Bavix
Separations
Feb 15, 2012 12:14 AM
Hello,
I'm trying to print color separations as a Postscript file from Illustrator CS5 and the halftone areas keep showing up as grayscale instead of the specified frequency and angle. I've tried usiing multiple PPDs and options but I'm having no luck.
Bavix
    Feb 15, 2012 3:52 AM   in reply to Bavix
    Not sure what you are saying here. A separation is for all intents and purposes just a greyscale representation of the ink's intensity/ saturation and distribution on the plate. The actual rasterization is applied by whatever is interporeting the file on the other end, i.e. a RIP hardware/ printer. If the printer supports custom screening angles, it will read the meta info attached to the objects and rasterize them accordingly, if noit, it will simply use its default screen.
    Mylenium
    Feb 15, 2012 7:39 AM   in reply to Bavix
    Sounds like you were expecting to get each seperation in it's respective color not in grayscale. The tags are still there for color information, so there is nothing wrong with your separations being in grayscale, sounds like you are having trouble with controlling the angle.
    Something has changed in either how you are viewing you PS files, or how you are creating them.
    How are you previewing the PS files? On the scitex for example you could preview seperation in either grayscale or their own channel, there was a settign to change. really helped on yellow plates which  are hard to see against white.
    How exactly are you making your PDFs, need to be able to trace your exact steps?
    Jun 21, 2012 10:20 AM   in reply to Bavix
    I'm having this exact same problem. I'm on a Mac running Lion (OS 10.7.4), working in Adobe Illustrator CS5, and trying to print color seps to our Epson Stylus Pro 9900. Since I can no longer print to PDF (as with older versions of Illustrator), I print to Adobe PostScript File using my Epson 9900 PPD. I then select Output on the left-hand sidebar menu, which gives me the list of inks available to print. I'm outputting positive film for tshirt screen printing, so for the ink I need I'm setting the Frequency to 40 and the Angle to 17.5. I then save the postscript file, put it through Distiller, and print to the Epson from the resulting PDF.
    When the film is finally out (this is a lot of time and too many steps, IMHO), the screened areas of ink are not halftone dots, they are solid greys. This means that the Frequency and Angle settings I input for the postscript file were ignored when printed. Is this a PPD issue? A driver issue? An Illustrator issue? An operating system issue?
    HELP!!
    Jun 21, 2012 10:27 AM   in reply to rc@luxyachts.com
    What happens if you Save a PDF directly from AI, open the result in Acrobat and do your seperations from there?
    Jun 21, 2012 10:41 AM   in reply to Larry G. Schneider
    If I Save As a PDF file from Illustrator and then open in Acrobat Pro, I can't print seps and I can't change screen frequency or angles.
    Jun 21, 2012 10:58 AM   in reply to rc@luxyachts.com
    So you can't use this
    when printing from Acrobat?
    Jun 21, 2012 11:29 AM   in reply to Larry G. Schneider
    Nope. No option for seps in my dialog box series...Print_Dialog_optionsjpg.jpg
    Jun 21, 2012 11:59 AM   in reply to rc@luxyachts.com
    Do you have any RIP software for this printer? I looked at the literature and can't seem to find out if this printer has PS3 support.
    Jun 21, 2012 12:32 PM   in reply to Larry G. Schneider
    No, we have no RIP software. Never needed it until the CS5 + Mac OS 10.7.4 combo came along. I'm trying to figure out whether I can expect Adobe to release an updated PPD that will fix this, or whether now I have to go buy RIP software because Illustrator no longer functions as it did previously.
    Jun 21, 2012 12:43 PM   in reply to rc@luxyachts.com
    OK, let's try this. From AI do Print> and then select the Printer button in the lower left. When the new dialog comes up is there a PDF button in the lower left of that dialog. If there is, then do you have the option shown here. This has replaced the old print to PDF in OSX10.6x and 10.7.x.
    Jun 21, 2012 1:12 PM   in reply to Larry G. Schneider
    When I use that method and try to save as a PDF, I get "The Save as PDF options in the Printer dialog are not supported." I can save as a postscript file by that method, but I can do that right from the main print dialog box. :-(
    Dec 7, 2012 8:49 AM   in reply to rc@luxyachts.com
    I've been trying to figure out this same issue. Have you figured anything out since you first started this post?
    Dec 18, 2012 12:53 PM   in reply to Z_Print_41
    No news on my end. I'm calling Adobe support again and will post if I get any good news, such as, "We heard you and made a new PPD - download it here!" This is maddening. Not an issue on PCs, of all things.
