pat agonia
Why can't LR see the DNG's?
Jun 22, 2012 6:59 AM
I really am utterly confused by LR.3.6
What I am doing is for every new set of images, say a wedding, I am setting up a new catalogue on the off board HD.
I then import the images as DNG's & that's after first off loading them as the original Nikon RAW files (I don't trust either LR or myself to get it right) onto another HD.
So, now I have 2x copies.
One original non-PP RAW files
One open in LR as DNG's which I then work upon.
Now, a few days later, I plug in the HD into my PC and Lo! File name is off line or missing.
This happens more often than not, so maybe 75% of my work flow is stymatised by having to work out what's happened or I have to start again on the PP.
At this point, I am trying to both open the .lrcat file either from within LR / File /  Open Recent or directly from the file on the offboard HD.
I can see the DNG's but LR seems unable to do so.
Grrrrrrrrrrrrrrrrrr!
What error am I making?
    Jun 22, 2012 7:10 AM   in reply to pat agonia
    What OS? Windows or Mac?
    If Windows, when you plug in the HD, is the drive letter always the same? If not, that would explain the problem.
    Jun 22, 2012 7:47 AM   in reply to pat agonia
    pat agonia wrote:
    I've opened the DNG's in Bridge CS5 now, having given up with LR for the moment and none of the changes are apparent.
    Why is this?
    Is not the Adobe software seeing / reading it's own data?
    Because Lightroom is a non-destructive editor, which means that changes you make within Lightroom are only stored in the catalog, the image file is not over-written. You can, however, have the edit information stored as XMP data in the header of the image file, which could then be read and interpreted by other Adobe software. But for Lightroom to be able to write that metadata back to the file, it has to be online.....so you're back with the original Lightroom problem of your files being missing.
    I ask again: when you plug in the HD is the drive letter always the same?
    Jun 22, 2012 7:49 AM   in reply to pat agonia
    The default operation of Lightroom does not store metadata in DNG files. By default, Lightroom only stores metadata (including edits) in its catalog. So, in the default operation of Lightroom, the only place you can see the edits is to view the photos in Lightroom.
    I suggest you look further into this issue of external drives changing letters, instead of saying "No idea". In particular, Lightroom will tell you the location (including drive letter) that it thinks the photos are located in. This can be seen in the Metadata Panel on the right of the Library Module. Then go to Windows and determine where the photos are actually located (including drive letter). If the drive letter or other part of the location and file name don't match, then there's your problem. If it is the drive letter, this is easy to fix. If there are some other parts of the filename/path that have changed, we can probably help you fix those issues as well.
    Jun 22, 2012 8:17 AM   in reply to pat agonia
    Lightroom stores the full path to each image in the catalog including the drive letter, so the drive letter needs to remain the same as when you imported the files.
    The drive letter does not necessarily change when you connect to a different USB port. Each drive has a unique signature so Windows is usually able to assign the same drive letter.  If you have multiple drives that all share the same drive letter, though, then this will be a problem if you have more than one plugged in at the same time, where Windows will necessarily have to assign a new drive letter to at least one of them.   If you also have drive-letters assigned to network locations, the local drive letters can be hidden by the network drive connections.
    Assuming you are on Windows 7, you can use Administrator Tools / Computer Management / Disk Manager / right-click-on-hard-drive / Change Drive Letter and Paths… to assign a different drive letter to each of your external drives so there won’t be conflicts if you plug in more than one at a time or to move the drive letters out from under any drive letters used for network locations  Once you have a different and consistent drive-letter for each drive then you can right-click on a wayward folder in Lightroom and choose Update Folder Location then navigate to the folder on whichever hard-drive the photos are on.
    Jun 22, 2012 8:43 AM   in reply to pat agonia
    Lightroom looks for the image where ever it was first imported from.  If the location is stable then there shouldn’t be any problem, although sometimes the upper-case/lower-case of the drive letter can be different and confuse Lightroom.
    You can see the drive letter in My Computer or Computer and usually in the title or address bar in Windows Explorer, and usually in the title of the AutoPlay window that pops up when you plug in a hard drive.
    You don’t copy/paste the images to another hard-drive to make LR see them, again.  You right-click on a folder in LR and choose Update Folder Location… and click over to where that folder is, now, whatever drive letter it is on.  LR will update the references to all the photos that are under that folder to the new location.  Do this “locating” after you’ve assigned consistent drive letters to each hard-drive.
    Is your problem that you are moving the hard-drive between two different PCs and the drive letter is different between the two PCs?  If so, then you will certainly want to assign the same drive letter to that hard-drive on both PCs and do the same thing for each hard-drive you connect to each PC.
    Jun 22, 2012 9:13 AM   in reply to pat agonia
    Unless you intervene, Windows will allocate the next available drive letter when you plug in an external drive. If you are in the habit of moving the external drive between different PCs, then it logically follows that there is a risk that the second PC will allocate a different drive letter (i.e. it depends on what the next available letter is on the second PC). Furthermore, when you reconnect the drive back to the original PC, it again may get a different drive letter than the last time if you have connected other devices in the interim.
    The very simple solution, which you only ever have to do once, is to allocate a specific drive letter (and a drive name helps as well), and choose one near the end of the alphabet (so it won't get affected by other device connections), e.g. drive X. Then do exactly the same on the second PC. Ideally you would have done this before starting to import files into Lightroom, but as you haven't you'll need to do the "Update Folder Location" process as outlined, and the problem should be sorted
