Hello,
I am creating a series of music worksheets on photoshop. I have created some music scores in a music writing software called Sibelius 7. It has the capability to export the sheet music graphics in the following forms: .pdf, .eps, .bmp, .tiff, .png, .svg .
However, I have tried to 'place' each of them into my photoshop file to see which one will work. But on saving the photoshop document as a .pdf with any of the graphics formats, the vector quality of the image has been lost, as it pixelates on zooming in. I have also tried to import an .svg file into adobe illustrator to save it as an .ai file and then import that into photoshop, but the image is again pixelated.
I don't really know what is happening, as I am essentially trying to import a file that is a vector (or at least does not pixelate on zooming) into photoshop, hoping for the same qualities to be retained, but it is being lost for some reason.
What should I do?
Thank you.
Not surprised that no one has replied.
Why on Earth are you trying to do this in Photoshop and not in InDesign or at least in Illustrator?
I would think Photoshop is not the right choice for what you want to do. Photoshop has at best limited vector support. You may want to do a search for Fonts, Shapes and brushes for music scoring.
If your vector file can be open in Photoshop in a vector format Photoshop should be able yo scale it well. If you "Place" it in a Photoshop document using menu File>Place do not scale it with the transform dialog during place or later with free transform (ctrl+T) that will scale it like a raster layer not as vectors. Instead try double clicking on the layser's smart object icon in the layer in the layers palette. This will open the embedded object in photoshop in a temp work document scale it using menu Image>Image Size if the object is all vector graphics Photoshop will scale it well. When you have the size you want. Use menu File>Save then File>Close no save. During the File>Save Photosgop will update the embedded object used to open the wor document with the updates made to the temp work document.
I had to do a quick test. I knew ai files would boot illustrator from photoshop's smart object. But I did not know that you could with a pdf or eps file. I must have been around long enough to assume that photoshop renders all vectors as raster. But thats not necessarilly the case any more.
But in order for photoshop to use a vector file as a smart object, it looks like you have to place the file, not open it.
I guess it just one of those things, you normally don't think about much, just do it out of habit.
Thank you for all your help. I had a go at using InDesign, but I found it just so awkward to use, as I like to use hex colours and codes for colouring objects, but in InDesign, you have to use those sliders and swatches. Essentially, what I am trying to do is to retain all vector quality, and it's not working. I have installed illustrator, and I can scale the images up to enourmous size in my photoshop document without pixelation, so they are clearly still vectors after they have come from illustrator. But its when the pdf is being produced, the vector quality is lost when I zoom in more than '100%' from the photoshop's design.
However, other vectors, such as the text and font are still retained, but its just the music vector graphics which is lost.
The reason I want vectors is because, this worksheet will eventually be viewed on items such as the iPad, and I wouldn't want any pixelation occuring if someone say zoomed in on the object.
If I used InDesign, would it be able to save vector files? And for the bottom line, does photoshop actually handle vectors on import/placing (which has unfortunately not made any difference to quality as suggested), as vectors still when exported to .pdf etc? Or is that just a fallacy?
If the notes are vector in a pdf converted with Illustrator then they stay vector …
So have you used a pixel format?
Or have you instead of converting placed the pdfs and/or applied transparency in any form to them (Blend Modes other than Normal, reduced Transparency, Effects …)?
Could you please post a screenshot of the ai-file with the expanded Layers Panel visible and one of the resulting pdf where the items have been rasterized?
Thank you for your reply. I opened the vectored pdf into illustrator. I tested illustrator by saving that document as a new pdf and the vector quality was still retained. I the following images, I copied and pasted the vector from illustrator into photoshop. However, on saving this new photoshop document as a pdf, it does not retain the vector format, as you can see with the pixelation that occurs when zooming in on an object.
Thank you.
That’s as expected.
Vector Smart Objects retain the vector data inside themselves but exist as pixels in the psd.
You should probably not involve Photoshop at all in this task but perform it in Illustrator if you want vector output.
There is of course an option to create vector output from Photoshop and that is to paste the paths into Photoshop and use them as Vector Masks on (Solid Color) Layers, but that may be more trouble than it’s worth.
