I couldn't get a straight answer to why OpenCL might be unavailable, but it's clear that the setting depends on capabilities of the display driver.
http://forums.adobe.com/message/4414146
The general advice is to seek out and install a better version of the display driver for your video card. In the case of ATI, their latest release broke OpenCL functionality. That could be the same story with your nVidia drivers. OpenCL is still so new and volatile that apparently the normal "latest is greatest" philosophy with drivers is not true.
-Noel
Does it grey out every single time you check preferences having launched PS? Might sound like an odd question, but I've found on my own system (running an ATI 5850 Radeon with Catalyst 12.3) that it usually does have OpenCL checked, but occasionally it becomes greyed out. I just can't understand what's causing OpenCL to randomly become unavailable on an officially supported card with an up to date driver (but not quite the very latest version, because as Noel says, this is broken). Anyway, this may be of no help to you directly, but at least it shows that you’re not alone in experiencing OpenCL issues… I’m hoping future driver updates will make things more stable.
M
Mollysnoot - It is a helpful answer.
I made a restart to the system after installing the newest dirvers. Restarted photoshop serveral times and it was still gray.
Then after few hours after I gave up - I checked that again and now its not grayed out. You have the same issue like me. It is mysterious indeed.
Very interesting. I tend to find that I need to do a system re-start (not just re-start PS) to re-set the OpenCL dialogue so it's not greyed out. Makes me wonder: what causes PS to sometimes find fault with the driver/graphics card and grey it out, and yet not find fault at other times?
Having said all this, I have found that lately it's stayed on in the preferences, but I bet it'll gery out again at some point soon! :-)
M
>> what causes PS to sometimes find fault with the driver/graphics card and grey it out, and yetnot find fault at other times?
Some bug in the driver. If the driver returns errors when it shouldn't, or crashes, then Photoshop will remember that the driver is bad and disable the related features.
Thanks for confirming this Chris. Hopefully the next ATI driver update (seemingly delayed, as they were saying that 12.5 would be released in late May) will fix this then.
Always a bit dubious of using beta drivers GarySki... But as the beta is now 12.6, makes me wonder if 12.5 has been abandoned altogether.
M
A beta driver is not a completely untried/untested, but an update to the previous drivers to add features or fix bugs and needs testing by real users before releasing a final version; no different than Adobe releasing the CS6 beta, which I used without difficulty except for the non-beta drivers released by AMD/ATI. After rolling back my graphics drivers to the 12.2 version, I used the CS6 beta without issues. Dip your toes in the beta waters, the worst that can happen is you will have to roll back your drivers.
Unfortunately, I'm not sure that covers everything either. But I'm curious to know. I don't know what version you're running right now, but if it's 12.2 see what the sizes/dates of the following two files are:
C:\TEMP>dir C:\Windows\SysWOW64\amdocl.dll C:\Windows\System32\amdocl64.dll
Directory of C:\Windows\SysWOW64
02/14/2012 10:04 PM 13,238,272 amdocl.dll
Directory of C:\Windows\System32
02/14/2012 10:05 PM 16,507,904 amdocl64.dll
-Noel
Chris Cox wrote:
There is no way to activate it manually -- it's deactivated because the driver has a serious problem. Forcing it active would just expose you to the problems in the driver.
I gather, then, that once the GPU Sniffer—or whatever it's called—crashes, its reaction is final. Or something like that? I'm trying to use the terminology found in the Photoshop System Info off the top of my head.
OK This is weird.
The graying out happen when I render a video in photoshop and than the render crashes.
What I did to fix it is restarting PC->opening PS -> and "OpenCL" is still grayed out.
Closing photoshop and running sniffer_gpu.exe in the PS folder. Then opened photoshop. -> "OpenCL" still grayed out.
Close photoshop and ran sniffer_gpu.exe again then opened photoshop and OpenCL is available. (!?)
I dont know why it happens and why it is fixed.
This is of course done for NVIDIA GEFORCE 520 with newest drivers.
The people here who have ATI cards have a totally diffrent driver issue.
Looks like NVIDA also have work to do on updating their drivers then!
I don't think ATI users necessarily have a totally different driver issue: we've confirmed through your thread that the problem causing OpenCL to intermittently become unavailable is most likely to be the result of errors caused by the graphics card driver, and I'm hopeful that it will be resolved by future driver updates (in fact GraySki's experience is that it already has been fixed on the ATI side). What causes PS to identify that there's a driver error may vary considerably: might be rendering video as you've experienced, might be using say the new blur filters. But the basic underlying issue appears to be driver error, regardless of the card manufacturer.
M
Something that might help explain the inconsistency / intermittency is to remember that the GPU isn't just a hunk of silicon sitting there quietly waiting for you to give it work to do. It also runs your computer display all the while you're starting Photoshop, editing images, etc. On a Windows system, for example, besides moving data around for display on one or more monitors, all the little animations, Aero transparency, drop shadows - even the entire content of your Internet Explorer windows - are done by GPU programming.
The display subsystem has the complexity of an entire operating system in itself. I was noticing the ATI driver updates are now getting closer to 200 megabytes each.
-Noel
Yep. Both manufacturers and Adobe need to do some more work in making this stable.
I'm rendering a 4 seconds 3d animation with a single simple object and the program crashes all the time while rendering.
I guess its not a faulty graphics card on my end if others are experiencing the same issues.
I guess there is no solution for this but to wait for all parties to recognize these stability issues and fix them.
In case anybody is still stuck with this issue I have found than when running PS CS6 on Win 7 64bit I need to run the 64bit version for the "Use OpenCL" option to become available. If I run the 32bit version then the "Use OpenCL" option is greyed out.
BTW I think that even though the Use OpenCL option is greyed out when running the 32 bit version of PS CS6 on a 64bit system I suspect openCL is still working if you have enabled it in the 64bit version.
That's by design. OpenCL is simply not supported in the 32 bit build.
We can only guess that this made programming at the interface easier.
-Noel
