Why will this code only trace strings?
Jun 23, 2012 7:58 AM
The following code randomizes the array "doors". It works fine if the array is strings. However,
if I remove the quotation marks, it traces "[object Symbol1_1]" instead.
var doors:Array = [red_button, blue_button,yellow_button];
var randomDoors:Array = new Array(doors.length);
var randomPos:Number = 0;
for (var i:int = 0; i < randomDoors.length; i++)
    randomPos = int(Math.random() * doors.length);
    randomDoors[i] = doors.splice(randomPos, 1)[0];
trace (randomDoors);
Tracing (randomDoors.name) returns the  statement "undefined". How can I trace "doors" without converting the elements to strings?
  • kglad
    Jul 21, 2002
    Jun 23, 2012 8:44 AM   in reply to witherton
    assuming those doors elements have names, loop through that array and trace each elements name.
  • kglad
    Jul 21, 2002
    Jun 23, 2012 9:02 AM   in reply to witherton
    the array class doesn't have a name property.  when you use trace(randomDoors.name), you're asking flash to find the name property of that array.
    so, either use:
    trace(doors[i].name);
    or create your own function or class to do what you want so you don't have to repeatedly create a for-loop to trace what you want.
