Does anyone know how can I get a numerical pdf form field to validate within a range as well as validate that the value is equal to or less than the value of another numerical field?
The min is 0 and max is 2,000,000
The other field will need to have a numerical value (can't be blank if they want to use the 2nd field) - it has no max, so I guess the order of the validation would be the 2,000,000 max after the equal or less than the 1st field? I'm not great at javascript, so don't know how to format this at all!
If you can help at all, that would be great.
I think the following custom Validate script will do what you want:
function range_validate1() {
// Do nothing if field is blank
if (!event.value) {
return;
// Initialize some variables
var sError = "";
var nMin = 0;
var nMax2 = 2e6;
var nVal = +event.value; // Value user entered, converted to a number
// Get the other field value, converted to a number
var nMax1 = +getField("Text1").value;
// If the value is less than the minimum
if (nVal < nMin) {
sError = "Please enter a value greater than or equal to: " + nMin;
// If value exceeds the other field value...
if (nVal > nMax1) {
sError = "Please enter a value less than or equal to: " + nMax1;
// If value exceeds the max. possible value
if (nVal > nMax2) {
sError = "Please enter a value less than or equal to: " + nMax2;
// Alert the user and reject the value
if (sError) {
app.alert(sError, 0);
event.rc = false;
// Call the function
range_validate1();
The function can be placed in a document-level JavaScript, but the last line should be the custom Validate script for the field. Replace "Text1" in the line containing the getField statement to the actual name of the other field.
