alainbettens
libraries in encore CS6
Jun 22, 2012 3:22 AM
Tags: #background #buttons #library_image #encorecs6
When installing encore CS6 i have menus libraries but not buttons, images ans background.
I tried from the installation disk but no way.
Who can help me
    Jun 22, 2012 3:32 AM   in reply to alainbettens
    The library content was limited with CS6. This is not the full version. For full version, follow the following steps:
    Go to http://helpx.adobe.com/x-productkb/multi/library-functional-content-mi ssing.html
    There you have "Download extra library content" under Additional Solution.
    Download the zip file for the desired language, extract that and point the library to that folder from Encore Preferences.
    -Thanks,
    Ramesh.
    Jun 22, 2012 5:32 AM   in reply to alainbettens
    What did you get when you extracted the zip file?
    -Ramesh.
    Jun 22, 2012 5:34 AM   in reply to alainbettens
    What is the size of the Content you have after download? Open the folder of the downloaded content and see if there are any buttons/images in the content.
    Make sure on this link http://helpx.adobe.com/x-productkb/multi/library-functional-content-mi ssing.html you scroll down to the bottom of the page and follow the instructions -
    Jun 22, 2012 5:37 AM   in reply to alainbettens
    I have done this ...
    But what is "this"? Many of us had trouble getting this straight: the "this" that gives  you buttons, etc is after "Additional Solution: Install the Resource Central library content." That is where Ramesh is referring to "extra library content."
    The solution at the top installs the "functional content" (templates only). The "additional solution" toward the bottom installs all the content, including buttons etc.
    Jun 22, 2012 10:38 PM   in reply to alainbettens
    Encore CS6 is a 64 bit application and 5.5 was 32 bit. You must be looking into Program Files (x86). And also, CS6 will go to the path which you provided to the installer while installing. Did you change the path while installing? If yes, navigate to that path.
    For example I have my Encore CS6 at        C:\Program Files\Adobe\Adobe Encore CS6           on my win 7 machine.
    What you can do is, you can copy the Library folder and paste it at  C:\Program Files\Adobe\Adobe Encore CS6  (in my case, Encore is here). And then point the Library to this path from the preferences.
    Or you can simply point the Library to this folder wherever it is now.
    To point your Library to the folder, do the following:
    1. Edit->Preferences... (Encore->Preferences... on Mac)
    2. Go to Media tab
    3. There the first rectangular partition allows you to browse to the Library folder.
    4. Browse to the Library folder and click OK.
    -Ramesh.
    Jul 1, 2012 9:13 AM   in reply to alainbettens
    You are looking in "program files (x86)." Look in "program files" without the x86. The x86 are 32 bit. Encore is now 64 bit.
    Jul 2, 2012 5:04 AM   in reply to alainbettens
    To extract the .7z file you can download a .7z extractor from - http://www.7-zip.org/download.html
    Use this tool to extract your .7z file to any location you want.
    Now, Launch Encore 6.0
    Goto - Edit -->Preferences-->Media
    The first text box shows the location of the library files.
    Click on the browse button next to it and browse to the location of the library folder in the files you have just extracted.
    Jul 12, 2012 8:32 AM   in reply to alainbettens
    As you did before, please post a windows explorer screenshot of your extracted library location.
    Glad you are back from the hospital!
    Jul 12, 2012 11:00 AM   in reply to alainbettens
    Screenshot did not appear...
    Jul 12, 2012 11:56 PM   in reply to alainbettens
    When you will extract the .7z file you will get a folder for example en-US if you have downloaded the English functional content.In this folder you will have subfolders namely - Library, main, Styles, Template.Remove your earlier copied files completely from Adobe/Adobe Encore CS6/library and copy these subfolders  to the following location -
    Now, launch Encore and goto Edit->Preferences->Media
    The firat text box is the location of the library.Click on the browse button to navigate to C:\Program Files\Adobe\Adobe Encore CS6\Library
    Clickon OK.Your library files will be loaded.
    Shuchi
    Jul 13, 2012 6:24 AM   in reply to alainbettens
    Glad you got the library working!
    3 method for playing single chapters and returning to menu.
    1) Make the chapters their own videos. For a "play all" use a playlist.
    2) Put each chapter into its own CHAPTER playlist. A chapter button links to the chapter playlist.
    3) Use overrides; this can be problematic, and most helpers here do not recommend this since chapter playlists have been added.
    Jul 14, 2012 12:29 PM   in reply to alainbettens
    excellent!
