scanning photos v negatives into LR 4
Jun 22, 2012 6:36 PM
I have some old photos that I intend to scan into LR4 using a CanoScan 9000E - I also have the negatives.
Is there any advantage to scanning from the negatives v the photos? Does scanning the negs give me more control over any post work I do in LR4
    Jun 23, 2012 12:43 AM   in reply to Paynts1
    LR does not really care if you scanned the printed image or the negative.
    What you do afterwards inside LR solely depends on the quality of your scan result, which you want to get optimal.
    Typically I always scan the negatives if I have them available, as they are usually in better shape than a print and my scanner can scan several in one pass.
    So experiment on quality of scan result and ease of scanning workflow.
    Cornelia
    Jun 23, 2012 6:24 AM   in reply to Paynts1
    Yes, scanning the negatives is much better, providing they are in good condition. Otherwise, scanning the picture will provide fairly good results up to about 2x enlargement (i.e. 4x6  > 8x12).
    I have a Canon 9000F, which I believe is the model you are talking about. It does a good job of scanning negatives using the bundled Canon MP Navigator EX software, and requires minimal color correction. I recommend selecting 'Use The Scanner Driver' mode,' which will allow you to optimize your scan settings. There doesn't seem to be much advantage to scan higher than 4800dpi, but make sure you have 'Enable 48/16 bit Output' and 'Enable Large Image Scans' under Preferences> Scan checked. I also suggest setting 'ProPhoto RGB' profile under Preferences> Color Settings and check Target 'Monitor.' When saving the scans use TIFF mode. You will need to apply fairly aggresive sharpening (~1.2 Radius, Amount 100) in LR, which is typical for this type of dual-purpose scanner. But overall it produces very good scan output.
    The one anomaly I have noticed is that the saved TIFF files do not have the ProPhoto RGB profile assigned to them, so you have to do that manually using Photoshop or other editing application, or LR will assume the files are sRGB profile.
    Here's what Canon Tech Support told me:
    Dear TR Shaner:
    Thank you for writing to us. Unfortunately assigning the color profile in Photoshop would be the only workaround for this.  I apologize for the inconvenience.
    Please let us know if we can be of any further assistance with your 9000F.
    Thank you for choosing Canon.
    Sincerely,
    Karl
    Technical Support Representative
