Maliazmom
PDF to epub not converting correctly
Jun 29, 2011 10:33 AM
After I change my PDF to an epub file, it does not look the same. I have two photos per page in the PDF, and when it converts to epub it shows only one picture per page with double the amount of pages?
    Jun 29, 2011 11:30 AM   in reply to Maliazmom
    How are you converting it to epub? Acrobat doesn't export to epub.
    Jul 1, 2011 6:31 AM   in reply to Maliazmom
    Jul 6, 2011 8:26 PM   in reply to Maliazmom
    Try Calibre. It's an open source ebook management app that organizes ebooks and can convert between multiple formats.
    Feb 2, 2012 8:07 PM   in reply to Maliazmom
    You can use some pdf to epub converter for mac or windows. Goole "pdf to epub converter" or "pdf to epub converter mac". There may be more useful informations for you.
    Jun 16, 2012 6:44 PM   in reply to inman2787
    Yes, Calibre works very well in my experience BUT it doesn't work if you buy something in pdf and the Seller put a DRM on it.
    Jun 17, 2012 8:57 PM   in reply to jena518
    Nor should it do anything differently than any other software package.  DRM
    is implemented the same way across the board.
    Jun 21, 2012 10:16 PM   in reply to Frustrated in AZ
    In some ways I agree with the theory of DRM...just not the practice if the original format doesn't work when told it does.  That's the equivilent of stealing isn't it?  Charging for something that the Buyer can't use.  If you have purchased something, believing that it will work and disappointed when it doesn't shouldn't there be a solution for the end user or is it just written off by the companies that have that in the software?    Bottom line is $$$ for any company...but customer satisfaction, support...are those things no longer important to companies?   Individuals that buy software that have this ability should be able to use it but when it's used to cheat as a scam, why is finding help a challenge?  The End User did nothing wrong but with all the technology out there...there's no real reason something can't be done to help us.
    It's not right nor is it fair...but no one who can 'fix' it really cares do they.
    Jun 22, 2012 11:05 AM   in reply to jena518
    I may become a PITA for you, but I think you need to step back and
    determine how you started this process.....
    .pdf is a file format that's been used for documents for what seems like
    forever.  It has many limitations, and for that reason, other formats for
    epublications were developed.  Those formats permit more flexibility in
    formatting text, illustrations and colors that .pdf does.  Adobe developed
    the 'epublication' format (.epub) many years ago, and it's one of the
    standards in the industry.  There are very few companies that publish
    ebooks that don't have an .epub version available.
    I don't know why you chose .pdf format for the ebooks you downloaded.  The
    results seem unsatisfactory (!).  You say 'the original format doesn't
    work' , but you chose it - perhaps not knowing how limited a .pdf file is,
    and on the faith that the NOOK supports .pdf.  Digital Editions does also,
    but within limitations, because it does not incorporate all of the features
    found in Adobe Reader software (which is designed to handle .pdfs).  So,
    there's no telling whether the ebooks you purchased in .pdf are using
    features not supported by either the NOOK or Digital Editions - until you
    run into a problem.
    This 'feature' problem is compounded by conversions.  You have no idea when
    you start whether the program you're going to use will do the job correctly
    because you don't know what .pdf features are incorporated in the original
    ebook.  Slowly, step by step, we go down the rabbit hole...
    Jun 26, 2012 2:11 PM   in reply to Frustrated in AZ
    Yes, you're right about the different formats available.  BUT, pdf is what I was given so not being able to use it, to read more than one word on a line isn't unreasonable.  However, I know that other people that have Nooks just rebuy the item after trying to fix the problem.  I don't have that kind of disposable income.  Most people look for deals and it a great opportunity for scammers to take advantage of that....but when 57 books from on author are set up that way....and youi have several authors it's difficult to understand why there is no help.
    Again...more exercises in futility and fustration.
    Jun 28, 2012 5:36 AM   in reply to jena518
    I feel for you, Jena.  The technologists who do this don't think of those
    consequences.
    Feb 20, 2013 12:58 AM   in reply to jena518
    I agree with this comment and your points in post 8 about the practice of DRM.
    There are DRM strippers such as epubee.
    You can then use the best converters available to escape from the inappropriate .pdf format.
    The legal case of using these strippers is not clear and varies from country to country.
    However, the moral case seems pretty clear.
    They should not be used for breaking the intent of the DRM (eg for sharing copies with other people).
    However, their use is completely justified in cases where the DRM implementation is faulty, as it is in many ways with Adobe DRM, to enable books to be read in an appropriate manner.
