Hi guys, here I am again!
I solved the problem with the timer and the screen appears now.
import flash.utils.Timer;
import flash.events.TimerEvent;
import flash.utils.setTimeout;
import flash.media.SoundChannel;
import flash.utils.*;
import flash.system.ImageDecodingPolicy;
import flash.display.BitmapData;
import flash.events.KeyboardEvent;
var customPanel:CustomPanel = new CustomPanel();
var timer:Timer = new Timer(30,0);
var timer2:Timer = new Timer(Math.random() * 60000,1);
var myTimer:Timer = new Timer(1200000,0);
var secCntr:int = 0;
var minCntr:int = 40;
var hourCntr:int = 23;
var currentTime:String;
var soundRequest:URLRequest = new URLRequest(sounds/Flash Clock.mp3);
var mySound:Sound = new Sound();
var soundChannel1:SoundChannel = new SoundChannel();
mySound.load(soundRequest);
soundChannel1 = mySound.play();
timer.addEventListener(TimerEvent.TIMER, setTime);
timer2.addEventListener(TimerEvent.TIMER, surprise);
stage.addEventListener(KeyboardEvent.KEY_DOWN, pressedKey);
timer.start();
timer2.start();
customPanel.visible = false;
function surprise(e:TimerEvent):void{
trace(Surprise!);
this.addChild(new CustomPanel());
function pressedKey(event:KeyboardEvent):void{
if(event.keyCode == 32){keyDetector()}
function keyDetector():void{
trace(The spacebar key was pressed)
function setTime(e:TimerEvent){
secCntr++;
if(secCntr == 60){
minCntr++;
secCntr = 0;
if(minCntr == 60){
hourCntr++;
minCntr = 0;
if (hourCntr >= 24){
hourCntr = 0;}
if(secCntr < 10){
currentTime = String(hourCntr) + : + String(minCntr) + :0 + String(secCntr);
else{
currentTime = String(hourCntr) + : + String(minCntr) + : + String(secCntr);
countdown_txt.text = currentTime;
The only is thing that the screen haves to be removes while pressing spacebar. I tried it like this:
trace(Surprise!);
this.removeChild(customPanel);{
But for some reason this doesn't work. The spacebar does react.
Have somebody a solution for this?
Greets,
Anne-Loes
You should show the code as you have it now. While it might not be the problem, it is not correct to have an extra set of brackets in your function below...
this.removeChild(customPanel);{ // this brace at the end does nothing
} // this brace does nothing
timer.start();
timer2.start();
trace(Surprise!);
keyDetector()
if(contains(customPanel))
trace(The spacebar key was pressed);
secCntr++;
if(secCntr == 60)
minCntr++;
secCntr = 0;
if(minCntr == 60)
hourCntr++;
minCntr = 0;
if (hourCntr >= 24)
hourCntr = 0;}
if(secCntr < 10)
else
This is the new code. Thank you
You should format your code properly, it is very difficult to read all spread out and oddly indented as you show it. I had to take you code and reformat it just to see what you have. After removing any code related to things I do not have, I ran the file and the textfield displayed time counting, and when I press the spacebar I get the trace message: "The spacebar key was pressed"
So it is working fine for what the code tells it to do. Since customPanel was never added as a child, it is not going to be removed (you create another new instance, but that other new instance is not customPanel)
To make it a child, use: addChild(customPanel); right after you create it in the beginning.
Then change your function below to make the customPanel visible (you already made it invisible a line before this function)
function surprise(e:TimerEvent):void {
trace(Surprise!);
customPanel.visible = true;
