I just upgraded from MacOSX 10.5.8 to 10.6 and using Photoshop CS4.
Not sure if this is related to what happened today, but...
"About Photoshop" is greyed out. Can't tell what version I have.
I need to duplicate a layer in a high res RGB image. The LAYER, CHANNELS, PATH palettes have all options greyed out, except "convert to smart object", which I don't know yet what that is. The image is in 8 bits/channel. How do I fix this?
Thanks Baljeet. Even the QUIT Photoshop was greyed out. Had to Force Quit.
I removed the CS4 Settings folder. And relaunched. Good news - was able to work on the image for a few minutes.
Bad news - the Layer palette, About Photoshop, and Quit are greyed out again! The CS4 Settings folder is back, so deleted it. Was able to work again for a bit. Now back to square one with same problem as I started with. How can I fix this?
Is this a conflict with Snow Leopard?
Boilerplate-text:
Are Photoshop and OS fully updated and have you performed the usual trouble-shooting routines (trashing prefs by keeping command-alt-shift/ctrl-alt-shift pressed while starting Photoshop, 3rd party plug-ins deactivation, system maintenance, cleaning caches, font validation, etc.)?
I'm using Photoshop 11.0.2. and OSX 10.6.8.
I believe those are the latest versions?
I've done font validation using Font Book. All system fonts OK.
I do use Font Agent Pro 4.
Re: prefs - Command Shift upon starting PS brings up the application window. Now what?
I don't think I have 3rd party plug ins. How to find and deactivate?
Don't know how to clean cache for PS.
I've repaired Disk Permissions.
Any other advice you can give would be GREATLY appreciated. My design business has been shut down for two days since Snow Leopard was added!
Been on two monitors lately?
Looks like you may have a Modal Dialog somewhere off screen. Trashing your prefs (aka: post number 1) should have fixed it. Try Window>Workspace>Reset Essentials and see if that helps.
If not, check Apple System Preferences>Displays and see if your Mac thinks it may be hooked up to a second monitor.
No. Those are partial screen shots, because I cut out extra background. I don't use 2 monitors.
I was able to get some advice and fixed this problem:
I trashed all plist preferences in me/library/preferences.., emptied trash, repaired permissions, rebooted, unchecked "Enable Open GL" in PS Preferences.
Now I can work in PS but when I save or Save as, it crashes!
4 days so far, trying to correct this!!!!
Sorry, but this sounds more and more unlike a legitimate version of Photoshop CS4. Exactly where did you obtain it?
If if is legitimate, it most certainly is corrupted beyond repair and needs to be throughly uninstalled and re-installed, which would be a good idea anyhow since you upgraded to Snow Leopard.
Since you are on Snow Leopard, upgrading to CS6 at this time sounds like an excellent idea, before CS4 ceases to be upgradeable in less than six or seven months.
I DON'T do software piracy! It was a legitimate purchase from Adobe.
I don't think it's corrupted beyond repair either. I read 320+ posts on this forum that discuss this issue...
https://discussions.apple.com/thread/2138670?start=15&tstart=0
Here is another lengthy forum that talks on font conflict issues with SL...
http://www.prepressure.com/fonts/basics/snow-leopard-fonts
Different solutions seem to work for different people based on the variables of ones system. I was able to fix my first problem with someones suggestions.
After that I could work in PS, but it would freeze as soon as I would Save or Save As.
Yesterday I found another solution that seemed to make it more stable. But today it's still freezing more than the odd time.
A reinstall will be my next try. Not exactly sure how to do that.
Same thing still happens to me... I work in PS CS4 for a while and Layers palette turns grey and nothing works. I can SAVE. But then I have Force Quit, because the QUIT is grayed out.
If I SAVE AS, I can work longer before Layer's palette turns gray.
I've trashed Prefs several times.
I don't have a Modal Dialog off screen.
This is legitimate software.
I have upgraded to CS6 but haven't tested it yet. Are there any issues with OSX10.6.8 and Photoshop CS6?
