I have this weird thing at my website. There is a gap between the main and the footer.
As you can see here: http://dhsrobotics.org/2012/home.html
Second problem. In this one, the main and the footer stops leaving an awkward thing for the continuing text.
LINK: http://dhsrobotics.org/2012/BEST.html
Please help! Thanks!
#1 Remove height values from divisions. Page height is determined by content, not explicit values.
#main {
height: 700px;
width: 910px;
background-repeat: no-repeat;
font-family: Verdana, Geneva, sans-serif;
background-color: #999;
#2 Same as #1 above. Height is limiting how much content will fit inside your #main div.
Nancy O.
The colors are pretty dark. Where are you seeing this gap?
As far as other code errors go:
The <blockquote> tag is intended to delimit a bit of quoted text on your page. It happens to also indent the text, and as a result is commonly used erroneously as a general indentation tool. That's an improper use. While it won't cause your page to fail validation, it will confuse any semantic evaluation of the 'meaning' of the code.
Ok, I see it is now that the blockquote is gone. That's because the floated element is taken out of the flow of the document and is longer than the container that it's in. So the background is not streteching. You can add some more content or just add padding to the bottom of your main container to try and add more background there. Not ideal, but that's the simplest way I see to fix the issue.
