Why can I not export layers to Photoshop? I need the text editable, too. Working in a multilayered .ai.
thanks
Larrry
jarnot9 has a text wrap so that is the way it has to be but what they can do if that is causing the problem is remove the tex wrap and do it the old fashionb way which is a manually layout the text to look like it is wrapped. theat is one frame for the text to the right of the linked image and another one below the image and the first text frame they can then link the frames and copy and paste the text into the first text frame and let if flow into the second one or if they prefer simply not link the text frames.
In this case two frames are better than one, perhaps.
thanks, all
1. color mode is RGB
2. linked image is a flat, rgb, jpg
3. never heard of a text frame... )looks like your grab is psd. Is that an Illustrator thing?) simple text box with text wrap (if I can't use text wrap, what is the point of working in Illustrator? might as well work in Photoshop)
4. clipping path is actually necessary, unless I edit the image in photoshop. There are 17 images in this doc. Again, why work in Illustrator if I can't use clipping path??
5. nothing is set to overprint (this design is for web)
