Cfif len(form.meeting) do other set of cfif
Jun 23, 2012 2:51 PM
The code below works fine, now I want to add this cfif to check if the form field is empty:
<cfif len(form.meeting)>
</cfif>
I tried wrapping it around the code but it gives me a java error. How can I do this? Thank you:
<cfif DayOfWeek(Now()) eq 2>
<cfset meetingDate = dateAdd("d", 2, now())>
<cfelseif DayOfWeek(Now()) eq 3>
<cfelseif DayOfWeek(Now()) eq 4>
<cfelseif DayOfWeek(Now()) eq 5>
<cfset meetingDate = dateAdd("d", 4, now())>
<cfelseif DayOfWeek(Now()) eq 6>
<cfset meetingDate = dateAdd("d", 3, now())>
<cfelseif DayOfWeek(Now()) eq 7>
<cfelseif DayOfWeek(Now()) eq 1>
<cfset meetingDate = dateAdd("d", 1, now())>
</cfif>
    Jun 23, 2012 3:43 PM   in reply to goodychurro1
    What was the error message?
    Jun 26, 2012 1:03 AM   in reply to goodychurro1
    You could improve that fairly impenetrable code with a switch, thus:
    <cfswitch expression="#dayOfWeek(now())#">
              <cfcase value="1">
                        <cfset daysToAdd = 1>
              </cfcase>
              <cfcase value="5">
                        <cfset daysToAdd = 5>
              </cfcase>
              <cfcase value="6">
                        <cfset daysToAdd = 3>
              </cfcase>
              <cfdefaultcase><!---ie: 2,3,4,7 --->
                        <cfset daysToAdd = 2>
              </cfcase>
    </cfswitch>
    <cfset meetingDate = dateAdd("d", daysToAdd, now())>
    This is much easier to read than what you've done above.
    As a rule of thumb, if you have one or more if/elseif statements that all check the same variable: use a switch.  Only use ELSEIF statements if the condition is evaluating different logic from the one in the the initial IF.
    Adam
