I'm trying to outline an image. In photoshop, I did find edges (save), then opened the image in illustrator and did image trace. I obtained a perfectly outlined image.
The problem: I can't obtain the same results using illustrator image trace alone.
I've adjusted the advance settings a few times to get the same result but with no luck. Threshhold and corner settings are ok, but I'm getting more paths and noise than I want, with the settings at low/1 respectively.
I also tried the gray scale setting since the image is mostly gray, expand, etc, but no dice).
Can you help? ![]()
The top donut-like shape is your original image, correct?
Hm...since you're not getting the results you want with Image Trace, I would try another approach. I don't usually use Image Trace alone since it isn't a perfect translation to vector. It can be very touchy with some images, this one being among them apparently.
Since it's a pretty simple shape, I would just manually trace it using the pen tool. That way you could also get that middle section filled with gray, and have a lot more control over how your image is traced. It will take a longer time however, so you might just want to stick with your Photoshop to Image Trace technique.
Hi Jholland83
Have you tried the following combination in Image Trace panel :-->
1) Trace the image with "Outline" preset
2) Increase the number of paths and corners to 100%
3) Reduce the "Noise" to 1px
4) Now try to increase the "Threshold" value
Maybe you can be nearer to your desired result.
~MBM
