I think that what you have is a text layer. The layer should look like this in your Layers panel if it is:
When you crop your image, the text bounding box doesn't crop (see below). You should just be able to drag the bounding box (the dashed line) back into the boundaries of your image.
EDIT: Same thing happens with Shape Layers.
No it is not a text layer, do not confused by the "coming up". Here is the image from the layers panel.
The red arrow points to the layer I want to crop, AND it above the text layer.
What I must add is the fact that the layer I wish to crop, before, I had used a shape to "subtract from it" a part.
Maybe this is what is preventing the crop operation. Here is another image:
This "egg" path above falls outside the canvas and this is what I want to remove by using the crop operation-croping that right part of the rectangle shape-it has curve there cause of the fact I used the subtraction feature.
P.S Sorry for the delayed response
Message was edited by: JimVag1947
