Two questions about sidecar.xml
Jun 24, 2012 4:48 AM
Tags: #upload #article #sidecar
Hi, folks. Hope you are having a nice Sunday
Just allow me two simple question about the use of sidecar.xml files to speed up and simplify the upload-building of a DPS publication.
1. I place a sidecar.xml file in the root of the folder structure. It seems to need that structure to be very simple (no nesting of folders?, All right I can live with that). The folders follow one given order (alphabetic, let's say. It's irrelevant) . Now I want the uploaded articles in DPS to follow the order I described them in the sidecar.xml (another one, completely different). That does not happen: The articles are uploaded and placed with the order of the folders (and that's is something I cannot live with, because it defeats the speeding up purpose of a sidecar.xml). Any idea? Am I doing something wrong?
2. Is there any way (xml tag) I can specify in the sidecar.xml the thumb picture I want to use in the TOC in the Content wiever?
3. The lenght of headlines-titles in the sidecar seems to be too short. Any idea if that is a shortcoming of the sidecar generator or else?
Though I am using the excellent sidecar generator of Johannes Henseler, somehow I think the three questions is unrrelated to it.
Thanks a lot
Gustavo Sánchez (Posting from a scorching sunny Madrid).
    Jun 24, 2012 6:32 AM   in reply to Gusgsm
    @Gustavo – Can you reveal some of your sidecar.xml code using advanced editor of the forum: >> (Insert) / Syntax Highlighting / Java? And a list of your Folders/Files structure. A short example that is showing the problem will do.
    Uwe
  • Bob Bringhurst
    May 29, 2007
    Jun 24, 2012 9:56 AM   in reply to Gusgsm
    Is the folder name "Mordor" or "02 Mordor"? The field in the sidecar.xml file needs to match the folder name exactly.
    If you put the thumbnail .png in the article folder on the same level as the InDesign files, it will be picked up automatically when you import the article.
    http://help.adobe.com/en_US/digitalpubsuite/using/WS67cb9e293e2f1f6060 6c7754128c7a9c00e-7fff.html
    Metadata fields are limited to avoid the cropping of text when the artcle is displayed in the viewer.
    Jun 24, 2012 11:08 PM   in reply to Bob Bringhurst
    @Bob Bringhurst – I think it would be time to exceed the capabilities of the sidecar.xml file with something like this:
    <folderPath>..\root of project\01 hobbiton</folderPath>
    <articleName>hobbiton</articleName>
    where <folderName></folderName> will not be deprecated (for compatibility cases with old sidecar.xml files).
    A relative path description and tags that are  semantically more clear.
    Of course it is debatable if we use <folderPath> or <directoryPath> or, even better:  <articlePath>.
    Uwe
  • Bob Bringhurst
    May 29, 2007
    Jun 24, 2012 11:20 PM   in reply to Laubender
    I agree. We also need the ability to import/export metadata. It's on the roadmap of planned features.
    Jun 25, 2012 2:37 AM   in reply to Bob Bringhurst
    @Bob – good to know…
    Of course also the ability to generate a sidecar.xml file out of an existing project together with an editor (maybe a panel) where you can point to folders.
    If Adobe would exceed the scripting possiblities with the Folio Builder panel, this should be easily scriptable with JavaScript.
    Basically all the information is there. The only thing is that it's very hard to get to them (for building up a tree view with all assets of a folio or an article in case for reporting and getting an overview) and we (the scripters) have nearly no means ("methods" or "functions") to access the pieces.
    There is a app.createCustomMiniFolio() method, not documented very well, but there is no "app.folio" (Folio) object in the DOM or a "miniFolio" (Article) object.
    There is a app.exportFolioToDirectory() method, but no app.importFolioFromDirectory() method.
    It would be good to have  an add() method for creating new folios with all needed properties (all pseudo code here using a made up "folioBuilder" object):
    "app.folioBuilder.folios.add({
    orientation:orientationOptions_HORIZONTAL_AND_VERTICAL,
    size:"1024 x 768",
    and an add() method for creating articles inside an existing folio like that:
    "app.folioBuilder.folios.itemByName("MyFolioName").miniFolio.add(
    {name:"MyArticleName",
    InDesignAssetV: File("Fllepath/myInDesignFile_v.indd),
    InDesignAssetH: File("Fllepath/myInDesignFile_h.indd),
    or a move() method for moving articles around in a folio or even to another folio:
    "app.folioBuilder.folios.itemByName("MyFolioName").miniFolios.itemByNa me("MyArticleName1").move(LocationOptions.AT_BEGINNING, app.folioBuilder.folios.itemByName("MyOtherFolioName"))
    Hope, you'll get the picture…
    Of course offering something like that will slow down development of new DPS versions, but also will open doors for 3rd party developers wide open with new, fresh tools (scripts, custom made panels) and ideas.
    Same goes with Overlay Creator panel.
    Another example how we can make progress in scripting DPS:
    Annotation: all overlay properties applied to an InDesign page item are applied by invisible labels, that stick to that item.
    What went wrong: a tiny change from InDesign CS5.5 to InDesign CS6!
    For scripting we had a method in InDesign CS5.5 for detecting all applied labels (insertLabel() method), that is not functional any more with InDesign CS6:
    object.extractLabels()
    without specifying a key string in "()" the function will not return an array of ALL the key/value pairs any more (great feature in Indesign CS5.5!). Instead we have to gather those information by exporting the page item to an IDMS file and extracting the information from there. A step backwards in ease of use. Please, bring the old functionality back…
    For a detailed discussion in the scripting forums see:
    http://forums.adobe.com/message/4368689#4368689
    Uwe
