Attempting to create a new Site, the New Site function prompts fields for Site Name and Local Site Folder. However, the first time I filled these fields I accidentally ended a URL with the \ character. Now every time I attempt to fill these fields with the correct URL the DW application adds that \ to the end of the Local Site Folder field and then issues error message that / (yes, not the same character) isn't a valid path component. I've deleted the WinFileCache*.dat file, deleted Internet Explorer saved files, and restarted computer but the error persists. Any ideas short of reinstalling DW?
I had tried this but I tried again and it still didn't work. And I just noticed that on page 828 of David Sawyer's Dreamweaver Missing Manual there's a "Note" describing this error and claiming the site's been set up regardless. This isn't my experience. Somehow, I have to be able to enter Sawyer's designated name and URL without getting the error. Also, finally, the reason I didn't get a reply button for Nancy O's reply was that I was logged into Adobe's product purchase site using another email address and password.
OK. Delete your DW Personal Configuration Folder. DW will create a new one.
http://forums.adobe.com/thread/494811
Nancy O.
That deletion was my first response to the problem. It occurs to me that Sawyer encountered this problem with a correctly formed URL. Therefore, the fact I ended a URL with a \ instead of a / may be a red herring. I'm wondering if the problem isn't the URL Sawyer wants placed in the Local Site Folder: http://www.cosmofarmer.com/cosmo_shop. This isn't "local". Sawyer is demonstrating a testing server, but I'm wondering if that URL isn't appropriate for the New Site process. In that case, the reason DW states that the error is a / that's not appropriate for the path is that it's the second / in the URL beginning http:// and that address in its entirety isn't appropriate. This all occurs on pages 823-826 of Sawyer's "DW4.0 The Missing Manual".
Nancy, the primary pertinent information in your screen prints is that the address in the Local Root Folder is indeed local; its on your C drive. The address Sawyer wants to use is a URL for a remote site. I think this is the underlying problem, and I'll try to proceed in his example to see if the error can be ignored as he says. Also, I'm using DW5.5. What worked in DW4 may not work in DW5.5. Particularly, there's the issue of why I can't clear the initial URL with the erroneous \ in its path from DW4's files; whereever that may be. Deleting the WinFileCache*.dat file didn't have any effect.
First, I'd like to defer to Nancy on (almost) ALL issues related to DreamWeaver! She has knowledge and background that I can only aspire to.
But let me remind you that you do NOT need to "Define" your sites in order to be able to use DW! DreamWeaver will work just file with the plain old folder/file structure of your machines operating system.
At any one time, I may have about 20 active sites running and I use DW to edit and update ALL of them. I have defined ZERO of the sites.... !!
OK, I'm out of the closet! I'm a non-traditional DW user!
Since I don't use it, I'm really not sure of the advantages of "defining" a site. Everything DW can do by defining a site can also be done otherwise.
So please don't feel that just because you are having problems defining a site, that DW can't work for you.
DW can open and edit any applicable files on any drive on your computer. DW can link to any other file on your computer with the "Point to File" feature in the Properites Panel (images, other Web pages, etc).
And for FTP, I'd suggest a real FTP program, like Filezilla or SmartFTP.... more powerful and versatile than the built in FTP of DW!
So if for some reason you feel that you need to "Define" your sites... go for it!!
But also realize that "Defining" a site is just not necessary to take advantage of most of DW.
Best wishes,
Adninjastrator
It's David Sawyer McFarland - just so you'll know.
Let me back up a bit and ask what is the actual path to your local root folder (the one that you have in your site definition)? And also, what is the value that you see under advanced settings for the Web URL? Finally, what is the path that you see in the Root Directory field of the Remote site's definition?
One more question - are you using DW4 or DWCS5.5? You mention both and I'm not sure which applies.
