I have Adobe Digital Editions on my computer and have been able to load books from my library on to my nook and nookcolor. I recently purchased the Samsung Galaxy Tab 10.1 and tried to load a book I just got from the library on ADE but ADE does not recognize the Galaxy Tab as a device. It doesn't show up at all in the library. I've checked the files on the Tab as reccommended by another post on this site. The Adobe Digital Editions file is not on the Tab.
The supported devices list shows only 'Galaxy Tab' with Android OS (here
<http://blogs.adobe.com/digitalpublishing/supported-devices> is the list),
which may mean that the latest version is not supported yet - or not....
Pardon me if you know all of the rest of this - I have no way of knowing
whether you do, and I am trying to help.
It probably is supported, so I would suspect that there's something wrong
with the setup. You didn't say whether you've registered the Galaxy with
its parent, but the fact that ADE files are missing from the device is a
clue that you may not have done so yet. You need to do that to activate it
so that it'll work with ADE. When you do the registration, you'll be asked
for a user ID: use your Adobe user ID and password so that it'll be
compatible with ADE.
Given all that, then you need to follow a particular sequence in order to
establish contact all the way around. Plug in your tablet to your computer,
and turn it on. Windows should recognize it as a USB hard drive, and tell
you that it's connected, ready to use. Once that's done, then open ADE.
ADE should recognize the tablet and show it in the bookshelf list in Library
view. If it doesn't, ADE may ask you to activate the device, which you can
do with your Adobe ID, and then it will show up (unless something screws up,
naturally).
Now, check the digital rights for the library book. You can do this in ADE
Library view by resting your cursor on the book cover or avatar. A small
arrow will appear at the top. Rest your cursor on that arrow, and you'll
see a drop-down box. Click on that box, and you'll see the digital rights.
SOME library books cannot be transferred to an ereader (which seems a bit
silly, doesn't it?). If copying is allowed to any device, then go back to
Library mode, drag and drop the ebook onto your now visible Galaxy Tablet.
Hope this helps!
I should have given you a bit more detail. Sorry - who knew?
I don't have a Galaxy, but I 'assume' that it has some setup instructions
that came with it, and one of those is to go on-line to Samsung and register
the device with them. Part of that process will include setting up apps.
The ebook app connects you to the Google bookstore, where you'll probably
have to set up an account with a user ID and password. A small file will be
put on the tablet with that information, which ADE will use to interface
with your tablet.
I don't have a Galaxy, but when I went through this process with SONY, at
one point they asked me whether I wanted SONY to handle epub files, and I
said no, because I was going to use ADE. You might encounter the same thing
with Google - or not. i think the reason they asked is that they wanted to
set up a proprietary linkage with my ereader, which would have bound me to
their ebookstore for all of my downloads.
Hope this helps!
I did register the product with Samsung, which was a
weird ordeal in itself. Their online registration process wasn't working so I had to
call in and they couldn't even do it. I had to wait for them to correct the web-site registration page for the Galaxy Tab 10.1 Wifi only. Just a huge hassle from the begging.
It didn't include any process for setting up apps a all. Now I'm beginning to wonder about the regisration process again![]()
I think it does have Google books on it. Maybe that's causing some glitch. I'm going to load another e-book program and see if it makes any difference.
Thank you for all your help.