It may help if we can could see your Photoshop System Info. Directions for sharing your system info from Photoshop:
Try these steps to fix most issues: http://bit.ly/Troubleshoot_PS
Adobe Photoshop Version: 11.0 (11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch])
Operating System: Mac OS 10.6.8
System architecture: PowerPC G4 with AltiVec Running in Rosetta
Physical processor count: 2
Processor speed: 2660 MHz
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: NVIDIA GeForce 9400 OpenGL Engine
OpenGL Drawing: Disabled.
Built-in memory: 4096 MB
Free memory: 1641 MB
Memory available to Photoshop: 3072 MB
Memory used by Photoshop: 70 %
Image cache levels: 4
Serial number: deleted.
Application folder: Macintosh HD:Applications:Adobe Photoshop CS4:
Photoshop scratch has async I/O enabled
Scratch volume(s):
Macintosh HD, 595.9G, 374.8G free
Primary Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS4:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
adobe_caps.framework adobe_caps 2.0.99.0 2.135373
adobe_epic.framework adobe_epic 3.0.1.10077 "53.352460"
adobe_eula.framework adobe_eula 3.0.1.10077 "53.352460"
AdobeACE.framework AdobeACE 2.14.21.1744 53.355610
AdobeAGM.framework AdobeAGM 4.19.26.1744 53.355610
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.4.401.1570 53.348206
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.4.401.1570 53.348206
AdobeBIB.framework AdobeBIB 1.2.01.1744 53.355610
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 53.355610
AdobeCoolType.framework AdobeCoolType 5.06.05.1744 53.355610
AdobeCrashReporter.framework AdobeCrashReporter 3.0.20080806
AdobeExtendScript.framework ExtendScript 3.92.114.1661 53.351316
adobejp2k.framework AdobeJP2K 2.0.0.1570 53.100857
AdobeLinguistic.framework 7863
adobelm.framework adobelm 3.0.11.10077 53.352460
AdobeMPS.framework AdobeMPS 4.9.16.1631 53.350311
AdobeOwl.framework AdobeOwl 2.0.70 53.354161
adobeowlcanvas.framework AdobeOwlCanvas 2.0.70 53.354161
adobepdfl.framework AdobePDFL 9.0.0.1733 53.204060
adobepdfsettings.framework AdobePDFSettings 1.4
AdobeScCore.framework AdobeScCore 3.92.114.1661 53.351316
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMP 53 . 352624
AdobeXMPFiles.framework AdobeXMPFiles 53 . 352624
AdobeXMPScript.framework AdobeXMPScript 53 . 352624
aflamingo.framework AFlamingo 1.0.404.1638 53.350580
ahclient.framework ahclient 1.3.12
aif_core.framework AdobeAIF 1.0.00 53.352475
aif_ogl.framework AdobeAIF 1.0.00 53.352475
AlignmentLib.framework xcode 1.0.0.1
amtlib.framework amtlib 2.0.1.10077 2.0.1.10077
amtservices.framework 2 . 0
asneu.framework asneu 1.6.2
Cg.framework NVIDIA Cg
data_flow.framework AdobeAIF 1.0.00 53.352475
FileInfo.framework FileInfo 53 . 352624
ICUConverter.framework ICUConverter 3.61 "gtlib_1.1 CL#7223"
ICUData.framework ICUData 3.61 gtlib_1.1 CL#7223
image_flow.framework AdobeAIF 1.0.00 53.352475
image_runtime.framework AdobeAIF 1.0.00 53.352475
LogTransport.framework 1.0
PlugPlug.framework PlugPlug 1.0.0.73
registration.framework 2 . 0
wrservices.framework
Installed plug-ins:
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - from the file “AdobeADM.bundle”
Accented Edges 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
AltiVecCore 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1998-2008 Adobe Systems Incorporated - from the file “AltiVecCore.plugin”
Angled Strokes 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Anti-aliased PICT 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1990-2008 Adobe Systems Incorporated - from the file “Anti-Aliased PICT.plugin”
Average 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Average.plugin”
BMP 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “BMP.plugin”
Bas Relief 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Camera Raw 5.0 (178), Copyright © 2008 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©2002-2008 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Clouds.plugin”
Color Halftone 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Color Halftone.plugin”
Colored Pencil 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “GIF.plugin”
Conté Crayon 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©2003-2008 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “CropPhotos.plugin”
Crosshatch 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Crystallize.plugin”
Cutout 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “De-Interlace.plugin”
Difference Clouds 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Displace.plugin”
Dry Brush 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Enable Async I/O 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] © 2004-2008 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
Extrude 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Extrude.plugin”
FXG 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “FXG.plugin”
Fibers 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Fibers.plugin”
Film Grain 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filmstrip 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “FilmStrip.plugin”
Filter Gallery 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
FontAgent Pro Copyright© Insider Software, Inc. 2001-2010. All rights reserved. Portions Copyright© Adobe Systems Incorporated 1993-2010 - from the file “FontAgent Pro.plugin”
FontAgent Pro Helper Copyright© Insider Software, Inc. 2001-2010. All rights reserved. Portions Copyright© Adobe Systems Incorporated 1993-2010 - from the file “FontAgent Pro Helper.plugin”
