7601.17514
Xfire Video Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Xvid MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Helix YV12 YUV Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.06.7601.17713
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.06.7601.17713
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.06.7601.17713
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.06.7601.17713
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
{6A08CF80-0E18-11CF-A24D-0020AFD79767},0x00200000,1,1,quartz.dll,6.06. 7601.17713
DivX ;-) Audio,0x00200000,1,1,quartz.dll,6.06.7601.17713
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
DV Audio -- NTSC,0x00200000,1,1,quartz.dll,6.06.7601.17713
DV Audio -- PAL,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
AC-3 ACM Codec,0x00200000,1,1,quartz.dll,6.06.7601.17713
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
Audio Capture Sources:
Microphone (2- High Definition ,0x00200000,0,0,qcap.dll,6.06.7601.17514
Line (Roxio GAMECAP),0x00200000,0,0,qcap.dll,6.06.7601.17514
Line In (2- High Definition Aud,0x00200000,0,0,qcap.dll,6.06.7601.17514
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
WDM Streaming Capture Devices:
HD Audio Microphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio Mixed capture,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Roxio GAMECAP,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Roxio GAMECAP Capture,0x00200000,1,0,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
HD Audio Headphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio Speaker,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Audio SPDIF out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
WDM Streaming Crossbar Devices:
Roxio GAMECAP Crossbar,0x00200000,7,2,,6.01.7601.17514
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
WDM Streaming Communication Transforms:
Audio Renderers:
Speakers (2- High Definition Au,0x00200000,1,0,quartz.dll,6.06.7601.17713
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
Digital Audio (S/PDIF) (2- High,0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Digital Audio (S/PDIF) (2- High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Headphones (2- High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
DirectSound: Speakers (2- High Definition Audio Device),0x00200000,1,0,quartz.dll,6.06.7601.17713
Headphones (2- High Definition ,0x00200000,1,0,quartz.dll,6.06.7601.17713
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Also few of my about:crashes
bp-6c695b2f-b197-4665-b724-c035821206226/21/20124:06 PM
59bfb7fe-7af4-4ade-8b42-fcbcbe5bc8946/21/20124:05 PM
587d7dca-4475-466d-934b-28ec45e788106/21/20124:05 PM
http://crash-stats.mozilla.com/report/index/bp-6c695b2f-b197-4665-b724 -c03582120622
The rest say they are not reported for throttling in link below.
Was this problem never solved? I'm having the exact same issue, flash player freezes in chrome after a few seconds of a video playing. SUPER ANNOYING.
Tried uninstalling flash and installing and it didn't work. Currently using google chrome (can try with other browsers but don't think it will matter). Disabling hardware acceleration doesn't help either.
We'd be happy to investigate, but we need some actionable details.
Please give us the output of dxdiag.exe
Go to start > run > dxdiag
Save the output to a file
Post the details here, or give us a link to dropbox or something.
Let us know what Flash Player version you're using.
(Right click on Flash content and you'll see the version in the context menu)
Also, please provdie a direct link to a video or videos that exhibit the problem.
