baboonery
Unexpected file format
Jun 22, 2012 8:47 PM
HI, I created a video and saved as fla and now I cannot open it.  I can see the video on bride and on my file orgarzer and looks like a flash one, but when attempting to open it, it says "unexpected file format" with an exclamation sign. Any ideas?
Thanks in advance,
    Jun 23, 2012 4:39 AM   in reply to baboonery
    How did you save the video as an fla?  Did you save using a different version of Flash than the one you are using to open the file.
    Jun 23, 2012 5:03 AM   in reply to baboonery
    Often operating systems know to ignore the extension of a file and read the actual metadata of the file. That may be why certain apps can see the video. They know the file extension (.fla) is incorrect.
    It's common that people get the file extension to save wrong when exporting a video or publishing a flash animation.
    If you published this from flash, rename what was published from .fla to .swf
    If you exported a movie (file->export->export movie) then the extension could be many things based on what format you exported. If you remember it was quicktime, or you're on a mac, then try .mov or .mp4. Otherwise if you're on windows try .avi or .mp4. One of those will probably work.
    You can sometimes get file details to help with this by right-clicking on the file and selecting properties (on windows) or file info (on mac) and it may read the header of the file and tell you what type it is.
    If you're on windows, file extensions are hidden by default. If you open windows explorer (Windows Key + E), then in the upper left hit the Organize->Folder and Search Options->View Tab (at top), scroll down a smidge and uncheck the 8th option down so "Hide extensions for known file types" is UNchecked. Then you will see the files extension.
    Jun 23, 2012 3:06 PM   in reply to baboonery
    Ok so you are actually working on a FLA.
    Can you elaborate on what happens when you open the FLA? Can you duplicate the file and try to open its copy?
