Content aware leaving outline
Jun 23, 2012 4:20 PM
I used content aware on a bag on the forground of a picture. Worked ok, but left an outline. I got rid of that ok with healing and clone.
But some wirse in sky, it's leaving an outline that is no better than the wires themselves. any tips? thanks.
CS5
    Jun 23, 2012 4:45 PM   in reply to kevin4545
    This is the Lightroom forum. I suggest you post your question in the Photoshop forum.
    Jun 23, 2012 5:24 PM   in reply to kevin4545
    No "content aware" in Lr,
    Jun 23, 2012 5:48 PM   in reply to Keith_Reeder
    Moved from Lightroom Forum.
  • Noel Carboni
    Dec 23, 2006
    Jun 23, 2012 6:16 PM   in reply to kevin4545
    I've found that using 0 feathering and turning off anti-aliasing often gives better results.
    -Noel
    Jun 23, 2012 7:34 PM   in reply to kevin4545
    Which tool are you using??
    Jun 23, 2012 8:47 PM   in reply to kevin4545
    Most likely you're selecting the inside of the wire, and not the fuzzy edges.
    With the content aware option, you're better off selecting a bit outside the wires (say 3 pixels or more outside the fuzzy edges).
  • Noel Carboni
    Dec 23, 2006
    Jun 23, 2012 8:49 PM   in reply to kevin4545
    Sorry, I should have been more explicit - I meant to say use 0 feathering and turn off anti-aliasing in the selection tool you use.  For example the Polygonal Lasso Tool.
    -Noel
    Jun 24, 2012 12:09 PM   in reply to kevin4545
    I usually use the spot healing brush (set a bit larger than the wires), or quickmask and a paintbrush set to about the same size.
    Jun 24, 2012 1:12 PM   in reply to Chris Cox
    I use Chris' method most often, and it that does not get me what I want, then the Clone Stamp, followed by the Healing Brush to get the "texture" of the Cloned "sky" back.
    Good luck,
    Hunt
    Jun 24, 2012 3:29 PM   in reply to kevin4545
    In my experience
    CS5
    In my experience you get an outline when
    a) the selection is not large enough, and/or
    b) the feathering value is too small.
    I get rid of such outlines by
    a) increasing the selection by let's say 5 pixels (>Selection >Modify >Enlarge) but the amount is dependant on how big your selection is in relation to the image, and I migh tincrease the selection by 10 pixels if necessary;
    b) increase feathering to maybe 5 pixels.
    You have to play around with these values a bit. These are not hard rules; every image is different. With time you will know intuitively which values to choose.
    But sometimes you can't avoid to clean up with the clone tool afterward.
    Jun 25, 2012 11:40 AM   in reply to kevin4545
    kevin4545 wrote:
    Chris: with spot healing you dont get a selection do you? I don't see running ants. When I do edit fill, content is greyed out.
    Web, so you disagree with Noel, he says feathering 0.
    I don`t disagree with Noel because the feathering depends on the image content, i.e. the surrounding of the area of content-aware fill.
    But often I find that with feathering at 0 you see an edge between the filled area and its surrounding. If you do content aware fill with wires going through a fairly uniform sky, feathering 0 might give acceptable results. But if you had - let`s say - a picture of a beach and on the beach is a piece of ugly flotsam, you would probably need more feathering to blend the filled-in part with its surroundings.
    As I said there are no hard and fast rules; experiment with it. Every picture is different.
    Jun 25, 2012 12:21 PM   in reply to kevin4545
    Well, you can call the clone / heal tool content aware but this term refers to "content aware fill" in >Edit >Fill >Content aware.
    You can use any selection tool for making the selection for content aware fill, the lasso, quick selection tool, magic wand. You use the selection tool that's best for the purpose. After the selection has been made, you fine-tune it for size, feather, etc.
    For "wiry wires" I'd use the polygonal lasso.
    Jun 25, 2012 3:57 PM   in reply to kevin4545
    They don't. You use them after content-aware fill to clean up. Or you use them instead of content aware fill.
    Jun 25, 2012 4:32 PM   in reply to kevin4545
    kevin4545 wrote:
    …pity, would be great if you could select with healing!
    That is totally absurd.
    Jun 25, 2012 4:51 PM   in reply to kevin4545
    >Select >Modify >Feather.
    Kevin4545, you need to watch some tutorials on Photoshop. You need at least to know the basics.
    Or else, you'd spend your time posting questions and waiting for the answer.
    See here: http://www.adobe.com/designcenter-archive/video_workshop/
    Jun 25, 2012 5:07 PM   in reply to kevin4545
    OK, rusty it is. But video tutorials help remove rust, too
