Devoth
Incorrect 960 column grid in Adobe Proto
Jun 21, 2012 5:08 AM
Tags: #ipad #columns #grid #adobe_proto #offset #960
Hi guys.
== Incorrect 16 column grid ==
When I create a new document in Adobe Proto and choose template Web Layout (960px) and set the number of columns to 16 and Gutter Space to 20, at the top of the popup it says:
Column Width: 59 pixels Margin Width: 20 pixels
Which is incorrect, it should generate a 60 pixel column:
Column Width: 60 pixels Margin Width: 20 pixels
== Incorrect 12 column grid when reentered ==
Also when I create a new document in Adobe Proto the default template parameters are: Template Web Layout (960px), # of Columns 12, Gutter Space 20. Which results in Column Width: 60 pixels Margin Width: 10 pixels.
So far so good, but if I change # of columns to whatever and then come back to 12, i get the following result: Column Width: 59 pixels Margin Width: 10 pixels
Both of errors described above result in a broken column snapping (columns aren't aligned with the grid).
Hope you can fix this.
Cheers
Lukasz
    Aug 1, 2012 10:31 PM   in reply to Devoth
    Hi Lukasz,
    - Are you working on an iPad or Android tablet?
    - What version of Proto are you using?
    Thanks for posting.
    -Dave
