BWScott
Color values and matching
Jun 23, 2012 11:27 AM
I am struggling with how you match colors in Speedgrade. I see that if you click on the image you get a chart that lists RGB and HLS values. (I do not see this feature listed in te documentation anywhere. The chart actually seems to show 2 setes of values and the 2 colors stacked above eachother - image added:
It is a little unclear what these values are. At times they appear to be corrected and uncorrected values, but not always. I cannot find a way to compare 2 color values. Since I am using a Wacom, I can't create 2 playheads to see 2 images at the same time, so that may provide a way.
What is the workflow to compare colors and set one to match the other. Most other clor programs have a method for this.
    Jun 23, 2012 9:17 PM   in reply to BWScott
    I believe the top color is the original and the bottom is the current (with the looks applied). For color matching, try the looks ColorMatch and ColorMatch2 (under +).
