I have to convert an 8-page, European, A4 (8.27 X 11.69 inch) formatted InDesign color brochure to 8.5 X 11 inches for the US market. I have a few questions I'd like help with.
1. First, this European brochure is laid out with the front and back covers in a single spread (with front cover to the right and back cover to the left, as if you wanted to print it on a single large sheet of paper and fold it to make a cover using a laser printer). When creating new, multip-page brochures, I always treat the front and back covers as single pages, not as spreads, with a lone front cover page at the beginning of the document, and a lone back cover page at the very end. Is it advisable to change the original? It won't be difficult to do. I'm mostly concerned about working with a commercial printer (whoever my client selects).
2. Is there an easy way to do a layout adjustments that will rescale everything, including images? I'm going from a tall, thin format to a shorter, fatter format, so it will present a few challenges on certain pages when trying to fit things in vertically, since I lose 0.69 inches of height. Also, I'm a bit concerned that an "auto layout adjustment" may create a mess. What's the preferred way of doing this?
Any other words of wisdom are also welcome.
Lou
Is that cover spread a single page, or two pages with a section start to force the spread, or to put this another way, how many pages and spreads does ID report in the pages panel? Personally, I'd be inclined to move the back cover back to the end of the doc before outputting for the printer to be sure there's no confusion during imposition IF all the pages are spearate and it's arrange in readers' spreads other that his one.
Sadly, I doubt layout adjustment is going to help a lot unless you go to the trouble to draw guides snapping to every image frame and any text frame that isn't alread snapped to margin guides, and even then it might or might not work. That's about the same amount of work as setting up in CS6 for an alternate layout. For only 8 pages I'd probably just copy/paste from one doc to the other, then adjust things manually.
Hi Peter.
The front and back covers are set up in ID as two separate pages and combined into a spread. The back cover is "page 1" (on the left) and the front cover is "page 2" (on the right) in the ID pages palette. All the rest of the pages are set up the same way. I have NEVER set up a brochure this way. My only concern was the covers. This arrangement misnumbers ALL the pages in the brochure too. Yikes! My biggest concern was confusing the printer during imposition, as you confirmed.
I figured auto adjustment would probably be more trouble that it's worth. I've always done it manually in the past, but thought I'd ask to see if I was missing something.
Thanks you.
Lou
Thanks again, Peter.
That's great method for when I absolutely need it, but I prefer to set it up as I normally do, with front and back covers in their traditional locations as individual pages. That's the way I'm going.
Your answers are always so helpful and well-informed. I appreciate your expert assistance.
Lou
I often do it so, e.g. I have a flyer, I start in section with page 4 (he last one, and make on the same spread on the right side a new section which starts with 1, so I have numbered all pages correctly. I would never put the last and the first page on a single page, but on the same spread, even if I create book covers, which consist on 3-page-spreads.
Oh, I'm in complete agreement. As I said, even if you work with the covers as a spread, I'd move the back cover before making the PDF. It can be helpful to work this way if the two covers need to relate to one another in some specific way, but otherwise I find it a distraction. I like to design as the reader will see things, and normally they don't open a booklet and lay it down to view the open covers.
Hi Lou,
If you'd like to try out an Imposition product at you could resize your A4 easily in our Adjust pages sizes...(you can adjust the x and y) and then impose it please take a look at Quite Imposing Plus 3.
Here is a temporary number so you can try it out for free. It's an Acrobat Plug-in.
Expires end 7/2012 Serial 7313-6768-1128-1358 Code 6945
cheers,
Charles
Quite software
USA
