AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
Nov 25, 2009 2:44 PM
  Latest reply: Maretine, Jun 21, 2012 7:32 PM
Replies 1 2 Previous Next
    Nov 10, 2011 8:36 AM   in reply to james.g.taylor
    VB6 is not supported with Reader X.
    From: Adobe Forums <forums@adobe.com<mailto:forums@adobe.com>>
    Reply-To: "jive-1134247383-8igo-2-2e4on@mail.forums.adobe.com<mailto:jive-1134247383-8igo-2-2e4on@mail.forums.adobe.com>" <jive-1134247383-8igo-2-2e4on@mail.forums.adobe.com<mailto:jive-1134247383-8igo-2-2e4on@mail.forums.adobe.com>>
    Date: Thu, 10 Nov 2011 08:19:16 -0800
    To: Leonard Rosenthol <lrosenth@adobe.com<mailto:lrosenth@adobe.com>>
    Subject: Re: AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7 AccessViolationException fatal error, Acrobat 9, AxAcroPDFLib, .NET, Win7
    created by james.g.taylor<http://forums.adobe.com/people/james.g.taylor> in Acrobat SDK - View the full discussion<http://forums.adobe.com/message/4018487#4018487
    Jun 21, 2012 6:24 PM   in reply to lrosenth
    And Adobe continues to fail and/or refuse to resolve this issue even for those of us using .NET which IS supposedly supported.
    -- Edited to remove email sig.
    Dec 22, 2011 7:29 AM   in reply to AccessViolationException
    Here is a workaround for WPF with .NEt 3.5 and Reader X :
    add In "Window_Loaded" :
    ComponentDispatcher.ThreadFilterMessage += new ThreadMessageEventHandler(ComponentDispatcher_ThreadFilterMessage);
    private void ComponentDispatcher_ThreadFilterMessage(ref MSG msg, ref bool handled)
        if (msg.message == 0x1450)
            handled = true;
    H.M
    Jan 26, 2012 7:59 AM   in reply to Maretine
    As a workaround in VBA, I used the Microsoft Web Browser control instead of the Adobe Read Control.  It loaded the exact same interface, but didn't crash when you press TAB.
    Jan 26, 2012 8:19 AM   in reply to BrianHribek
    Hey Brian,
    I have tried this in the past, but cannot figure out how to access the control's routines through the web browser component to configure the viewer's options.
    Any help is appreciated.
    Thank you,
    - Dustin Buschow
    Jan 26, 2012 9:17 AM   in reply to DBuschow
    Dustin,
    I am only opening the PDF for viewing and possibly printing, so I'm not using any of the other specific PDF control routines you are probably interested in.
    Sorry I couldn't be of more help.
    -Brian
    Jan 30, 2012 6:30 PM   in reply to DBuschow
    Hi Dustin,
    You could probably use Parameters for openning PDF Files in your case. On the last page of the document they describe how to encode the parameters into the URL
    aucha
    Mar 7, 2012 5:21 AM   in reply to AccessViolationException
    Microsoft Web Browser control instead of the Adobe Read Control and  loaded the exact same interface alose tab not use it crashed
    ukash
    ukash kart
    Mar 7, 2012 6:25 AM   in reply to kaozci
    Sorry Kaozci but this workaround is not so helpful. This workaround is known. This is an old problem that has no solution even with the newest release of acrobat.
    Mar 20, 2012 4:47 PM   in reply to aucha
    The parameters work great.  The thing is that I still need to have an easier way for the user to print the document from GUI in the parent application.  Is there a way to reference the PDF and have it open the print dialog using something like javascript?  Or even better, an undocumented parameter to open the print diaglog prompt?
    Mar 20, 2012 5:06 PM   in reply to DBuschow
    Yes you can. See this document. However, next time please start a new thread rather than asking off-topic questions.