Fresco 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Graphic Pen 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 11.0, Copyright © 2003-2008 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
Halftone Pattern 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
IFF Format 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “IFF Format.plugin”
Ink Outlines 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Lens Blur 11.0, Copyright © 2002-2008 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 11.0, Copyright © 2002-2008 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Lens Flare.plugin”
Lighting Effects 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Lighting Effects.plugin”
Liquify 11.0, Copyright © 2001-2008 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Measurement Core 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Mezzotint 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Mezzotint.plugin”
Mosaic Tiles 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1990-2008 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
NTSC Colors 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Neon Glow 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ocean Ripple 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
OpenEXR 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©2003-2008 Adobe Systems Incorporated - from the file “OpenEXR.plugin”
PCX 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “PCX.plugin”
PICT Resource 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1990-2008 Adobe Systems Incorporated - from the file “Pict Resource.plugin”
PNG 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “PNG.plugin”
PPCCore 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1998-2008 Adobe Systems Incorporated - from the file “PPCCore.plugin”
Paint Daubs 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1994-2008 Adobe Systems Incorporated - from the file “Paths to Illustrator.plugin”
Photocopy 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Picture Package Filter 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Pinch.plugin”
Pixar 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Pointillize 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Pointillize.plugin”
Polar Coordinates 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Polar.plugin”
Portable Bit Map 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Radial Blur.plugin”
Radiance 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©2003-2008 Adobe Systems Incorporated - from the file “Radiance.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Ripple.plugin”
Rough Pastels 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web & Devices 11.0, Copyright © 1999-2008 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 11.0, Copyright © 2008 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Send Video Preview to Device 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1994-2008 Adobe Systems Incorporated - from the file “FireWire Export.plugin”
Shear 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Shear.plugin”
Smart Blur 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Smart Blur.plugin”
Smudge Stick 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Spherize.plugin”
Sponge 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sumi-e 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Targa 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “Targa.plugin”
Texturizer 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Tiles.plugin”
Tone Mapping 2.0, Copyright 2006-2010 HDRsoft - from the file “ToneMapping.plugin”
Torn Edges 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twain Acquire 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1992-2008 Adobe Systems Incorporated - from the file “TWAIN.plugin”
Twain Select 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1992-2008 Adobe Systems Incorporated - from the file “TWAIN.plugin”
Twirl 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Twirl.plugin”
Underpainting 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 11.0, Copyright © 2003-2008 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Variations 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Variations.plugin”
Video Preview 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1994-2008 Adobe Systems Incorporated - from the file “FireWire Export.plugin”
Water Paper 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 11.0, Copyright © 1991-2008 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Wave.plugin”
Wind 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “Wind.plugin”
Wireless Bitmap 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1989-2008 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 11.0x20080919 [20080919.r.488 2008/09/19:02:00:00 cutoff; r branch] ©1993-2008 Adobe Systems Incorporated - from the file “ZigZag.plugin”
Plug-ins that failed to load: NONE
Flash:
Connections
Kuler
Installed TWAIN devices:
EPSON Perfection 3200
EPSON Perfection 1670
EPSON Perfection 3170
EPSON Perfection 2400
Ok. First. Update you Photoshop.
If that doesn't fix it, then troubleshoot your plug-ins. you have a few 3rd party plug-ins (Font Agent Pro, Epson TWAIN, etc) that may be causing havoc.
Instructions for these and other troubleshooting here: http://bit.ly/Troubleshoot_PS
