How do I make a black and white portrait with piercing color eyes or red lips
Jun 22, 2012 7:18 AM
I am frustrated thus far with this PS elements 10 and trying to get answers on the internet is frugal as I've come across a solution which doesn't assist me with elements 10. Please help before I return this product
    Jun 22, 2012 7:28 AM   in reply to AlwynjSmit
    It would help if you post the picture so that we may offer targeted suggestions.
    You can do this via the camera icon in the reply box, or at www.pixentral.com. If you use pixentral, please provide the URL so that we may open it.
    Jun 22, 2012 7:58 AM   in reply to AlwynjSmit
    The picture didn't come through. To send it post another reply and click on the camera icon:
    Jun 22, 2012 8:45 AM   in reply to AlwynjSmit
    Mark is showing you the top of the message composition section on this website, not in PSE.
    Jun 22, 2012 9:28 AM   in reply to AlwynjSmit
    Click on "reply" at the bottom of this post, and you will find the camera icon at the top - see Mark's post #3
    Not at the top of the page. When you click reply, like this. Why can't you reply here? What happens? Are you logged in?
    Jun 22, 2012 9:57 AM   in reply to AlwynjSmit
    I have a bookmark for http://forums.adobe.com/community/photoshop_elements
    I'm always logged in. Maybe when you log in there is an option to remain so.
    So what do you want to do?  Convert a color picture to B&W leaving just selected portion in color such as eyes?
    Jun 22, 2012 10:31 AM   in reply to AlwynjSmit
    1. Make a copy of your background layer by hitting Ctrl+J.
    2. On that background copy layer, use the Smart Brush tool.  In the Options Bar for the tool, select the "Reverse Effects" effect, then its "Reverse Black & White" option:
    3. Paint the eyes to get this:
      At this point your layers look like this:
    4. Ctrl+click on the mask icon of your reverse colour layer to select all the white area.
    5. On the main menu bar, use Select...Inverse to invert the selection (so only the eyes are now selected).
    6. In the Layers panel click the icon at the bottom to add a new Hue/Saturation adjustment layer.  This layer will be automatically masked to the selection of the eyes.
    7. Adjust the saturation and lightness sliders:
    Your final image:
    Your layers end up like this:
    Ken
    Jun 22, 2012 10:35 AM   in reply to AlwynjSmit
    Lots of ways to do this. Your PSE version has the Smart Brush which will do the trick. Hopefully some other reader of this forum can help you there since my version does not have the Smart Brush.
    Here is how I did it, and so can your version.
    1. Duplicate the Background layer and remove the color: Enhance > Adjust Color > Remove Color.
    2. Add a Layer Mask to the duplicate Layer.
    3. Click on the mask in the Layers Pallete, and with the Brush tool paint black on the eyes to reveal the original color.
    4. Add a blank layer and set its Blend Mode to "Color". Paint the eyes with blue. If the result is too bright or dark, lower the Opacity of the layer as I did.
    5. If you paint too far into the pupil or outside the eye, use the Eraser to remove the excess.
    Jun 22, 2012 11:31 AM   in reply to Mark Sand
    1. Open your picture file
    2. Access the smart brush tool, the one with the gears. In the drop-down, select Black & White - use high contrast which is in the panel, and be sure to check "Inverse" at the top. Paint both eyes. You should have 2 layers
    3. Go to Layers>merge down. You should have 1 layer
    4. Access the smart brush tool again. In the drop-down , select color, and use the nice blue in the panel.
    5. Paint both eyes
    6. You can click on "refine edge" at the top on the tool's option bar if necessary
    7. To get rid of the "marching ants" go to Select>deselect
    TIP: You can make the brush cursor larger with the right bracket key ], smaller with the left bracket key [, next to the letter p on the keyboard
    Jun 22, 2012 11:41 AM   in reply to hatstead
    Once you get the hang of this, you can do all sorts of things.
    Don't be discouraged. Yes, there is a steep learning curve to this program. There are several  excellent  books, help files, movies, and assistance here on the forum.
    Jun 23, 2012 10:47 AM   in reply to AlwynjSmit
    In my post #15, realizing that this program is new to you, I provided instructions which I thought were straight-forward. The stuff you have just posted in post #18 did not emanate from me.
    Suggest that you print the content in post #15, try it, and if it doesn't work for you, let us know where you get stuck.
    Will be glad to help.
    For your information, the folks posting here are consumers, like you. If you have a problem with Adobe, suggest that you contact them. I doubt that they monitor all these threads. Occasionally an employee will make a suggestion, but that is the exception, rather than the rule.
    Since computer time is at a premium to you and you are seeking a manual, I recommend the following to you:
    http://www.amazon.com/s/ref=nb_sb_ss_c_1_8?url=search-alias%3Dstripboo ks&field-keywords=brundage&sprefix=brundage%2Caps%2C193#/ref=nb_sb_nos s?url=search-alias%3Dstripbooks&field-keywords=brundage+photoshop+elem ents&rh=n%3A283155%2Ck%3Abrundage+photoshop+elements
    I have no commercial connection to the author or to the publisher.
    There are other books, of course, but this one has served me well, is well illustrated and indexed. Others have different "favorites."
    Jun 23, 2012 12:15 PM   in reply to AlwynjSmit
    AlwynjSmit wrote:
    Viewing tutorial material in video format chows data which in turn costs money. I'm so frustrated right now
    There are always going to be some effects that require a good working knowlege of the program.  I can appreciate that, at first, the learning curve can be steep if you've never used an image editing program.  The good news is that it becomes easier the more you use it and practice.
    Reading the Help files is what I did to learn PSE.
    When the Help is open, there's an icon in the upper right corner for "View as PDF", then you can save that PDF to your computer for reading and searching. (Do that for both the Editor and the Organizer, since the help files are separate.)
    I also found the Adobe TV tutorials very helpful:
    http://tv.adobe.com/product/photoshop-elements/
    You'll want to view the tutorials for PSE8, PSE9, and PSE10 because some of the tools were unchanged and new videos weren't created for the newer versions. When you watch the videos, look to the right of the video viewer -- some of the tutorials have sample files for download so you can practice on the same photos used in the tutorial.
    What I've found is that these are the 3 most important things to get comfortable with in PSE:
    1. Making selections.
    2. Using Layers.
    3. Using Masks.
    If you have questions, you know where to find us....
    Ken
    Jun 24, 2012 4:17 AM   in reply to AlwynjSmit
    AlwynjSmit wrote:
    Tx man, I appreciate your help. I was under the mistaken impression that you guys are working for Adobe. Please forgive me for my rude demeanor, I am so sorry.
    No problem. Feel free to repost for help as you continue to use the program.
