I go to Preferences>Interface>Text>UI Font size and change it to Large. After a PS restart, the UI font is large and readable. But after a few PS openings and closings it always reverts back to the default Small size. It never seems to remember my setting. Anyone else have this problem or perhaps something I need to do to make it so that PS always remembers this setting?
Mac OSX 10.7.4 PSCS6
Not sure that's it... Just to verify that an orderly close is not a cause, I quit PS normally, then went back to LR4(latest version) and selected an image and choose "Edit in Photoshop CS6". When the image opened in PS the UI size was back to small. No PS preferences were changed before closing.
Sounds like your Photoshop preferences file is corrupted, then.
To re-create the preferences files for Photoshop, start the application while holding down Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS). Then, click Yes to the message, "Delete the Adobe Photoshop Settings file?"
Once you restart Photoshop, immediately set the UI Size and then quit Photoshop in an orderly fashion. When you re-launch Photoshop once again, the UI Size should stick. You can proceed to set all your other preferences to your liking, as they will have been reset to their factory defaults.
In Bridge if you close program by clicking on the red X in upper right hand corner, it closes the window and therefore forces close on Bridge. To quit program you have to click on File/Exit.
Perhaps it is the same in Photoshop, to properly close PS you have to click File/Exit. I know most people quit a program by just closing the window.
If by chance it is the Wacom driver/tablet, I am going to have to live with it for now. They are a lot of work to set up and so even if I were to disconnect it/delete those preferences, and then reset PS prefs, there's no guarentee the Wacom stuff wouldn't mess up PS again. I can live with the small font, it just isn't as much fun without the larger font.
Thanks for all your help.
Curt,
Just FYI, there's no "red X in the upper right hand corner" of any Mac window.
The menu item to quit Photoshop is called Quit (not exit) and it's in the Photoshop menu, not the File menu.
Closing all windows does not quit Photoshop on the Mac.
To be a real stickler (not to mention a PIA), there's no red X in the upper right hand corner of Windows windows either. The X is actually grayscale/white, it's just the surround that's red. ![]()
But even worse, in Photoshop CS6 the button's surround isn't red either!
And lastly, pressing the button highlighted above in Photoshop in Windows does close the application gracefully, and (assuming Photoshop doesn't crash on the way out) preferences will be saved.
-Noel
Noel,
I was just pointing out to Curt Y the differences between Mac and Windows. The OP is on a Mac.
1.— There is NOTHING on the upper right-hand corner of a Mac window. Niente! ![]()
The Close, Minimize and Maximize buttons are on the left. I choose the Graphite Appearance system-wide, so they're gray, with • – + symbols in them when you hover the mouse over them. Those who choose the Blue Appearance see gaudy red, amber and green lighted buttons.
2.— Closing all windows does not cause Photoshop to exit on a Mac. You only do that by hitting Command+Q or through the Photoshop menu > Quit Photoshop command.
If the OP were not a Mac user, I wouldn't have pointed out these differences.
OK, you got me on the red X. One more point for Noel.
But I know for a fact in Bridge if you have checked "Start Bridge at Login" and close Bridge my clicking on "grayscale/white X surrounded by RED" any changes you made to your preferences will not be saved. They will only be saved if you click on File/Exit. Therefore, I stand by my statement - using the X makes a forced exit and preferences will not be saved, at least in Bridge.
Don't think PS has the "Start PS on Startup" option, but mentioned the above as OP said their prefernce changes were not persistant when he exited program.
And Station 2 - I admit to not knowing how a Mac works. So whether the "X" is on left and are color lights, and Exit called something different, I was assuming the Mac user is smart enough to compute the correct terminology for their computer.
