The following code randomizes the array "doors". It works fine if the array is strings. However,
if I remove the quotation marks, it traces "[object Symbol1_1]" instead.
var doors:Array = [red_button, blue_button,yellow_button];
var randomDoors:Array = new Array(doors.length);
var randomPos:Number = 0;
for (var i:int = 0; i < randomDoors.length; i++)
randomPos = int(Math.random() * doors.length);
randomDoors = doors.splice(randomPos, 1)[0];
trace (randomDoors);
Tracing (randomDoors.name) returns the statement "undefined". How can I trace "doors" without converting the elements to strings?
the array class doesn't have a name property. when you use trace(randomDoors.name), you're asking flash to find the name property of that array.
so, either use:
trace(doors.name);
or create your own function or class to do what you want so you don't have to repeatedly create a for-loop to trace what you want.
assuming those doors elements have names, loop through that array and trace each elements name.
Thanks for the reply, but I'm not sure what you mean by that.
I have tried tracing one element at a time with the ".name" appendix and that returns an element of the array without it being in strings.And as I said, if I just put quotation marks around the elements in the "doors" array, then the array works fine.
I'm just a little confused by which array you're talking about and how I should trace it?
so, either use:
trace(doors.name);