    Jun 8, 2012 3:41 PM   in reply to DBuschow
    yes I agree thank you dbuschow ukash ukash kart
    Jun 21, 2012 12:43 PM   in reply to AccessViolationException
    For any that need a fix for this in Access/VBA the solution for me was to use a low level keyboard hook. Sub classing the window proc causes all sorts of gimpy behvior in access, even a window proc that does nothing more than call the default window proc. Instead you can install a WH_KEYBOARD_LL hook and supress the tab key on the form housing the acrobat control. For some folks this will be a problem (tabbing through controls) however we personally use the pdf control on its own dialog outside the main access window so it works fine for us. I'm not sure how it affects pdf forms either, again a non-issue for us. Any how, here's the code, adapt it for your needs:
    ' Win32 Module
    Public Const WH_KEYBOARD_LL = 13
    Public Type KBDLLHOOKSTRUCT
        vkCode As Long
        scanCode As Long
        flags As Long
        Time As Long
        dwExtraInfo As Long
    End Type
    Public Declare Function SetWindowsHookEx Lib "user32" Alias "SetWindowsHookExA" (ByVal idHook As Long, ByVal lpfn As Long, ByVal hmod As Long, ByVal dwThreadId As Long) As Long
    Public Declare Function UnhookWindowsHookEx Lib "user32" (ByVal hHook As Long) As Long
    Public Declare Function CallNextHookEx Lib "user32" (ByVal hHook As Long, ByVal nCode As Long, wParam As Any, lParam As Any) As Long
    Public Declare Function GetModuleHandle Lib "kernel32" Alias "GetModuleHandleA" (ByVal lpModuleName As Any) As Long
    Public Declare Function GetActiveWindow Lib "user32.dll" () As Long
    ' Some other module
    ' Please note the keyboard hook procedure HAS to be in a module, AddressOf will not work
    ' for a function inside a form module.
    Public Property Get KeyboardHookHandle As Long
         KeyboardHookHandle = ' where ever the handle of the hook is stored
    End Property
    Public Property Let KeyboardHookHandle(val as Long)
         ' store the hook handle in global variable, in a control on a form, wherever you like....
    End Property
    ' Form_PdfViewer is the form that holds the adobe pdf viewer control
    Public Function KeyboardHook(ByVal nCode As Integer, wParam As Long, lParam As Win32.KBDLLHOOKSTRUCT) As Long
        If nCode >= 0 Then
            If lParam.vkCode = vbKeyTab And Win32.GetActiveWindow() = Form_PdfViewer.hwnd Then
                Debug.Print "Aborted tab key press!"
                DoEvents
                KeyboardHook = 1
                Exit Function
            End If
        End If
        DoEvents
        KeyboardHook = Win32.CallNextHookEx(KeyboardHookHandle, nCode, wParam, lParam)
    End Function
    ' The form housing the adobe pdf viewer control
    Private Sub Form_Load()
         KeyboardHookHandle = Win32.SetWindowsHookEx(Win32.WH_KEYBOARD_LL, AddressOf KeyboardHook, Win32.GetModuleHandle(vbNullString), 0)
    End Sub
    Private Sub Form_Unload(Cancel As Integer)
        Win32.UnhookWindowsHookEx KeyboardHookHandle
    End Sub
    Another alternative is to use the web browser control which works fine in access 2003 on windows 7 with ie9 however you can't resize the control on windows xp with access 2002 and ie8 and unfortunately we still have users with that configuration so it's not an option for us.
    Jun 21, 2012 3:02 PM   in reply to jptros
    Thanks hugely jptros, this (ignored by Adobe) bug has been annoying me for quite a while. I'd implemented a kludge to handle the tab but your solution is much better.
    I had to fiddle with it a bit to get it to work for me - in case anyone else needs it, my adjusted version is pasted below.
    ' Until Adobe get around to fixing the bug with the Tab key, have this in a stand alone module
    ' When (if) it's fixed, delete the module and remove the references in the Form_Load and Form_Unload on any forms that are referencing this code
    Option Compare Database
    Option Explicit
    ' This lot are used to hook the [TAB] key on forms showing the Acrobat PDF viewer control
    ' because of the bug in their code that causes Access to lock up.
