in a Php document path to a class specified with a string resolved without a problem:
require_once ( './classes/class.php' );
However, if a defined variable is used, the path does not resolve and Dreamweaver doesn't help with method hints:
define ( CLASS_DIR . './classes/' );
require_once ( CLASS_DIR . 'class.php' );
As a note, CLASS_DIR might not be defined in the same document, bu linked from another one that contains the define:
require_once ( './config.php' ); //contains define ( CLASS_DIR . './classes/' );
As I use defined paths, I can take no advantage of Dreamweaver's hints.
