mangalarajiv
Working with Pdf files
Jun 21, 2012 5:13 AM
I have ten pdf files in a folder. Total number of pages are variying from one to another.
How do i open a pdf file, how to open all the pages one by one for image editing and save it as "jpg"
Could you please help me
thanks,
rajiv.s
    Jun 21, 2012 12:21 PM   in reply to mangalarajiv
    Jun 21, 2012 11:48 PM   in reply to mangalarajiv
    Are the original pdfs proper vector-pdfs, are the texts actual searchable text?
    Because then I would doubt the wisdom of converting them to pdfs than only contain pixel images.
    Jun 22, 2012 5:46 AM   in reply to mangalarajiv
    Do you have Photoshop CS6?
    Because PDF Presentation was reintroduced and therefore one could create multipage pdfs from Photoshop again.
    Jun 22, 2012 6:52 AM   in reply to mangalarajiv
    Something like the following should work; I amended the code you posted and you should probably include a check for the existence of a jpgs-folder to avoid overwriting existing files.
    // 2012, use it at your own risk;
    #target photoshop
    var pdf = File.openDialog( "select file to open","PDF:*.pdf");
    if(pdf != null){
    var theFiles = new Array;
    var folderPath = pdf.fsName.slice(0, pdf.fsName.lastIndexOf("/"))+"/jpgs";alert (folderPath);
    alert (folderPath);
    var theFolder = new Folder(folderPath);
    theFolder.create();
    for(var i =1; i<500; i++){
        var mode = OpenDocumentMode.RGB;
         rasterizePDF( i, 300, mode, pdf); //Page Number, Resolution, File
      if(app.documents.length == 0) break;    //loop passed the number of pages
          // code to process page
    app.activeDocument.flatten();
    app.activeDocument.activeLayer.duplicate();
    app.activeDocument.activeLayer = app.activeDocument.artLayers.getByName('Background copy');
    var idDfs = charIDToTypeID( "Dfs " );
    var desc44 = new ActionDescriptor();
    var idMd = charIDToTypeID( "Md  " );
    var idDfsM = charIDToTypeID( "DfsM" );
    var idanisotropic = stringIDToTypeID( "anisotropic" );
    desc44.putEnumerated( idMd, idDfsM, idanisotropic );
    var idFlRs = charIDToTypeID( "FlRs" );
    desc44.putInteger( idFlRs, 4837760 );
    executeAction( idDfs, desc44, DialogModes.NO );
    app.activeDocument.activeLayer.applyUnSharpMask(50, 2.0, 0);
    if(app.documents.length > 0){
              var saveFile = new File(folderPath + "/" + pdf.name +"-Page" + i + ".jpg");
    //          var saveFile = new File(decodeURI(pdf.fsName.slice(0,-4) +"-Page" + i + ".jpg"));
              SaveJPEG(saveFile,12);
              app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
              theFiles.push(saveFile);
    //alert (theFiles.join("\n"))
    pdfPresentation (theFiles, String(pdf.fsName).replace(".pdf", "_jpg.pdf"))
    function rasterizePDF( pageNumber,res, mode, pdfFile){//pageNumber as integer, pdfFile as File object
        var desc = new ActionDescriptor();
            var optionsDesc = new ActionDescriptor();
            optionsDesc.putString( charIDToTypeID( "Nm  " ), "rasterized page" );
            optionsDesc.putEnumerated( charIDToTypeID( "Crop" ), stringIDToTypeID( "cropTo" ), stringIDToTypeID( "boundingBox" ) );
            optionsDesc.putUnitDouble( charIDToTypeID( "Rslt" ), charIDToTypeID( "#Rsl" ), res);
            optionsDesc.putEnumerated( charIDToTypeID( "Md  " ), charIDToTypeID( "ClrS" ), charIDToTypeID( "ERGB" ) );
            optionsDesc.putInteger( charIDToTypeID( "Dpth" ), 8 );
            optionsDesc.putBoolean( charIDToTypeID( "AntA" ), true );
            optionsDesc.putBoolean( stringIDToTypeID( "suppressWarnings" ), false );
            optionsDesc.putEnumerated( charIDToTypeID( "fsel" ), stringIDToTypeID( "pdfSelection" ), stringIDToTypeID( "page"  ));
            optionsDesc.putInteger( charIDToTypeID( "PgNm" ), pageNumber );
        desc.putObject( charIDToTypeID( "As  " ), charIDToTypeID( "PDFG" ), optionsDesc );
        desc.putPath( charIDToTypeID( "null" ), pdfFile );
    executeAction( charIDToTypeID( "Opn " ), desc, DialogModes.NO );
    function SaveJPEG(saveFile, jpegQuality){
    jpgSaveOptions = new JPEGSaveOptions()
    jpgSaveOptions.embedColorProfile = true
    jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE
    jpgSaveOptions.matte = MatteType.NONE
    jpgSaveOptions.quality = jpegQuality //1-12
    activeDocument.saveAs(saveFile, jpgSaveOptions, true,Extension.LOWERCASE)
    ////// function pdf presentation //////
    function pdfPresentation (theFiles, thePath) {
    var idPDFExport = stringIDToTypeID( "PDFExport" );
        var desc1 = new ActionDescriptor();
        var idflst = charIDToTypeID( "flst" );
            var list1 = new ActionList();
    for (var m = 0; m < theFiles.length; m++) {
            list1.putPath( new File( theFiles[m] ) );
    //        list1.putPath( new File( "/Volumes/Backup HD/photoshop/test/illustratorMove.jpg" ) );
    //        list1.putPath( new File( "/Volumes/Backup HD/photoshop/test/scripteventmanager.jpg" ) );
        desc1.putList( idflst, list1 );
        var idT = charIDToTypeID( "T   " );
        desc1.putPath( idT, new File( thePath ) );
        var idincludeAnnotations = stringIDToTypeID( "includeAnnotations" );
        desc1.putBoolean( idincludeAnnotations, true );
        var idBckC = charIDToTypeID( "BckC" );
        var idWht = charIDToTypeID( "Wht " );
        desc1.putEnumerated( idBckC, idBckC, idWht );
        var idAs = charIDToTypeID( "As  " );
            var desc2 = new ActionDescriptor();
            var idpdfPresetFilename = stringIDToTypeID( "pdfPresetFilename" );
            desc2.putString( idpdfPresetFilename, """High Quality Print""" );
            var idpdfPreserveEditing = stringIDToTypeID( "pdfPreserveEditing" );
            desc2.putBoolean( idpdfPreserveEditing, false );
            var idpdfDownSample = stringIDToTypeID( "pdfDownSample" );
            var idNone = charIDToTypeID( "None" );
            desc2.putEnumerated( idpdfDownSample, idpdfDownSample, idNone );
            var idpdfCompressionType = stringIDToTypeID( "pdfCompressionType" );
            desc2.putInteger( idpdfCompressionType, 7 );
        var idPhtP = charIDToTypeID( "PhtP" );
        desc1.putObject( idAs, idPhtP, desc2 );
    executeAction( idPDFExport, desc1, DialogModes.NO );
    Jun 23, 2012 3:11 AM   in reply to mangalarajiv
    If the Script works OK for single files, you could wrap it in a function to be used in a for-function to pricess the pdfs selected with a Folder-selection.
    var theFolder = Folder.selectDialog ("select folder");
    if (theFolder) {
    var theFiles = theFolder.getFiles(/\.(pdf)$/i);
    Jun 23, 2012 4:06 AM   in reply to mangalarajiv
    How have you set up the for-clause to iterate through the pdf-files from the selected Folder?
    Jun 23, 2012 4:10 AM   in reply to mangalarajiv
    By the way: You mentioned the pdfs have no searchable text, so I wonder if the individual odf-pages are actually images?
    In that case converting the pages would seem less advisable than opening the images.
    Jun 23, 2012 4:18 AM   in reply to mangalarajiv
    So do the pages originally contain vector/font elements or not?
    Jun 23, 2012 4:48 AM   in reply to mangalarajiv
    That does not answer my question.
    Does the original pdf consist of pages that contain vector data or is it actually a pdf that consists of only one image per page?
    #target photoshop
    // get folder;
    if (theFolder) {
    if (theFiles.length > 0) {
    // work through files;
    for (var x = 0; x < theFiles.length; x++) {
    var pdf = theFiles[x];
    // create jpgs;
    if(pdf != null){
    var theseFiles = new Array;
    if (theFolder.exists == false) {theFolder.create()};
              theseFiles.push(saveFile);
    // create the collection pdf;
    pdfPresentation (theseFiles, String(pdf.fsName).replace(".pdf", "_jpg.pdf"))
            optionsDesc.putEnumerated( charIDToTypeID( "Crop" ), stringIDToTypeID( "cropTo" ), stringIDToTypeID( "trimBox" ) );
    Jun 23, 2012 4:54 AM   in reply to mangalarajiv
    It seems the code you originally posted would include open documents in the pdf (provided the pdf was below 500 pages) and close them.
    Easiest to avoid that might be to change
    if (theFolder) {
    to
    if (theFolder && app.documents.length == 0) {
    Jul 18, 2012 12:51 AM   in reply to mangalarajiv
    Like I said, PDF Presentation was reintroduced in CS6.
