jmwarren2012
Robohelp 9.0.2 Access Project Files from Network Drive or SharePoint
Jun 22, 2012 8:51 AM
Hello everyone!
I was wondering if anyone has suggestions for the following scenario:
Mutliple content authors traveling around the world need to access centrally place project files.
I know using a network drive is a bad practice, and I've been testing it with little luck today. Has anyone used SharePoint to house projects in the past?
What is the best way to share these projects on a network? It's becoming very necessary for us to do so, and I was wondering if anyone has had any success.
Ideas anyone?
Jerry
    Jun 22, 2012 8:55 AM   in reply to jmwarren2012
    Hi Jerry
    Assuming SharePoint can function as a Source Control system it should work. Note that Source Control systems perform a variety of tasks. Librarian, Traffic Cop, etc.
    With any Source Control system the files are centrally located. They have to be, no? But in my experience, you configure each of them in a similar manner. You designate a "Working Folder" that is on your local C drive. As you check files out and work on them, they are copied to your working folder. When you check them in, they are copied back to the server and updated. So you are working locally but the content is centrally located. Assuming SharePoint works that way, it should work for you.
    Cheers... Rick
    Helpful and Handy Links
    RoboHelp Wish Form/Bug Reporting Form
    Begin learning RoboHelp HTML 7, 8 or 9 within the day!
    Adobe Certified RoboHelp HTML Training
    SorcerStone Blog
    RoboHelp eBooks
  • RoboColum(n)
    Oct 8, 2004
    Jun 22, 2012 9:20 AM   in reply to Captiv8r
    Hi Jerry.
    SharePoint is not designed for source control. At a push, and a really hard one at that, you can use it as Rick describes. The issue is that each RoboHelp project is a collection of many files. SharePoint does not allow you to easily check in and out multiple files. One way around this could be to zip your RoboHelp project files and add that to SharePoint. That way your authors could check out the zipped file, unzip it to their local drive, work on it, zip it back up and check it back in. Personally I'd suggest a proper source control application that is designed for that purpose. The problem with zipped files though is that they maybe viewed as a security risk inside SharePoint. If so this maybe a non-starter anyway.
  • RoboColum(n)
    Oct 8, 2004
    Jun 22, 2012 9:53 AM   in reply to jmwarren2012
    Yes that would work also provided you have strict procedures. For example the authors just write and the owner imports, indexes, compiles the TOC, etc.
    Colum
    Jun 22, 2012 9:59 AM   in reply to jmwarren2012
    Hello again
    As Colum indicated, it can work that way.
    When I was using RoboHelp in the corporate environment, I "shared" projects with a colleague. As Colum indicated, she had a copy of the project and used RoboHelp to create new content and revise content. At the end of each day she would tell me what topics had been added and changed. And I was the "master" and I would open my own copy of the project and import her new and changed topics. Then I would generate, test and publish from my own PC.
    Cheers... Rick
    SorcerStone Blog
    RoboHelp eBooks
