Hi everyone,
I am newbie here.
Can someone please tell me how to snap such as the attached image?
Please notify me by email when there is a reply.
Thank you
Jarlabs
From your screen shot, looks like you want to know how to distort a transformation not snap.
Hi Mike Gondek,
Thank you very much for your help.
However, I still can not snap the four corners of the ellipse to the four corners of the rectangle because when I try to snap one corner of the ellipse to the one corner of the rectangle, the other corners are moving too, won't fix at their position.
Can you please tell me more detail about it?
Thank you
Jarlabs
From the View menu make sure the Smart Guides are checked.
With the Selection tools (black pointer) click anywhere on the ellipse and try to position it as shown in the first step from my previous message. Drop the ellipse when the Smart Guides say "intersect" as shown in the image.
Click and drag the bottom left point of the transform box of the ellipse to the cursor position shown in the second step. Drop it when the Smart Guides say "anchor"
Pick the Free Transform tool (as shown in the image below), click and drag the bottom right point of the transform box of the ellipse to the cursor position shown in the third step. Hold Ctrl key before (while) dropping and make sure the Smart Guides say "anchor"
Hi emil emil,
I appreciate your help.
However, it still doesn't works.
This is what it looks like when I use the Free Transform Tool and holding the ctrl button:
http://s18.postimage.org/iotuorqcp/Snap1.png
And this is what it looks like when I release the ctrl button:
http://s14.postimage.org/wwlbvf4a9/Snap2.png
What should I do next?
Jarlabs
my instructions were valid for the shapes and scenario shown in the image in your original post. Did you try that? Your last post shows that you are doing something quite different. In this case you can't use the same steps and approach.
Also when using the Free Transform tool you don't release the Ctrl button before releasing the mouse button if you want to retain the free transformation.
For your last case, I would put a box fitting around the ellipse and manipulate them together using the box as a guide for the Free Transform tool. Snapping is not possible in this case but with a few adjustments you can reshape the box and the containing ellipse to fit in the target shape.
Another way is to use Envelope distorted made with a Mesh but while this can give you precise snapping of the corners of the box to the corners of the target shape, the ellipse itself will be reshaped by the length of the handles which takes more manual adjustments and subjective shape decision to make the deformation. For this reason I would use the first method.
Hi emil emil,
I am 100% sure that I already follow your instruction correctly.
Yes, I am not release the ctrl button before release the mouse button when using the Free Transform Tool.
What I would like to do is to fit the box around the ellipse, to the rectangle.
However, it still doesn't work.
Btw, I am using the Adobe Illustrator CS3.
Jarlabs
probably the best tutorial on using the free-transform tool:
http://www.automotiveillustrations.com/tutorials/adobe-illustrator-fre e-transform-tool.html
Missed that.
If things "snap back to position" when trying to free transform it means one of two things....
1) You're trying to free transform a raster image. You can't.
2) You're trying to free transform Live Type. You can't.
In either case.. do this.....
First select the image or the live type with the Selection Tool.
Choose Object > Envelope Distort > Make with Mesh.
Insert 1 row and 1 column and click OK.
Now you can use the Free Transform Tool on the envelope (which contains the raster image or the live type)
You can edit the contents later if needed via Object > Envelope Distort > Edit Contents.
Also, reviewing post #6 it appears that the standard bounding box is being used, not hte Free Transform tool. Be certain you are using the Free Trnasform tool (hit e on the keyboard)
Below tutorial is too complicated for me:
I can not follow it.
Does anyone here can explain me in the simple way?
This is what it looks like when I use the Free Transform Tool and holding the ctrl button....And this is what it looks like when I release the ctrl button:
You have to release things in the correct order, too.
JET
Try this... Go to the View Menu and look for Hide Bounding Box. If it's there, click on that line so it says Show Bounding Box. Go back to your file and select your object. There should be no corner or side adjusting boxes visible, just the small anchor points. Hit the e-key on your keyboard. A new set of selection boxes should appear. Then follow JET's instructions above.
hahaha, ok try this underground site, only known to hardcore illustrator users, and of course free of charge
http://www.youtube.com/watch?v=oGRz7mPhv7Q
...anything else? coffe? ice cream?
