I'm trying to install PSE8 from disc onto my new laptop (mac running lion). It gets to this point but the Quit and Install buttons have a little blue box right over the text. It seems to disable the buttons where I can't select either. In order to close out of it I need to click the red button, not the Quit. I tested the same disc on a different machine and it looks normal.
Is this a flash or java issue?
Thanks in advance!
I think it is more of the display issues , can you create a new user account , install the software and then check.
Create a new user account :- http://helpx.adobe.com/x-productkb/global/install-or-run-applications-new.html
Once installed log in back in the old account and check , if your applications run fine , delete the new account created to install the software.
I actually tried that. Logged in as admin user and tried the install and it had the same blue squares. When I click either it does nothing. Until I close with the red dot then it confirms that I want to quit.
Strange....can you check in the Safe Mode.
Someone else has also recently asked about these "blue squares" in the Flash Player installer: http://forums.adobe.com/thread/1028564
