Gman434
Error -54. Can't save the illustration. (very annoying)
Jun 21, 2012 6:14 AM
Tags: #illustrator #problem #adobe #bug #cs6
I get the following error multiple times a day:
Can’t save the illustration. The file may be read only, or the file is in use by another application, or you do not have the required permissions. Please save the document with a different name, or in a different folder or directory. -54
Sometimes I will work on a file for an hour before this erorr will randomly show up, but when it does I can no longer save the file unless I Save As or Save As Copy. This is frustrating. Does anyone have any idea what the issue could be? I have been unable to isolate a single action that might be causing this.
This is completely new for me. I have never ran into this error before. I'm running Windows 7 and saving locally to an internal hard drive with no other users. I am running Illustrator as an "administrator."
    Jun 21, 2012 7:38 AM   in reply to Gman434
    Are you editing a PDF and viewing that in Acrobat at the same time.
    If Not
    • Click Start ORB, in the Search Field, type secpol.msc, and then press ENTER.
    • Double-click Local Policies.
    • Double-click User Rights Assignment.
    • Double-click Back up Files and directories.
    • Click Add, and then double-click the Local Administrators group
    • Click OK.
    Jun 21, 2012 9:15 AM   in reply to Gman434
    What OS are you using? I'm betting you are saving to a network share and are having time sync problems between your computer and the network.
    Jun 21, 2012 9:27 AM   in reply to Gman434
    Some process ahold of your then, but which ojne hmmmm? Try chekcing the task manager, or download
    http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
    Did this problem just start recently, then go back to a system restore point.
