xxxyytim
auto-collapse not working
Jun 20, 2012 5:22 AM
Tags: #auto-collapse
It appears that the auro-collapse panels function is not working in CS5.5. If I right click on the panels and select the auto-collapse feature then when the panel is open and I click anywhere outside the panel it should automatically close. It does not do that. Any suggestions?
    Jun 20, 2012 1:17 PM   in reply to xxxyytim
    Auto-Collapse is not available in all products.
    In some products, if you select Auto-Collapse Icon Panels from the Interface or User Interface Options preferences, an expanded panel icon collapses automatically when you click away from it.
    Set General Preferences for Dreamweaver
    http://help.adobe.com/en_US/dreamweaver/cs/using/WScbb6b82af5544594822 510a94ae8d65-7f82a.html#WScbb6b82af5544594822510a94ae8d65-7f71a
    Nancy O.
    Jun 20, 2012 5:52 PM   in reply to xxxyytim
    Definitely works here on Win 7.
    I put the panels into Icon mode (auto-hide mode switched on) and whichever panel is open auto-hides when I click elsewhere.
    Jun 21, 2012 1:13 PM   in reply to xxxyytim
    xxxyytim wrote:
    Folks.....I have discovered the problem! If you have Dreamweaver operating on an extended display the function will not work. If you drag Dreamweaver back onto your main display this feature will work!
    Still works here on dual monitor setup.
    Can you provide an exact set of steps so we can reliably re-produce what you're seeing?
    xxxyytim wrote:
    Does anyone know how to contact Adobe to get this obvious flaw fixed?
    The most direct way is via the official Feature Request/Bug Report form
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
