I have sucessfully rolled out Flash 228 via Group Policy with the MSI package. That worked a treat. I also pushed out the mms file.
AutoUpdateDisable=0
SilentAutoUpdateEnable=1
AutoUpdateInterval=0
The issue I have is, it isn't updating. The update service has been installed, but not schedule task has been made.
Anyone got any ideas?
Best wishes
Michael
Hi Michael,
I'd be happy to help look into this. Can you post your Flash installer log?
Where do I find the Flash Player installation log on Windows?
Chris
Hi Chris,
Here is the log file.
https://dl.dropbox.com/u/262417/FlashInstall.log
Best wishes
Michael
i have a similar problem. I installed the 32bit version 11.2.202.228 on a win 7 64bit OS.
The mms.cfg contains:
AutoUpdateDisable=0
SilentAutoUpdateVerboseLogging=1
But flashplayer won't update on its own. The Flashinstall.log shows this:
=O====== M/11.2.202.228 2012-05-31+08-06-41.359 ========
0000 [I] 00000010 "C:\Users\Test\AppData\Local\Temp\InstallPlugin.exe" -install -msi
0001 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0002 [W] 00001036 Software\Opera Software/Last CommandLine 2
0003 [W] 00001036 Software\Opera Software/Last CommandLine 2
0004 [W] 00001036 Software\Opera Software/Plugin Path 2
0005 [W] 00001036 Software\Opera Software/Plugin Path 2
0006 [I] 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_2_202_228.dll
0007 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_Plugin.ex e
0008 [I] 00000017 C:\Windows\SysWOW64\Macromed\Flash
0009 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0011 [W] 00001102
0012 [W] 00001106
=X====== M/11.2.202.228 2012-05-31+08-06-44.124 ========
=O====== M/11.2.202.228 2012-05-31+08-07-37.606 ========
0000 [I] 00000010 "C:\Users\Test\AppData\Local\Temp\InstallAX.exe" -install -msi
0001 [W] 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 [I] 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 [I] 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_2_202_228.ocx
0004 [I] 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.e xe
0005 [I] 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_2_202_228_ActiveX.d ll
0006 [I] 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0007 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl 183
0008 [W] 00001024 C:\Windows\SysWOW64\FlashPlayerApp.exe 183
0009 [I] 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0010 [W] 00001106
0011 [W] 00001106
0012 [W] 00001024 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe 183
=X====== M/11.2.202.228 2012-05-31+08-07-42.418 ========
2012-6-1+6-11-5.777 [info] 1614
2012-6-1+6-11-11.652 [info] 1615
2012-6-1+6-11-11.824 [info] 1618
2012-6-1+6-11-11.839 [info] 1619 1063
2012-6-1+6-11-11.871 [info] 1614
2012-6-1+6-11-11.871 [info] 1615
2012-6-1+6-11-11.871 [info] 1618
2012-6-1+6-11-11.886 [info] 1608
2012-6-1+6-11-11.886 [info] 1604
2012-6-1+6-11-11.949 [warning] 1403 12007
2012-6-1+6-11-11.996 [warning] 1407 183
2012-6-1+6-11-11.996 [warning] 1408
2012-6-1+6-11-13.402 [info] 1626
2012-6-1+6-11-13.417 [info] 1612
2012-6-1+6-11-13.417 [info] 1621
2012-6-1+6-11-13.417 [info] 1620
2012-6-1+7-11-8.362 [info] 1614
2012-6-1+7-11-10.3 [info] 1615
2012-6-1+7-11-10.284 [info] 1618
2012-6-1+7-11-10.503 [info] 1619 1063
2012-6-1+7-11-11.393 [info] 1614
2012-6-1+7-11-11.393 [info] 1615
2012-6-1+7-11-11.393 [info] 1618
2012-6-1+7-11-11.393 [info] 1608
2012-6-1+7-11-11.425 [warning] 1403 12007
2012-6-1+7-11-11.425 [warning] 1407 183
2012-6-1+7-11-11.425 [warning] 1408
2012-6-1+7-11-11.925 [info] 1604
2012-6-1+7-11-14.831 [info] 1626
2012-6-1+7-11-14.831 [info] 1612
2012-6-1+7-11-14.846 [info] 1621
2012-6-1+7-11-14.846 [info] 1620
Any Ideas?
Martin
Hi Stephen,
Here you go - https://dl.dropbox.com/u/262417/FlashInstall.log
I also noticed that their is an MMS in the 64 bit folder as well. It reads
AutoUpdateDisable=0
AutoupdateDisable=0
SilentAutoUpdateEnable=0
This isn't the mms.cfg that my Group Policy pushed out.
https://dl.dropbox.com/u/262417/gp.png
Best wishes
Michael
Hi Martin,
Your log shows that the Background Updater is successfully starting up and attempting to check for updates. However, your system doesn't seem to be able to connect to Adobe's backend. Please make sure that you permit connections to port 80 on fpdownload2.macromedia.com and port 443 on fpdownload.macromedia.com.
To run a quick check, please open a web browser and try connecting to the following URLs:
https://fpdownload.macromedia.com/pub/flashplayer/update/current/sau/1 1/xml/version.xml
If you want to continue restricting access to these ports/domains, you might want to consider hosting updates to Flash Player on your internal network instead. You can refer to my blog post here for instructions on how to set this up.
-Stephen
Hi Michael,
On a 64-bit Windows system, you will want to place your mms.cfg file in:
An mms.cfg file that is placed in C:\Windows\System32\Macromed\Flash will be ignored on 64-bit Windows. If there is one there, feel free to remove it to avoid confusion in the future. It has no bearing on the installers, updaters, or Flash Player itself. Only on 32-bit Windows systems will the mms.cfg be placed in C:\Windows\System32\Macromed\Flash.
Your log shows that you successfully connected to the Adobe backend and that the Background Updater attempted to download the updates. However, the download and verification of the updates failed. Please make sure that you can connect to the following URLs from a web browser on the affected system (and that you don't get a 404 or similar error):
-Stephen
Hi Stephen,
I had to reboot this morning and on reboot Flash opened to say an upgrade we available. I declined. You can get the logs from the link below. I have included 32 and 64 bit. I renamed them so you know which is which.
https://dl.dropbox.com/u/262417/Archive.zip
Cheers
Michael
Hi Michael,
This seems to be due to the fact that the release of 11.3 was a scheduled release. For scheduled releases, the current Adobe policy intends to notify users of the update for a period of time (currently 30 days) before updating automatically. More info can be found here: http://helpx.adobe.com/flash-player/kb/flash-player-background-updates .html
-Stephen
