Is anybody else having problems with the metronome in CS6? Twice last night it seemed to botch the beat and trip me up while I was recording. (In the end, I imported a click track from FL studio, and quickly got the recording done.)
I don't use the metronome all that much but, on the occasions I've played with it, I've not had any issues (other than finding where to set the BPM which doesn't seem logical to me!)
By any chance, did you have any other programmes or processes running in background that could be grabbing processor cycles from time to time?
The metronome implementation is quite brilliant IMO and I have cause to use it often and never had an issue with it.
I think Bob might be on to something with his suggestion. http://www.thesycon.de/deu/latency_check.shtml
As to the placement of the BPM settings yes it is a bit odd but as a programmer I can see how if you are 'inheriting' the functionality of a 'track' - a track doesn't have a BPM so they would have had a problem that would not have been easy to fix without some serious jiggery & pokery.
It would however sit well next to the metronome on/off button ![]()
Well, I'm going click crazy, but I've just recorded five minutes of metronome five times and played back each one between recordings. Not a hint of a glitch despite doing it in a way I'd never record a real session, i.e. with tons of junk running in background.
Dobro, I have to wonder if there's something going on with your computer. Hmmm...I wonder what Audition uses as a timing reference to determine the metronome beat? Could there be something going on there?
The one thing I did notice is that the waveform drawing sometimes goes a bit strange when recording--especially the downbeats don't always draw properly even though they sound fine--and the waveform redraws a few seconds later and looks okay. This is with the MT view zoomed out fairly wide so each beat is pretty tiny. I suspect this is nothing but mention it just in case it means anything to those more clever than me.
Yeah, of course it's something with my computer - nobody seems to have this problem but me.
It's not the end of the world, it's just an inconvenience. I'm not expecting a fix, because I don't think there is one short of spending way more time looking for the remedy than I'm willing to put in. I'm posting this here just for the record.
Did you try running the latency checker?
Just a thought...
"This machine should be be able to handle real-time streaming of audio and/or video data without drops-outs."
When the machine is idling, values range from about 80 to 125 units of measurement. I can't monitor it simultaneous with Audition running, but values are well within the green. There are no red spikes. I tried updating my antivirus program while it was running, and I had a single (green) spike that went over 900 units for one second, but it was still in the green.
Just a thought...
Okay, having left the latency checker on in the background, I now get a new message saying that there are bad drivers on this machine which will probably cause dropouts. It gives me a way to go about finding out which driver exactly is the bad boy. Sigh.
Just to add a little more to your experience with the Latency Checker..
Although it "tells" you there is "a problem", the user is left with the unenviable task of discovering what that problem is! On, I think, another form someone pointed me to http://www.resplendence.com whose (free) "Latency Monitor" gives you, IMHO, a rather more useful reading of exactly what is causing any latency problems. It is not the easiest tool to understand (carefull reading of the Help files and ALL the apps tabs is vital) but should assist you considerably in locating and, perhaps, fixing the problem.
HTH
Im new to all this.. is this ''glitch'' you're refering to something like this.. i was recording my husband singing and playing guitar.. (this is in windows 7) everything was fine till he started to sing the chorus.. the music getting louder made the playback at that point sound crackly and the volume lower.. how can i fix this???
No, in my case, the metronome suddenly hiccups on the beat and the rhythm's off. In your case, it sounds like you either had the recording level too high (and it distorted), or you've got the playback level too high (and it's distorting). Check the meters in either case - are they clipping, are they going into the red?
HTH
Thanks, emmrecs. "Your system appears to be suitable for handling real-time and other tasks without dropouts." I'll do some recording and see what it says then. ![]()
Oh, hang on...it's found a problem. Okay, a-sleuthing I will go. I'll report back. Thanks for the software idea.
I got this problem myself using it for the first time today - stumbled across this thread because of it.
Creative juices were flowing, I began a session start recording to 3/4 time signature metronome and it clicks out of time after about 30 sec - recording ruined. Tried again, it did the same so abandoned the session. Frustrating as I'm a one take musician most of the time!
Don't make me have to find alternative software to use! ![]()
EDIT:
I see what is happening. When the playhead reaches the end of the visible play area, that is when the metronome skip happens - it skips back to beat #1 at that point when "making" more visible play area.
In preferences if you switch off Auto-Scroll during playback & recording, this doesn't happen. The problem then is that you can't see what you are doing clearly.
Please fix Adobe.
HTH
emmrecs, thanks for pointing me toward Latencymon - it's been really, really useful. Aside from educating me and suggesting things for me to look at, just the whole process of getting into it and exploring possible fixes got me to where I want to be at this point - the machine's running without any dropouts. The metronome's still glitchy, but now I know it isn't latency problems on my machine that's the culprit.
It could be something else on my machine, but it's not latency problems.
Our engineers have provided a fix for the issue and I am strongly hinting that one might see it in an update in the near future once such an update might be fully tested and confirmed.
The metronome problem was sneaky in that it doesn't show itself at the default tempo of 120bpm. The problem occurs when Audition extends a session duration during recording, and with the default session length of 30 seconds, it typically worked out to always "restart" the metronome at the point it would have begun a new loop. We also discovered the issue was introduced by a minor change late in the development cycle, after the bulk of the testing of this feature had been performed, so it was definitely something that slipped by rather than the team releasing a known bug.
I'll provide more information about an update as soon as I'm able. Thanks!
Durin
Hi All,
I have an annoying problem with metronome. Every time I set up the BPM in a session and save and close the session after work, CS6 forgets this setting! When I reopen the file, the metronome is always set to 1280 BPM. If I change it to the right setting (e.g. 80 BPM) it works fine, but closing and reopening change the setting to 1280 BPM again. And again. I really don't want to store all my BPM settings of my files on paper.
I can't find a solution to solve this. Is it a bug or are there any settings should be changed and I haven't found yet?
