veradelisa
WaterMark ?
Jun 21, 2012 11:18 AM
I cannot get the watermark to show up in LightRoom4 once I export the photo. I can see it in preview but them it disappears when I export photo. Need some help. Thanks!
    Jun 21, 2012 11:49 AM   in reply to veradelisa
    The watermark will appear only on your exported photo (the derivative, if you will). It will not show up on the original photo.  The derivative is not added back into your Lightroom catalog unless you expressly tell it to be (not a great idea) in the Export dialog.
    Which photo, original or the derivative (exported) version are you viewing when you say you cannot see the watermark?
    Jun 21, 2012 11:51 AM   in reply to veradelisa
    Did you check the box at <Watermarking> in the Export Dialog?
    In the drop-down menu you have to select the watermark you wish to apply.
    Jun 21, 2012 1:17 PM   in reply to veradelisa
    If you are using the Simple Watermark in the selection pulldown, it requires that the Copyright field in the metadata have information in it. If it doesn't the watermark will be blank.
    Also if you are using the Simple Watermark, it is a fixed pixel size. Meaning if your export is a large pixel dimensoin 4000x3000 for example, it may be there but be too small to read in the lower left corner.
    No features are disabled in the 30 day trial.
    Jun 21, 2012 1:46 PM   in reply to veradelisa
    Or it may be that you've run into the Watermark bug which I believe still shows up in LR4.
    Put as simply as I can, this bug (i.e. watermark not appearing on exported files) can be encountered when using certain fonts only (Lucida Calligraphy is one), and even then it depends upon a combination of the Proportional Size (set in the Watermark Effects box in the Edit Watermarks dialog) and the pixel dimensions which are set for the exported file. Somewhat oddly, the larger the export pixel dimensions, the greater the chance that the bug will bite.
    As a test, using your preferred font, try setting both the Proportional Size and the Export size to low values.....if the watermark then appears you'll at least have pinned down the problem, in which case your workaround options would be:
    1. Try a different font.
    2. Play around with the Proportional Size/Export pixel size to try to find an acceptable combination.
    Jun 22, 2012 5:55 AM   in reply to veradelisa
    Are you using the Simple Watermark, or custom creating one in the Watermark Editor?
    Jun 22, 2012 7:55 AM   in reply to veradelisa
    Text-based watermark or Graphic? Can you post a screen shot of your Export Dialog watermark section and your Watermark Editor showing the good preview?
    Jun 22, 2012 11:06 AM   in reply to veradelisa
    Help!!!  I am having a  watermark problem as well.  Simple watermark works, my custom watermark wich worked fine in LR 3 and seems to still exist in LR4 does not appear.  It is a .png.  Is this a bug?  Is there a workaround?  Thanks for any help!
    Jun 22, 2012 11:55 AM   in reply to veradelisa
    Does changing to a different font affect it?
    Jun 23, 2012 12:18 AM   in reply to veradelisa
    In which case we really need to see the screenshots that Rikk asked for, This post will explain how to take the screenshots, to attach them to your reply simply click on the camera icon at the top of the reply box then point to the location of the screenshot:
    http://www.lightroomforums.net/showthread.php?14018-How-to-take-a-quot -screenshot-quot-on-Windows-or-Mac-computers
    Jun 25, 2012 1:44 AM   in reply to veradelisa
    Did you not read my earlier post (#5)? This is exactly the bug that I described (I even mentioned Lucida Calligraphy as a known problem font). A quick bit of testing shows that, when using Lucida Calligraphy, the "Proportional Size" needs to be reduced down to 8 in order for the Watermark to be included on an export file size of 4592 pixel width. As this is likely unacceptable, you could maybe think about downsizing on export....but as you'd need to halve the long edge to about 2300 pixels in order to retain 17 as the Proportional Size, that also may not be acceptable. If you experiment you may find a more acceptable combination of Proportional Size and Export Size.....
    But if not, you may need to find a different font.
    Jun 30, 2012 1:15 PM   in reply to veradelisa
    I am having the exact same problem, and with a custom logo. It worked just fine in 3, and all other versions of LR, but in 4, it is a no-go, no matter what logo I use.
    I have seen some reports of 'bugs' in the watermarking portion of LR4, do we know anything more about this?
    I am currently using the 'trial' of 4 to see if it's worth the purchase, but this is a pretty big issue, as I am a professional, and if I can't watermark, or have to go to the trouble of editing in 4, then watermarking in 3, I just won't do it.
