After reading discussions about the flaws of external hardware (matrox, BM, AJA) - or at least the drivers needed, I want to find the right solution for using two computer monitors for my Workspaces and a third (HDMI or HD SDI) output for a 37-inch program monitor (not broadcast, but decent Panansonic LED). I have been reading tons of specs and posts... what is best? I am planning a new CS6 workstation
1. Dual Quadro 4000s
2. Dual GTX 570s or 680s
3. some new idea??
Why can't Nvidia make all three ports active on the Quadros?
Wishing Adobe would post more than just minimum specs, but some kind of details on levels of workstations based on types of workflows...
Diane
PS I've been using a $50 HP USB signal splitter on CS5 for a couple of months - it's been great - allowing me to spread my Workspace across two monitors with HDMI to the panny monitor. But that can't really be The Solution, can it?!?
GTX 670/680 cards support up to 4 monitors. Dual cards are not supported, nor is there a need for with the Kepler range of cards. Well, a bit more detail, you can install two cards if they use the same driver, but only one will be used by PR and the other only for steering monitors and that is a bit expensive with Quadros or the GTX 570/580, when a single 670/680 does the same job at much lesser cost and with better performance on most systems.
Videowilk wrote:
Thanks Harm - but I want to use a card certified by Adobe - does anyone know when it will be?
Request a card here: http://www.adobe.com/go/wish
I completely understand your desire to stick with certified cards but for the record, I've been running Premiere on my 680GTX without issue for a few months now. Just had to apply the famous "workaround" fix. They recently updated After Effects to include Ray Tracing support for the card and overall it works great. But if you're dead set on waiting, my guess is that certification isn't too far away.
