CQ5
Jan Amplexor
using mod_alias in combination with dispatcher
Jun 18, 2012 8:36 AM
Tags: #dispatcher
Hi all,
In the example dispatcher configuration there is a setting called DispatcherDeclineRoot which has a comment saying: if turned to 1, request to / are not handled by the dispatcher, use the mod_alias then for the correct mapping.  Can anyone explain how to use mod_alias in combination with the dispatcher module?  For example, how can I configure it to serve static content for a specific alias and go to CQ for other requests?  Can someone provide an example configuration?
Many thanks,
Jan
    Jun 18, 2012 8:48 AM   in reply to Jan Amplexor
    if you'd like certain paths to be ignored by dispatcher, exclude them in the filter statement in dispatcher.any. since the security checklist recommends having dispatcher ignore everything, and then selectively add a whitelist of paths to be processed by CQ, this should solve your issue:
    /filter
      /0001
        /glob "*"
        /type "deny"
      /0002
       # processed by CQ
      /glob "/content/mysite*"
      /type "allow"
    Jun 18, 2012 10:28 AM   in reply to Jan Amplexor
    the example i provided solves your issue. all requests not matching an "allow" filter in the dispatcher configuration will be served by apache instead. therefore, if you deny everything via dispatcher filter (a security checklist requirement), and selectively add paths to be served by CQ (e.g. allow /content/mysite), /oldhtml will be implicitly served by apache. what do you need mod_alias for?
    Jun 22, 2012 2:31 AM   in reply to Jan Amplexor
    in your virtual host, you may need to adjust the  directive for the paths you want to be managed by apache's default handler. most likely you currently have dispatcher handling all paths in the vhost?