    ' http://forums.adobe.com/thread/530591?tstart=0
        vkCode As Long
        scanCode As Long
        flags As Long
        Time As Long
        dwExtraInfo As Long
    End Type
    Dim gKeyboardHookHandle As Long
    Public Property Get KeyboardHookHandle() As Long
         KeyboardHookHandle = gKeyboardHookHandle
    End Property
    Public Property Let KeyboardHookHandle(val As Long)
    End Property
    Public Function KeyboardHook(ByVal nCode As Integer, wParam As Long, lParam As KBDLLHOOKSTRUCT) As Long
    Dim hwnd_Form_PDFViewer As Long
        ' I'm only using the PDF viewer on a single form so only care about a single hwnd
        If Screen.ActiveForm.Name = "frmDocumentArchive" Then hwnd_Form_PDFViewer = Screen.ActiveForm.hwnd
        If nCode >= 0 Then
            If lParam.vkCode = vbKeyTab And GetActiveWindow() = hwnd_Form_PDFViewer Then
                DoEvents
                KeyboardHook = 1
                Exit Function
            End If
        End If
        DoEvents
        KeyboardHook = CallNextHookEx(KeyboardHookHandle, nCode, wParam, lParam)
    End Function
    '---- From here on, these are in the form which needs the [TAB] presses to be consumed to prevent the crash.
        ' Handle the Acrobat bug
        KeyboardHookHandle = SetWindowsHookEx(WH_KEYBOARD_LL, AddressOf KeyboardHook, GetModuleHandle(vbNullString), 0)
    End Sub
        ' Clean up after handling the Acrobat bug
    End Sub
    Jun 21, 2012 4:12 PM   in reply to Maretine
    I spoke to soon.
    Maybe it's the changes I made - but this code consumes all TAB presses in all windows, not just the ones in Access... and then Access crashes when you exit the application.
    Looks like the same crash that would have occurred without this hook consuming the key presses.
    Improvement over crashing any time that Tab is pressed when the form with the reader control is open and the control is populated, but still doesn't resolve the problem.
    Ah well, rolling back to my bodgy fix.
    Jun 21, 2012 6:05 PM   in reply to Maretine
    Are you saving the hook handle? The code above doesn't seem to be, you never put anything in the body of the KeyboardHookHandle setter. That means you're not unhooking when the forms closes and when you call the CallNextHookEx function you're passing an invalid hook handle in the first parameter. Also, I've tested this code with multiple forms and it only drops tab presses on the form with the acrobat control, that's what the GetActiveWindow() = Form_FooBar.hwnd in the keyboard hook is for. The way we use the adobe reader control is to open a popup form outside of access. Tabbing between controls on other forms works fine so the GetActiveWindow() check is working fine in our application. In addition to testing I performed, I deployed this fix to a few users this afternoon and didn't hear a peep out of them for the rest of the day so it's working for us.
    Forgot to add that I've only tested this method of preventing the crash in access 2002 and 2003.
    Jun 21, 2012 6:20 PM   in reply to jptros
    I thought it was odd that there was nothing in the Get or the Let, but I have not used those so had no idea what was supposed to be done and thus left them as is.
    What should be in there?
    Jun 21, 2012 7:15 PM   in reply to Maretine
    Dim m_hookHandle as Long
       KeyboardHookHandle = m_hookHandle
    End Property
       m_hookHandle = val
    End Property
    That should get you started. The reason I didn't include a body to those properties is because some folks handle things differently. Access, if you have never noticed, will reset all variables in the event of an unhandled error. In a locked down mdb, the code silently discards the error and continues to run only now with unexpected data stored in the global variables which obviously is a pretty bad thing. I've seen folks store global variables in hidden form fields and in tables. Just depends on the person and the scenario, so I just left those properties empty. This really goes outside of the scope of the problem here, a quick google search for 'access vba variables reset' should turn up plenty of details about what happens if you don't do proper error handling in your vba projects.
    And as a result, if you don't unhook and call the next hook in the chain properly, wierd things can happen so it's important that you retain the handle returned when you set the keyboard hook until your hook has been released.
    Jun 21, 2012 7:32 PM   in reply to jptros
    Perfect, thanks hugely.
1 2 Previous Next
Actions
