I see you're on a Mac. There should be a keyboard app similar to Charmap on Windows (a native OS software like MS Paint).
In Windows there is a keyboard shortcut for this for fonts that have that glyph built in: "Alt+0156" where the 0-1-5-6 is typed in sequence while holding the Alt button down. The numbers must be typed from the numeric keypad on the right-hand side of the keyboard used for accounting applications. Charmap from the command line typed out will bring up this application and will show you many keystroke equivalents but not every glyph has a keystroke equivalent. I will look on the mac side to see what this application is called if you don't find it first.
Just a nominal footnote: "œ" is not a ligature, in the sense that "fi", "fl", and "Th" (in Minion Pro) are. These are typographic ligatures, designed to lighten the 'clash' between the top of the 'f' and 'i' -- and the other combinations. As such, they are used automatically when needed.
"Œ" on the other hand is a proper character on its own. There is a difference between "boeuf" and "bœuf", if only that the former has 5 characters and the latter only four. Ligatures do not change the character count, they only change appearance; digraphs such as 'œ' and 'æ' change the *meaning* of a character, and so it's beyond OpenType to "fix" it.
(Adobe used to add "œ" as a 'ligature' to fonts -- maybe as "Discretionary Ligature, cannot recall -- but ceased to when they got complaints from native users of these. A comparable, recent discussion on Typhophile was on 'automatic' replacement of 'ss' by 'ß' and the other way around. Again, this is not a pure typographic replacement but an orthographic one, beyond the scope and intention of OpenType.)
Awesome! Thanks opt Q works when I go back to US Keyboard form Unicode.
I also thought that maybe the opentype feature is nto working because this is not a ligature, but a charachter on it's own. The wiki calls this a ligature
http://en.wikipedia.org/wiki/%C5%92
Would rather set this as an opentype global option, cause don't have time to search for each character, but the option q is a better alternative than glyphs.
We still have keycaps, ya know, right? It got a lot less obvious with osx, but it's still there. You have to have another menu over by your clock, but it's small. ;-)
In the Keyboard control panel, check "Show Keyboard & Character Viewer in menu bar" and you'll get a new menu up there - "show keyboard viewer" will let you see all of the option and shift-option characters.
The Oxford dictionary calls a ligature "two or more letters joined (fi, æ etc.)" from the Latin ligere to bind.
So presumnably œ is a ligature too.
Here in Iceland we use Æ, æ for the sound 'eye' and it remains a ligature of A and E even though it has its own place in the alphabet and is treated as a separate letter in its own right.
The term "ligature" is of a description of a design. You can design your æ's any way you like, but ... it ought never be spit into separate "a" and "e" because, as you say, those *characters* are different. Personally, I use the term "ligature" exclusively for optional designed combinations of any two (or more -- "ffi") characters that do not influence "meaning", and "digraph" for a unique character that happens to be historically composed out of more characters.
Ye olde ampersand "&" is a digraph which has evolved *so* far since its first use, you can hardly tell it's a shorthand for "et". I guess that's why noone calls it a ligature anymore, though maybe one did in the ancient past.
That's your personal definition (which I understand to a point) but it's not the official one.
And by the way, "Ye olde" is really "Þe olde", the letter thorn having been mistaken for a Y in Gothic script. We still use Þ, þ in Icelandic for the unvoiced th sound like in thistle. See also http://www.baacorsham.co.uk/SFsubweb/PAGE7.HTM bottom of page.
