ds19aceofhearts
Jitter on vertical pans.
Jun 24, 2012 11:00 AM
Tags: #encore
I imported quick time movies from Final Cut into encore and then burnt a blu-ray.  Although the original movies were fine the resulting blu ray produced jitter and judder whenever the camera pans.
Is there an easy solution (I'm not very technical!)
David
    Jun 24, 2012 11:58 AM   in reply to ds19aceofhearts
    Well... not really... the first thing you need to do is describe the full details of the files you are using, and your Encore settings
    Aug 9, 2012 8:19 PM   in reply to ds19aceofhearts
    Hi David,
      It's my understanding that the H.264 codec for blu-ray is only capable of producing 1080i vertical resolution (i=interlaced) at 25fps- which would explain your jittering (interlaced isn't true 1080 resolution, rather a trick of the eye to replicate 1080 resolution). To produce 1080p (p=progressive which is true 1080 vertical resolution) with the H.264 codec for blu-ray you need to have your source video encoded at 24fps as i understand it... then make sure you select a 1080p (not 1080i) resolution when you transcode it into blu-ray.
    Hope that's helpful.
    Cheers,
    Kev
